Question about HP LaserJet 1020 Printer
Please guide me the steps to disable the" print the event log"
Could you please guide me the steps to disable the "print the event log" option in my driver(in my control panel).. i'm using windows vista home premimum...I couldn't find such options in my control panel...
  • 147 Answers
If you don't want see a printer notification event in the event log you can disable that..
Start regedit and find the key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Providers".
Add "Eventlog" and set the value "Reg_DWORD" at "0".
google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
Posted on Jun 25, 2009
C2A2: system event log (sel) full
even tough you did not specify the generation of your server
if this is the complete error message
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS
this is the way to resolve it :
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key.
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup
Aug 18, 2010 | HP ProLiant ML110 Server
When i am starting my lenovo R61 which has vista installed, it is not starting at all. The AC power light and the battery lights get on along with wireless light. The other two lights will on and off after...
Drain Flee power
Steps
Disconnect AC adapter,
Remove Battery
Press and hold power button for 30 seconds.
Reconnect adapter and battery
Start your pc and go to safe mode and check power settings.
Depending on your OS check event log /windows error log to find out what is causing the problem. And disable the service or reinstall driver needed.
Aug 10, 2010 | Lenovo ThinkPad R61 Notebook
Photoshop Elements 7 is not working on my vaio with vista 64 bit
Starting Adobe Photoshop Elements, the Editor returns the error message "Unable to continue because of hardware or system error. Sorry, but this error is unrecoverable," and the Organizer returns the error message "Interface not found."
Solution: Enable the Event log service.
1. Choose Start > Settings > Control Panel.
2. Double-click Administrative Tools, then Services.
3. Right-click Event Log and select Start.
Note: The Event Log can only be disabled in the Microsoft System Configuration utility (msconfig) under the Services tab, but should never be turned off.
Background information
The error messages "hardware or system error..." or "interface not found" when you start either the Editor or Organizer indicate a system level problem. These messages display if Event Log is disabled. The Event Log is a Microsoft service that should never be disabled.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Sep 23, 2009 | Adobe Photoshop 6.0 for PC
Printer problem - HP Photosmart 8150
If the printer cannot print or move any paper, follow these steps to display the Event Log. Otherwise, print the Event Log.
1. Press Menu until INFORMATION MENU appears.
2. Press Item until SHOW EVENT LOG appears. Press Select to show the Event Log.
3. Press - Value + to scroll through the Event Log.
4. Write down the error messages.
If you see a 52.X error then this indicates the following:
0 Laser/Scanner Error
1 Laser/Scanner Startup Error
2 laser/Scanner Rotation Error
ACTION:
1. Press GO. The page containing the error will automatically be reprinted.
2. Turn the printer off, and then turn the printer on.
3. Reseat the cables fort the Laser / Scanner Assembly.
4. Replace the Laser/Scanner Assembly
Sep 21, 2009 | HP Photosmart 8150 InkJet Printer
How to set the value for event log in the registry
If I understand what you are needing to do is to Disable Print Job Notification in Event Viewer for Windows Vista Home Premium
When you are in the registry editor
and at
"System Key: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Providers]
you should have seen and entry, right ?
name type Data
eventlog Reg_DWORD 0x00000000 (0)
To change the DATA value, double click on the NAME Eventlog
A small window will open that says "edit DWORD value"
Value Name: event log
leave this the same, it is not changeable
Value Data:
Change this data to 0
You can go back into the registry to confirm this value was changed, then turn off your computer and turn it back on again.
This should work for you.
Jun 25, 2009 | HP LaserJet 1020 Printer
Please guide me the steps to disable the"print the event log"
You will need to edit the registry to do this.
Jun 24, 2009 | HP LaserJet 1020 Printer
Laserjet 4100 cancels printing jobs
If you can do the following and email me the output I should be able to help you.
Print the event log
The printer’s internal event log stores the last 20 errors and can be printed at any time. To print the
event log:
1 Press MENU until INFORMATION MENU appears.
2 Press ITEM until PRINT EVENT LOG appears.
3 Press SELECT to print the event log.
kw7157@yahoo.co.uk
Mar 20, 2009 | HP LaserJet 4100 Printer
Server error
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup.
Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
Error 51A2: System cover has probably been opened
I hope there an option in the BIOS that could disable chassis intrution detection. Please check the BIOS settings....
Sep 25, 2007 | Intel SE7320EP2 (SE7320EP2DG) Motherboard
HP LaserJet 1020 Printer Logo
131 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
