Question about Goodman CLJ30AR32 Air Conditioner
Charging ac system
What is the correct way to charge a goodman ac system
  • 92 Answers
I depends on your inside temp.@ 72 degrees you psi on the large line(suction) should be approx 67. good luck!
Posted on Jun 25, 2009
My car didn't take the R-134a
If your car ac is not taking in refrigerant, it could be caused by several things.
If you have recently done work on the system and you are going to fill the system the first time, you will need to pull a very deep vacuum before trying to charge in refrigerant. If you have already properly evacuated the system and having problems getting the correct charge adjusted, you may be having problem with pressure equilizing between the refrigerant source and your ac system. To get the refrigerant going again, you need to connect the charging hose on the low pressure side of the ac system and turn the fan and ac on cool. The pressure in the ac system on the low pressure side will get lower than the pressure in the refrigerant container and flow will start. When charging initially, charge liquid on the high pressure side and with the ac system running, charge gas on the low pressure side. To charge liquid, invert most container so spout is down, to charge gas, keep container right side up. Charging by gas help you to not over charge your system. Beware on most vehicle ac systems the suction and discharge connections are two different sizes and require the proper adapter. If you still having problems creating a pressure difference to move refrigerant, you can try immersing the refrigerant container in warm water or applying warm air to the exterior of the container.
Hope this helps.
Jan 02, 2015 | Cars & Trucks
Ac not working
The first thing to do is check the charge in the AC system with a set of AC pressure gauges that attach to the charging port, if the pressure is low or non existent then you have a low charge and this means you have a leak in the AC system. The leak must be found and repaired and then the system evacuated and recharged with the correct level of refrigerant
Jul 08, 2012 | 2002 Mitsubishi Eclipse
My Goodman unit won't cool below 78 degrees inside during this heatwave. The thermostat says
your home may not be insulated well enough or you could have leaking duct or your system may not be charged correctly ac systems are not sized to cool below 76 degrees above 90 degrees outdoors because this will increase your utility bills during the cooler temperatures. thank your governement and all the regulations we have to follow for this. they would rather you save money than be comfortable. and we are actually in violation of state law and federal law if we install a unit that will cool below 76 degrees on 90 degree outdoor temp
Jul 02, 2012 | Goodman CKL36AR36 Air Conditioner
My AC unit model is CPLE60-1. It is running, blowing cool air but not cooling house. Any Suggestions? and what is the life expectancy of this unit?
Your Goodman unit is a five ton and should last 15 to 10 years with proper maintenance. Parts do wear out though during the normal life of piece of equipment.
Cooling problem may be due to low charge, broken ducting, or other low airflow problem. Need to verify freon charge and then go from there.
Jul 27, 2011 | Goodman CKL36AR36 Air Conditioner
I HAVE A NEW AC 2.5 TON GOODMAN, MY HOUSE IS 1600 SF I HAVE 3 BEDROOMS AND TWO ARE CLOLED AND THE VENTS ARE CLOSED TOO, WITH EVERY THING OPEN THE HOUSE WILL ONLY GET TO ABOUT 80-81 % NEW HOUSE WITH LOTS...
Depending on everything working correctly with the system, the problem I see may be the size of the system. 2.5 tons is enough to condition around 1000 sq. ft. At 1600 sq. ft. Of living space, you will need a 3.5 to 4 ton system. Unless it was designed in a way that 2.5 tons would work which i doubt, there would be a problem with the charge of refrigerant or other under lying problems. First I would make sure your system is designed right for your house, check all filters and air flow from the vents. Then you go from there. Q good way to check the charge without equipment to do it, on a warm to hot day the outside copper lines should be sweating and warm to hot air coming from the fan on top of the condenser. It's not the accurate way to do it, but a good check anyways. Hope this helps and good luck!
May 25, 2011 | Goodman CLJ42AR49 Air Conditioner
My AC keeps freezing. Condenser pipes freezes all the time and the repair men just keeps adding freon. What is the problem?
Hello MCOMSTI You have a freon leak that MUST be found & repiared so the system will keep the charge.A fast leak is eaiser to find,look for a oil/grease stain anywhere on the system,when you loose 1/2 system charge you make ice.
Aug 05, 2010 | Goodman CLQ30AR32 Air Conditioner
Freezing Goodman pipes
make sure the filter is clean. also the evap coil should be clean. if none of these then your system is probably low on charge. hope this helps
Jun 05, 2010 | Goodman CKL42AR42 Air Conditioner
Ac's are over charged, installer says they come fully charged from Goodman.... having many problems now. What is up?
they come with a factory charge for a set line length but quite often they need more freon. Have freon level checked by another company.
Aug 11, 2009 | Heating & Cooling
GSH13 Goodman heat pump split system is running a long time in cooling mode and will not cool below 74 degrees. A lot of condensation generated. The low side pressures 78 to 81 and high side pressures are...
Check sub cooling and super heat. the New ac units are very critical to charge. There is a charging chart on the inside of the cover to the unit outside. Check temp difference across coil. Should be 18 to 22 degress. If you have an ampmeter. Check the heat strips one 5 kw might be stuck.(sequencer). This would cause you not be able to pull down temp. Goodman unit are hard to charge to get the temp difference across coil. Feedback please
Jun 14, 2009 | Goodman CLQ36AR49 Air Conditioner
5 ton goodman ac unit
You MUST WEIGH IN THE NEW CHARGE OF R-22. There should be a label on the side of the a/c unit that states what the factory charge was. This is only a starting point. Once you have the factory charge in the system, then turn on the unit and allow it to stabilize (5 min) . Check pressure on low side and check teperature on low side pipe. Temperature of pipe should be 8 to 15 degrees above what the boiling point of the refrigerant is for the current pressure you are reading. If the temperature is more than 15 degrees, add R-22 in 4oz increments allowing 5min in between each time you add until you are in the "zone". When you do this, your head pressure needs to be 225-250. if you need to cover the coil or block the outdoor fan to do this then do it. Hook up the vacuum pump and start over
Jun 17, 2008 | Goodman Heating & Cooling
Goodman CLJ30AR32 Air Conditioner Logo
274 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
