Question about Sony Cyber-shot DSC-W55 Digital Camera
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little cracking noise everytime it turns at a certain point. The screen then tells me to turn the power off and on again. The problem restarts! Please help!
    Novelist:
  • 107 Answers
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jun 26, 2009
How do i turn off the sound on the sony cyber shot dsc-w55?
Press the MENU button, select the toolbox-1 icon, select "Beep", then select "Off". For full details see the "Using Setup items" section beginning on page 50 of the Cyber-shot Handbook.
Dec 21, 2012 | Sony Cyber-shot DSC-W55 Digital Camera
How do I reset the Sony Cyber-shot DSC-W55?
Press [MENU]. Press cursor-right, select Setup (toolbox icon), press cursor-right. Use cursor-up/down to select "Initialize" and press * at the center of the cursor pad. Use cursor-up to select "OK" and press *.
Nov 25, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Where is the reset buttom on Sony Cyber-shot Camera model DSC-W55
It's not a single button.
Press the MENU button. Press cursor-right, select Setup (toolbox icon), press cursor-right. Use cursor-up/down to select "Initialize" and press * at the center of the cursor pad. Use cursor-up to select "OK" and press *.
Nov 20, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot DSC-W150. when powering on the
allienment with the mother board and also failure of the sensors of the lens unit,so contact sony service
Mar 01, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
How to use the timer on a sony cyber shot 7.2mp digital camera
On your Cyber-shot DSC-W55 locate the control button:
32864f9.jpg Using the self-timer
Press cd9ebdc.jpg on the control button repeatedly until the desired mode is selected.
Conditions of the self-timer lamp:
(No indicator): Not using the self-timer
fc274e6.jpg: Setting the 10-second delay self-timer (picture is taken after 10 seconds)
996d00d.jpg: Setting the 2-second delay self-timer (picture is taken after 2 seconds)
Press the shutter button, the self-timer lamp flashes, and a beep sounds until the shutter operates.
Hope this helps.
Thank you.
Oct 16, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
MY DAUGHTER'S SONY DSC-W55 CYBER-SHOT WILL NOT TURN ON
It seems bad. Usually problem with PCB. Ask your daughter if there was possibility to get even drop of water (rain, drink...) inside - in that case you should let the camera dry, but your chance is not big. I´d like I was wrong...
Sep 18, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Replace Sony Cyber-shot DSC-W55 shutter button
Don't throw your Sony Cyber-Shot camera away!
We found a website who has created an entire comprehensive photo instructions for the Sony Cyber-Shot DSC-H Series Shutter Button Installation.
They also have the Sony Cyber-Shot DSC-H9 Shutter Button Installation Instructions as well!
Please note that we STRONGLY recommend using a flash discharger. This is for your safety and also for your camera's safety.
Hope this helps to get your camera working and start capturing memories again!
Aug 18, 2009 | Cameras
DSC-W55 movie camera video display problem
Your quality setting is probably set to the E-Mail quality. This makes the video low quality and tiny.
Just press the button that you use to delete pictures with the regular screen on and change the image quality.
Jul 07, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot DSC-W55 7.2 Mega Pixels
I think, Back Light of LCD in your camera is bad/ defective. You should contact nearest Sony repair facility for proper repair.
Jun 21, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Multiple pictures
Dear ACO107,
Please turn on Cyber-shot in camera mode and press Menu, select Mode, select Normal, OR got to Camera Mode Selection Button (top of camera near power button) and select Auto (Green Color) symbol. Problem would be solved.
May 26, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
319 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
