Question about BenQ MP611C DLP Projector
My BENQ MP611C stops projecting video after ~20min
My BENQ MP611C works fine right at the start, but after some 20 min. or so the video projection disappears, the lamp stays lit, and only a very faint, dark, empty screen is shown up front on the wall; neither video nor OSD gets shown at this point. I then have to turn it off completely and (after a couple of minutes of rest) turn it on again, and once more the projector starts working correctly, but after a similar lenght of time of good performance the video suddenly goes blank again, and so on. And no, the built-in timer does not seem to be related to this problem, since this happens whether its on or off (I tried both ways). I even placed a big fan near the projector to improve ventilation to it, but the results were exactly the same. I lack the user's manual, so I do not know whether the problem could be related to some kind of initial configuration. I have been using the S-Video input only, feeding videos from my laptop. Any clue to what the problem might be? All help in this matter will be highly appreciated. Thank you in advance!
  • 3 Answers
This happened to me once, it turned out to be the visual settings of the graphics card. In my case it was an Nvidia card and the softare allows you to have a different setting per monitor. All of the contrast, brightness, and well, all the settings were all the way down, but only for the Benq. I turned them all up and saved, now it works great. It was just like you described, a very, very faint image was visible. I suspect my graphics driver was updated, and the projector settings were somehow set to zero.
Posted on Aug 17, 2009
WHY IS THE PROJECTION FROM MY BENQ MP611 DLP IS COLORED VIOLET?
one of your input cables us either bad or not seated properly. Remove cable from projector & re-install tightly.
Mar 25, 2011 | BenQ MP611C DLP Projector
When I first start the car the air works fine for about 20 min, then the air comes out warm. If I turn the air off about 5 min and back on it will work for another 20min. What to do.
Is your air on MAX? If it is ... you are having a freeze up condition ... put your air on some lesser setting to preclude it freezing up on you.
Jul 05, 2010 | 2002 BMW 3 Series
My ps3 has just started to stop playing blu ray films after 20min
the laser is starting to go bad in the dvd drive. It takes more power for the drives laser to read and play a blu ray movie then it does to play a dvd game.
You can either replace the laser if you have the technical knowledge to take the dvd drive apart, or just replace the drive. You can usually find either one on ebay.
Aug 04, 2009 | Sony Playstation 3 (PS3) Console
I Have 1997, 850 Volvo with Intermittent A/C Problem.
Most probably it is the clutch gap on the compressor. I had the same problem on my 1998 V70.
See instructions on how to fix it on the Volvo forum.
Jun 17, 2009 | 1997 Volvo 850
Monitor shuts off during use
3 years old and generally rated as a Mediocre monitor to begin with, I'd say I'd invest in a new monitor
Here are some replacement options:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010190020%201309821311%204017&name=%24100%20-%20%24200
Sep 10, 2008 | BenQ FP72G+ 17" LCD Monitor
Convergence
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 13, 2008 | Philips 55PP9352 55" Projection Television
Samsung SP43W6HPX\XEU Rear projection
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Oct 25, 2007 | Samsung HCN4226W 42" Rear Projection...
TV turns on for about 10-15 min then turns off
Sounds like a tuner section problem. When you are playing a DVD. You are only using the audio video circuit of the TV. Something like a monitor. But when you go back to TV mode... You are now in the tv tuner circuit. And your problem lays there. I had a mouse **** on my tuner section of my tv and it caused the same problem. Yes mice do ****...
Aug 18, 2006 | Panasonic PT-47WX53 47" Rear Projection...
BenQ MP611C DLP Projector Logo
344 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
