Question about LG RZ-37LZ30 37 in. LCD Television
RZ 37 LZ 55
Have lost two(2) power modules, this can't be correct can it?
My dad is still watching his 25 year old jvc.
I paid £2200.00 for it, who do I complaint at/
  • BKOK Nov 24, 2007
    My lg 37 lcd has just blown (RZ37LZ55).Heard a crack sound and tv went off wont come back on again. Any solution as to what it could be, how much to fix and where to get it fixed. Would be greatful to hear from anybody with the answers
    Problem Solver:
  • 6 Answers
Checkout ebay user gazglasgow on www.ebay.co.uk
Posted on Sep 27, 2009
  • 934 Answers
The fact that you're having trouble with the SMPS is probably something in the set loading it down. For this I'd take it to the shop where you had the SMPS replaced before and that would be the place to start with the complaints. They should be able to test the X,Y, logic and main board to find the source of the problem.
Posted on Nov 05, 2007
1990 Voyager. Need code definitions from check engine light. Codes retrieved by turning key on 4 times and counting check engine light flashes. codes were: 12 41 25 55.
here you go hope it helps,dont forget to vote on answer thanks
88–95 3.0L (Except Monaco, Premier & Stealth),
3.3L, 3.5L & 3.8L Engines
11
Engine Has Not Been Cranked Since Battery Was Disconnected{4}
No Crank Sensor Signal During Engine Cranking{3}
12
Memory Standby Power Recently Lost
13
MAP Sensor Pneumatic Circuit
14
MAP Sensor Electrical Circuit
15
Vehicle/Distance Sensor Circuit
16
Loss Of Battery Voltage Sense
17
Engine Running Too Cool
21
Problem In Oxygen Feedback Circuit
22
Coolant Temperature Sensor Circuit
23
Charge Temperature Sensor Circuit
24
Throttle Position Sensor Circuit
25
AIS Motor Drive Circuit
26
Injector Current Limit Not Achieved
27
Injector Driver Interface Circuit{1}
Injector Control Circuit{2}
31
Purge Solenoid Circuit
32
EGR Diagnostics
33
A/C Cutout Relay Circuit Or A/C Clutch Relay Circuit
34
Fault In Speed Control Solenoid Driver Circuit
35
Fault In Fan Relay Circuit
37
Part Throttle Unlock Solenoid Driver Circuit
41
Fault In Charging System Or No Field Current
42
Fault In ASD Relay Driver Circuit
43
In Ignition Coil Control Circuits
44
Lose Of FJ2 To Logic Board
46
Battery Voltage Is Too High
47
Battery Voltage Is Too Low
51
Lean Condition Is Indicated
52
Rich Condition Is Indicated
53
Internal Problem In Module
54
Fault In Distributor High Data Rate Pickup Circuit{1}
No Sync Pickup Signal{2}
55
End Of Message
62
Unsuccessful Attempt To Update EMR Mileage
63
Fault Error{1}
Controller Failure EEPROM Write Denied{2}
65
Manifold Tuning Valve
66
CCD Bus System
77
Speed Control Relay Circuit
{1}—1988–91 models.
{2}—1992–95 models.
{3}—1990–95 models.
{4}—Neon.
If you need more just ask Thanks Db
Aug 18, 2010 | 1990 Plymouth Voyager
Burner igniter won't click or work
This is an easy problem to fix. If your repair man is correct and it is the spark module and not a wire harness problem you can pick up a spark module as sears for about $37 and it only takes a couple of minutes to install. Just pull off the back panel and replace the module. This is a repair that anyone can do. I would recommend unplugging the unit before replacing.
Jun 20, 2009 | Maytag MGR6772 Gemini Gas Kitchen Range
Myota Watch Batteries
Try a Maxell 391 silver oxide
Oct 10, 2008 | Watches
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Age problem
Since you have the answer, the easiest way to work with this is to work with real numbers and break it down. What are the knowns?
Rose + 25 = Dad
10 + 25 = 35 (today)
5 years ago, Dad (then 30) was 2x old as Rose will be 5 years from now (+5), or (30/2) -5 = 10
You can also put this into formulas
Rose + 25 = Dad
Dad - 5 = 2 * (Rose + 5)
So, if Dad = Rose + 25, you can substitute one for the other in the 2nd formula, like so:
(Rose + 25) - 5 = 2 * (Rose + 5)
Rose + 20 = 2 * (Rose + 5)
Now, you can solve for Rose and eventually come up with 10
I hope this helps.
Jul 20, 2008 | Computers & Internet
Power problem
Check out ebay for the part.
My 3 year Sceptre 27" died. Local TV tech said it was the power module. Charged $25 for the diagnosis and wanted $190 to fix it. Took it home, popped the screws and the module almost fell out. It's a simple plug'n'play!!! Found a new module on eBay for $65 shipping included.
Jun 03, 2008 | Sceptre X37sv-Naga 37 in. LCD Television
JVC LT-Z37 SX5
is the power cord good leave it disconect over night try it in the morning or power bar those thing are not good for life hope it work take care cheers
Jan 17, 2008 | JVC LT-37X776 37 in. LCD HDTV
Casio watch g shock watch model 7100d
Go to this link and with the four digit module code from the back of the watch you should be able to get a manual; http://world.casio.com/wat/download/en/manual/ Hope this helps :)
Jan 30, 2007 | Casio G-Shock G7100D-1V Wrist Watch
LG RZ-37LZ30 37 in. LCD Television Logo
311 people viewed this question
Computer Repairing
Computer Repairing
