Question about Kenmore 53701 Dehumidifier
Kenmore model 580.53701300 does not stay loaded
When the humdifier is placed into run, shortly after starting you hear the compressor load then between 5-10 seconds the compressor unloads. Over time it will cycle, start to load then unload in 5-10 seconds, repeat repeat, repeat....
I have the Kenmore 14 gallon whole house humdifier. The humidity level only goes up to 30 even though I have it set to 45. I changed the filters,cleaned the unit and tried unplugging but it did not make a...
My suggestion is to get an additional humidifier and run both. It sounds like it is at capacity. This was a cold winter and the additional heating put a large demand on the humidifiers.
Feb 27, 2014 | Kenmore 14 Gallon Humidifier
I have a Kenmore Dehumidifier Model # 580.53509300 that it runs but it won't pull out any water. What can I do to fix it?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 01, 2010 | Kenmore 54501 Dehumidifier
The Kenmore 106.955501 dehumidifier works well when first started, coils get cold quickly, fan runs, air moves well. after 1 hr when the compressor needs to kick back on, the lights on that circuit dim and...
The compressor will not start when it is hot or it is no longer bleeding the pressure off fast enough on the high side of the refrigeration system and it cannot start under the load. The start relay and capacitor could also be bad...that would give the same symptoms...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 01, 2010 | Kenmore 54501 Dehumidifier
When running load noise coming from black cylinder
That part you identified is the compressor of the dehumidifier. Compressor is probably bad or going bad. When compressor go bad the valves start making noise and they lose alot of there efficiency.
Dec 10, 2009 | LG LHD65EBL Dehumidifier
A one year old Kenmore dehumidifier model #580-54501700 runs but no water comes out. Do not hear compressor run. Unit powers up and fan runs.
these units are notorious for losing their refrigerant charge,if the compressor isn't running that is one reason why, have a gauge put on the system to see sealed system pressures otherwise the low-pressure switch could be bad,you can test this with a continuity meter
Nov 14, 2009 | Maytag M7DH45B2A Dehumidifier
Fan runs but copressor will not kick on
The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
Jul 30, 2009 | Kenmore 53701 Dehumidifier
Humidifier compressor does not stay on more than 1-2 minutes
Sounds like bad relay on compressor or bad compressor. There is only so far you can go yourself without knowledge in electrical and AC units. Suggest you call a service tech or if you can take it to service cemter near you. Russ
Jul 24, 2009 | Kenmore 5230 Dehumidifier
Kenmore 54501
Normal 0 When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
May 28, 2009 | Kenmore 54501 Dehumidifier
Dehumidifier not collecting moisture
Jan 31, 2009 | Kenmore 54501 Dehumidifier
Kenmore 54501 Dehumidifier Problem
Jul 17, 2008 | Kenmore 54501 Dehumidifier
Kenmore 53701 Dehumidifier Logo
142 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
