Question about Garmin nuvi 750 GPS Receiver
Nuvi Blackout Nuvi kept telling me it could not acquire the satellite, then it displayed GPS update complete, then spent several minutes aquiring the satellite ( which it never did) and shut off. Went through this cycle several times. Now it won't turn on at all.
This is a known problem that Garmin is fixing. Look at:
http://www.garmin.com/garmin/cms/site/us/support
Under "TOP FAQ" there is an entry for "My nuvi 755T, 765T, 775T or 785T will no longer turn on."
You will need to return your unit to Garmin for them to fix it.
Posted on Jul 02, 2009
I have a nuvi 200w. My firmware updates and then I cannot aquire satillites. Do you have a solution?
It sometimes takes several minutes to acquire satellite signal afterward.
Make sure you have clear visibility of sky away from tall buildings.
If that fails try reloading software again, go to garmin and download web updater.
1 option in this is to reload all software again.
Feb 07, 2011 | Garmin nuvi 200W GPS
Gps not acquiring satellites
Press and hold the antenna signal strength icon on the display to bring up Satellite reception information. This will show you what, if any, satellites are being tracked. It will also tell you if you're in DEMO mode, in which case real satellite signals won't be used for the position.
Additionally, you can check the hardware by using the built-in hardware self-test features by pressing and holding the battery icon. Examine the information presented on multiple pages by pressing 'next'. Look for the hardware TEST button and press it. Wait several seconds for results.
These two steps should at least tell you where the problem is. If you ARE getting Satellite signals but they aren't being used by the hardware, you may need to reset your unit. Also check for firmware updates by using the Garmin Update utility available on their web site.
Apr 04, 2010 | Garmin NUVI 360 GPS Receiver
GPS wont aquire a satellite
    Hello there and happy new year
    If Your Unit Cannot Acquire Satellite Signals
  1. For your Garmin GPS unit to acquire the satellite signals it needs to function properly, the unit must be taken outside, away from mountains, tall buildings and heavy foliage where it can get a clear view of the sky. Keep the unit stationary for several minutes while the GPS unit acquires the necessary satellite signals.It may take several minutes for the unit to locate a good solid signal
  2. OK
  3. Hope this is very helpful please keep me posted on this ok?
    Best regards Michael
Jan 01, 2010 | Garmin MAP76 handheldS GPS Receiver
While driving Garmin Nuvi 250 constantly loses satellite signal. The screen says that it is aquiring a signal. It is also constantly refiguring the route.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
Nov 12, 2009 | Garmin nuvi 250 GPS Receiver
Brought my NUVI from NY to San Francisco and it doesn't locate any satillites. What can I do?
Good Luck
Jul 07, 2009 | Garmin nuvi 260W GPS Receiver
Garmin nuvi
If a GPS gets a factory reset, powered off for months, or powered up again in a different country, it will eventually scan the sky for any satellite it can find, and then download a new almanac and ephemeris - which can take up to 12 minutes after it finds the first satellite. This is best done stationary, to minimize the doppler effect until a fix is acquired.
Sep 12, 2008 | Garmin Nuvi 660 GPS Receiver
Dont Aquire Satellites
Ditto.. even after updating FW...
Jun 14, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi takes a long time to Acquire satellite
No. 98% of the time it took 45-56 seonds for your NUVI 660. Thats the compagny set up time acquisition and it did very well.
Be sur you had your flip antenna parallel to earth surface.
660 has THE BEST SIRF Chipset for acquiring satellite.
I had 2 NUVI 660 since 2 years. It work much better than those new 7xx series who it really took 2-3 minutes to acquire satellite.
Be sure you update your version to the last one.
----> https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=134&pID=400
Best regards
Jan 12, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 250W
try pushing the reset button on the back of the unit and then it should restart and acquire the satellites
Dec 26, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 750 GPS Receiver Logo
328 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
