Question about Garden
Water pump problem
My water pump coupling boring type does not lift water from undergroound (30 feeet) to overhead water rank (15 ffet fro ground). the electric motor is working fine. suggest solutions. boring is nearly 12 years old
    Problem Solver:
  • 10 Answers
Very old, that. Could be sucking air along the line. Or internal leakage due to wear. Better contact trained personnel.
Posted on Jun 25, 2009
How deep water for pump 63407
you have to say what pump you are using
if it is a submersible pump it could be jammed impeller blades and a blown circuit breaker
if it is a centrifugal pump and is not a jet assist pump then the lift head is exceeded to lift water to the pump from suction Most pumps of this type have a max head lift of 10 ft with a 2" suction pipe as the weight of water is too much to lift A jet assist pump is a better option for up to 20 ft
next is the pump primed now if it was pumping before as a bad foot valve will leak the water out of the pump so that it requires priming before it will work
Jul 13, 2017 | Plumbing
Davey XJ70 pumps bore water but flow dwindles when garden hose attached thus requiring pump to be turned off to stop burn out. Marc
possible it is a jet pump that has a return hose back to the foot valve to assist the pump to lift the bore water higher to work the pump
if that is the case ,when you turn on the tap on the pressure to the lift jet is reduced and so the pump cannot lift the water from the bore --it runs out of water
the fix here is to restrict the flow out of the tap so that jet pressure is maintained--- don't turn the tap on more than 1 turn
the reason is the lift height is too great ,indicating that the bore water level is lower than it normally is
Feb 22, 2017 | Water Garden
My pump is running but not drawing water from the bore hole. What is the problem and how can I solve it?
the pump needs priming first as the water in the pipe to the foot valve has drained out ( foot valve held open by sand grains and not sealing off properly)
the bore is empty
water level too low for the pump to lift water
Dec 29, 2015 | Cars & Trucks
No pressure for onga pump
check for water supply to the pump
If it is a bore pump then check for enough water in the bore, injection pressure to lift the water. It may be necessary to control the output from the pump to maintain the injection pressure. ( put a tap on the outlet side and turn partially off)
check for sucking air at pipe fittings
Mar 08, 2015 | Cars & Trucks
Big rainwater tank ran dry and so electric Onga pump that normally pumps water from big tank to little overhead tank kept failing. Have since refilled big rainwater tank, but pump keeps failing. Have
Release AIR lock. Air has got trapped in the pump hence it cannot create necessary level of suction. The way normally you do this by filling the water path of the pump with water and get the air released.
Oct 12, 2014 | Plumbing
What is the spec on a ingersoll rand type 30 model 15
Hope this is sufficient information:-
Two-stage Type-30 replacement compressor pump for Ingersoll Rand Type 30 Reciprocating Air Compressors. U.S.A. Max. PSI: 175, HP: 15, Flywheel Diameter (in.): 18, Total Cylinders: 2, Bore Diameter (in.): 5 1/2 and 3, Stroke Length (in.): 4
Jan 25, 2011 | Garden
REPLACE WATER PUMP
3.0L OHV Engine
  1. Disconnect the negative battery cable. Allow the engine to cool.
  2. Remove the radiator cap and drain the cooling system.
  3. Loosen four retaining bolts securing the water pump pulley to the water pump hub.
  4. Remove the accessory drive belts.
  5. Remove the automatic belt tensioner.
  6. Disconnect and remove the heater hose from the water pump.
  7. Remove the engine control sensor wiring from the locating stud bolt, if equipped.
  8. Remove the water pump-to-engine retaining bolts and lift the water pump and pulley up and out of the vehicle.
To install:
  1. Clean the gasket surfaces on the water pump and engine front cover. Install a new gasket on the water pump using gasket adhesive.
  2. Place the water pump in position on the engine with the pulley and four retaining bolts loosely installed on the hub.
  3. Apply pipe sealant to bolt No. 3. Refer to the accompanying illustration for bolt location.
  4. Install the bolts in the water pump housing.
  5. Tighten bolts Nos. 4, 5, 6, 7, 8, 9 and 10to 15-22 ft. lbs. (20-30 Nm). Tighten bolts Nos. 11, 12, 13, 14 and 15 to 71-106 inch lbs. (8-12 Nm).
The bolts are of different lengths and must be installed in the correct locations.
  1. If equipped, attach the engine control sensor wiring to the locating stud bolt.
  2. Hand-tighten the water pump pulley retaining bolts.
  3. Install the accessory drive belts.
  4. Tighten the water pump pulley bolts to 15-22 ft. lbs. (20-30 Nm).
  5. Connect the heater hose to the water pump.
  6. Fill the cooling system. Connect the negative battery cable.
  7. Start the engine and allow it to reach normal operating temperature. Check for leaks and proper operation.
3.0L DOHC Engine
  1. Disconnect the negative battery cable. Drain the engine cooling system.
  2. Remove the water pump drive belt.
  3. Disconnect the radiator and heater hoses from the water pump.
  4. If equipped, remove the A/C compressor-to-water pump brace.
  5. Unfasten the four nuts securing the water pump to the engine and remove the water pump.
To install:
Fig. : Water pump mounting-3.0L DOHC engine
  1. Clean the water pump to engine gasket sealing surfaces.
  2. Install the water pump using a new gasket and install the four retaining nuts. Tighten the retaining nuts to 15-22 ft. lbs. (20-30 Nm).
  3. Connect the radiator and heater hoses to the water pump. Make sure the clamps are securely tightened.
  4. If equipped, install the A/C compressor-to-water pump brace. Tighten the brace bolts to 15-22 ft. lbs. (20-30 Nm).
  5. Remove the water pump drive belt.
  6. Fill the engine cooling system, then connect the negative battery cable.
  7. Start the engine and allow it to reach normal operating temperature, then check for coolant leaks and proper engine operation.
Hope this helps (remember rated this).
Aug 10, 2010 | 1999 Ford Taurus
How to change a water pump on a 1995 ford windstar
Fig. 1: Front cover and water pump bolt size and location-3.0L engine
  2. Drain and recycle the engine coolant.
  3. Loosen the four water pump pulley retaining bolts while the accessory drive belts are still tight.
  4. Rotate the automatic tensioner down and to the left.
  5. Remove the accessory drive belt.
  6. Remove the two nuts and bolt retaining the drive belt automatic tensioner to the engine, then remove the tensioner.
  7. Disconnect and remove the lower radiator and heater hose from the water pump.
  8. Remove the eleven water pump-to-engine retaining bolts, then lift the water pump and pulley up and out of the vehicle.
  9. Remove the water pump pulley retaining bolts, then remove the pulley from the water pump.
To install:
Be careful not to gouge the aluminum surfaces when scraping the old gasket material from the mating surfaces of the water pump and front cover.
  1. Clean the gasket surfaces on the water pump and front cover. Lightly oil all bolt and stud threads except those requiring special sealant.
  2. Position a new water pump housing gasket on the water pump sealing surface using gasket sealant to hold the gasket in place.
  3. With the water pump pulley and retaining bolts loosely installed on the water pump, align the water pump-to-engine front cover, then install the retaining bolts.
  4. Tighten the bolts to the following specifications:
    1. Bolt numbers 1-10: 15-22 ft. lbs. (20-30 Nm).
    2. Bolt numbers 11-15: 71-106 inch lbs (8-12 Nm).
  5. Hand-tighten the water pump pulley retaining bolts.
  6. Install the automatic belt tensioner assembly. Tighten the two retaining nuts and bolt to 35 ft. lbs. (47 Nm).
  7. Install the alternator and power steering belts. Final tighten the water pump pulley retaining bolts to 15-22 ft. lbs. (22-30 Nm).
  8. Position the hose clamps between the alignment marks on both ends of the hose, then slide the hose on the connection. Tighten the hose clamps to 20-30 inch lbs. (2.2-3.4 Nm).
  9. Fill and bleed the cooling system.
  10. Connect the negative battery cable.
  11. Start the engine and check for leaks.
Hope this help; good luck and remember rated this post.
May 15, 2010 | 1995 Ford Windstar
As more water is pumped put of the ground, what will happen to the water table? how will this affect the wells?
We lived and raised our children in South Dakota. When the big farms started irrigating our 30 foot bored well water level dropped. When we brought this up we were told to dig a deeper well. We could not afford it. 300 foot wells were expensive. We learned how to recycle bath and laundry water. We got our kids raised up.
Feb 02, 2010 | Educational Insights Hows and Whys Of...
Garden Logo
159 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
