Question about Motorola Mobility RAZR V3
Battery is weak but i'm not sure
My phone can't stay turned on for more than a few minutes when its not plugged into the charger. But lately when I plus it in...it's really touch and when I finally do get it to the security code screen I can enter the code and get to the phones main screen. But after like a few secs. the phone flashes and then is frozen and I can't do anything with it...a few secs. later it will flash again and be back at the security code part. It keeps flashing that its charging everytime it unfreezes.
    Scholar:
  • 136 Answers
Did you send and receive any files via bluetooth or install any software, the possible cause may be a virus or corrupt application, try removing the memory card and restart the device, if it starts normally check the memory card for virus infections.
Posted on Jun 25, 2009
My phone will not turn on
Charge it. Once the battery is depleted, if you plug the phone into a charger, the phone will for some time refuse to show any life even while plugged into a charger. If you have some sort of fast charger, it may come to life almost immediately. Otherwise, you are in for a bit of a wait. How long? -An eternity if you need to make an immediate call or receive on. Otherwise, my "guess" is that it will at least work briefly within a half hour.
Make sure your charger IS plugged into the wall to a working wall socket.
If you accidentally completely powered it down, simply power it up. Seems obvious but you have to eliminate the possibility.
There is always a possibility that the battery is not holding a charge. Ask yourself how old is the battery.
Jul 31, 2017 | Cell Phones
My phone comes on and stays on for a few minutes and then it turns off. Can you help me please?
Plug into charger and make sure it's charging. Sounds like battery is dead or bad
Feb 09, 2015 | Cell Phones
My K810i phone doesnt turn on..
let it sit in the charger for 1hour then try to turn on your phone. it could be that the charger cannot charge the battery and turn on the phone at the same time and the battery is too weak to turn it on and needs a better charge.
Nov 11, 2009 | Sony Ericsson K810i Blue Smartphone
No sign of phone charging
I finally have spoken to a very nice youn guy from Sonim Tech Support. He fixed my problem of the phone not turning on.
1. Take out the battery, plug in the mains charger and leave for a few minutes (they say 10 but it took my phone a couple of hours).
2. Eventually the charging symbol will come on the screen, either stady or flashing.
3. Immediately put the battery in the carcass (while it is still connected to the charger), and the charging symbol should stay on.
4. Leave the phone for a couple of hours, disconnect the charger, and the phone should turn on as normal.
This was explained to me, the reason for not turning on was that the software had crashed. This solved it.
Sep 01, 2009 | Sendo Sonim XP1 JCB phone extreme...
I see red light instead of orange
did you try the following?
1. disconect you phone from power supply.
2. take the battery out
3. connect the phone back to the charger
4. place the battery back
if it does start charging (after 3 seconds you see the orange light) just leave it for about 60 minutes to charge. if you still get the red light, try again the 1-4 steps one or two times.
if it does not help you, you might need to replace the backup battery in the motherboard. this is a small CMOS battery, very close to the mini USB connector onboard. I think you should send the device to an HTC service center to do this kind of repair, since electronics ans soldering skills will be required for that job.
Aug 22, 2009 | HTC Touch P3450 Smartphone
Hello, my godmom just purchased a Brand new Blackberry Curve phone.When the saler put the battery in the phone, it didn't power on and she said that the battery was not charged and that we had to charge...
Its very hard to pinpoint the problem from your few descriptions. However since the light came on it mostly means the charger should be okay. As for the phone, if the battery is really dead, it sometime takes up to 30 minutes before it shows that it is charging. SO leave it plugged in for some time to see what happenes. If it did not come on after that then the phone is bad. Just to make eveything sure, you can also try any other MINI USB charger or a simple MINI USB cord to the computer to charge the phone with as well. They all work on the Blackberry
May 06, 2009 | RIM BlackBerry Curve 8310 Smartphone
My motorola krzr only stays on for a few minutes after a full charge.
Yes, you should resort to a new battery, coz the old one is exhausted. Overnight charging is not a good habit. You should charge 2-3 hours until full, and remove the charger
Sep 27, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Won't turn on
Your battery is dead. get a new battery
Aug 19, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Phone will not charge
try once using original charger and just check that your charge pin is connected well with the phone
Mar 12, 2008 | Motorola Mobility V365 Cellular Phone
Phone won't turn on
if after few minutes the the phone is plug into the charger and you turn on the phone and nothing still happans it's not the battery.
Mar 27, 2007 | Sanyo SCP-200
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
