Question about Electrical Supplies
12 volt but no 110 power.
My mc 40 puts out 12 volts to the battery but wont put out 110 only just enough to make a small light bulb glow
    President:
  • 1,922 Answers
Your 110 volt regulator is defective
Posted on Oct 07, 2009
Mondeo elproblem
May be but I doubt it. The alternator is not putting enough power to keep the light out. IT works like this battery power (12 volts) flows through the light to the alternator and puts it on when the alternator starts to charge the extra voltage from the alternator (14.5 volts) flows back through the light and as the 2 volts difference is not enough to make the light work it goes out . IF you are measuring 12 volts at the battery and 12 volts at the alternator then then the alternator is not charging. What you should have is 12 volts at the battery and as you rev up the engine the voltage should increase at the battery up to 15 volts maximum at around 2000 RPM
Jan 13, 2014 | Toyota Cars & Trucks
Can u use a 12 volt charger to charge a 6 volt spot light 1000,000 candle power s800g
obviously not as the 12 volt will fry anything 6 volt. It is like putting 240 volt into 110 volt and wondering why it blew up. Get the right charger for the unit and save yourself heartache and money
Aug 12, 2013 | Camping, Backpacking & Hiking
Holden caprice 2007 alternator warning light
charging lights work on the principle of a balanced current throughn the bulb. no charge and the current flows from the battery through the bulb to the alternator. conversly when the alternator is charging at 13.5 volts or better the current is flowing back through the bulb. this opposing current puts out the bulb 12 volt batteries arte in fact 13 volts and alternators charge at 13.8 to 15 volts the 2 odd volts difference is not enough to make the bulb light up. Knowing this it means that some where you have an open circuit that is allowing I suspect battery voltage to make the bulb work. So I would be checking the wiring at the back of the alternator especially the continuinty of the 2 small wires in the connector as I suspect one may be broken in the platsic covering at the fitting The heavier lead is the one that carries the charge directly to the battery
Jan 06, 2013 | Cars & Trucks
Should i have a continuity reading from the power lug on my 9n starter to the frame? i have removed the slipcover and the armature turns freely but when i put a battery charger set on jump across it it...
is this 6 or 12 volt? also is this positive ground or negative ground? if you pull the starter and put it on a bench ( lets say this is neg ground and 12 volts) put red charger clamp on the post and touch the black clamp to the casing (where it bolts up) it should turn over. things would be hooked different if its 6 volt or if its pos ground
Jan 07, 2011 | Ford 8n,9n,2n, Tractor Starter With Drive
Brake lights doesn't work
Either the brake light bulbs are faulty and needs replacement.But if in case the brake light bulbs checked out ok and the bulbs are glowing by connecting brake light bulb to battery directly ,then in that case the brake light switch is faulty and it has to be replaced./ Check for 12 volts at the terminal in the light socket when the brakes are applied.If there is 12 volt then its a bulb problem ,but if no 12 volt then its switch problem.The brake light switch located under the dash above the brake pedal. ------------ Keep updated for any more queries.Thanks.
Oct 22, 2010 | 1992 Buick Regal
I have a Red Lion submersible pump, drawing water from a lake. The pump has a low voltage charge (about the same as a 12 volt battery), after all power is shut off.. I have even shut off the main breaker...
If you are measuring this with a volt meter, you might be measuring a voltage with a VERY small current that could be coming from the pump motor magnet in combo with the plumbing and minerals in the water...but, that may not matter. To see if this is significant, hook up a 12V test light using an automotive interior light bulb or a turn signal bulb. Try it at night (or at least out of the sun) so you can see if you get a bit of glow. The current may be so weak that it cannot maintain even one volt across the light bulb filament, in which case you can disregard it. You can put your voltmeter in parallel with the test light to measure the voltage with the light bulb load in place.
If the light bulb does light up, then you have a problem. Please update this with where exactly you are measuring this 12V, and clarify if you are seeing this voltage only with the pump still connected to power.
Aug 10, 2010 | Simer 1/12 Hp Non Submersible Multi...
2004 Chevy Malibu front right turn signal burns out after one or two times. What is the fix for this?
are you buying the right bulb should be eather 3157 bulb if you use a 3057 they are wrong also make sure they are 12 volt light bulbs your sustem should be a 12. volt system and your alternator puts out apx 14 volts this is not enough to blow out a buld that can take 12.6 + volts you may have other issues
Feb 25, 2010 | 2004 Chevrolet Malibu
1984 ford ranger keeps blowing the running light fuses. when i let it sit at idle it won't blow the fuses but as soon as i start driving with in 5 mins or so it blows.... any ideas?
short in the wires will need a wiring diagram and ohm/volt meter to locate the problem, test lights work well to.
you will need replace the fuse with a light bulb so that the power will not go away. and you will have to search for power going straight to a ground source.
usually a raw wire from rubbing somewhere. can do a quick visual inspection first for the obvious, and then use the meter at certain points till you find a volt drop.
May 13, 2009 | 1984 Ford Ranger
My dometic frig will not work no power. Has 12 volt and 110 volts
Replace the bulb and also check the relay and the sensor in the back of the unit. But first try replacing the bulb
Feb 13, 2009 | Dometic RM2652 Refrigerator
Electrical Supplies Logo
108 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
