Question about Maytag Neptune Washer
Maytag Neptune model mah3000aww will not spin dry or empty the water inside the washer. This is the 3rd time this washer has had problems. Is it worth fixing?[Again] It's always had problems from the day I bought it (new)
I called a local repair shop and scheduled an appointment.
Thank you
Posted on Jun 25, 2009
My maytag neptune mah3000aww spins slowly then reverses, then spins slowly. will not reach regular spinning speed. What is the problem?
it could be a balance problem. Most machines are programmed to abort fast spin if the drum is unbalanced. This can be caused by too much in there, or possible the contents have clumped together somehow. Try a spin cycle only with an empty machine and see if it reaches full spin
Feb 18, 2015 | Maytag Neptune Washer Door Mah3000aww
Model MAH3000AWW won't spin
As giving info it seems it needs new control board and door lock .as I could see this is very old model and parts are very expensive
May 06, 2014 | Maytag Neptune Washer Door Mah3000aww
Will not spin, lock light out
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mah3000aww spin problem
there are 2 wires going back to the board. They connect to a blue harness. Make sure their is continuity thru the harness. It connects to 3 out of balance swithches. Also check to see if lock light comes on.
Jul 07, 2009 | Maytag Neptune Washer
Maytag Neptune washer MAH3000AWW seems to backfill after cycle
It could be a leaking water valve. The MAH3000 has two flavors, the earlier model had (2) extra wax motors in the soap dispenser for the bleach and softener controls and the newer ones have the bleach and softener valves integrated into the water valve assembly.
Contact me via the www.neptunehelp.com site and let me know which serial number you have and I can detemrine which water valve you will need.
See www.neptunehelpsong.com for a funny new song dedicated to Maytag Neptune owners explaining the door latch wax motor issue.
Feb 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer MAH3000AWW
order the wax motor kit and replace parts from the internet. there are plenty of videos how to do this. it does require minor soldering and a little mechanical aptittude.
Dec 30, 2008 | Maytag Neptune Washer
Maytag Neptune MAH3 series - doesn't spin completely
hi there,
can you supply the model # off your washer please?
Sep 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
re original issue, see if R11 is burned. if so, need to change R11 resistor and associated triac, and probably wax motor so it won't do it again. temporary fix just cut out R11, door won't lock. if your model won't spin that way, depress actuator for microswitch from door wax motor. instructions on web.
Jan 19, 2008 | Maytag Neptune Washer
Washing Machines Logo
784 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
