Question about Dayton E50 Heater
My oil fired water heater will not ignite - Dayton E50 Heater
  • 332 Answers
Make sure your oil line is clear and oil is comming thru the line,, make sure when oil is comming thru the line you tighten it up so there is no leak,, if it still doesn't ignite you will need to have the burner assembly cleaned {serviced} I will not tell a customer over the computer how to do this process beings it is flamable and not safe for an untrained person to do this part of the job,, good luck
Posted on Jun 30, 2009
Boiler won't ignite for hot water unless heating is on.
If this is in a RV the propane monitoring valve may require more gas flow to turn on than the water heater requires. A central heating system requires substantial gas flow so when the monitoring valve opens to fire the central heating, there is enough gas flow to also fire the water heater.
Jan 26, 2016 | Water Water Heaters
Boiler ries to fire on heating or hot water but then shuts down after 10 seconds to F1 with the flashing red light, any ideas. clearly same principle as any boiler but I'm looking for someone who has...
that would indicate that the boiler is not firing up
If oil fired, been there done that
it is out of oil
the oil filter is clogged
the nozzle could be clogged/burned
the igniter wires need adj/replacement
if gas fired - similar issues but no experience
Dec 08, 2014 | Water Water Heaters
Wont always fire up
You probably have tankless water heater.
What brand water heater?
Gas or electric?
Is this new installation or old installation?
For Rheem tankless:
Copy following link: If you get no error code on remote control, then scroll down to 'no error code.'
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 11, 2012 | Water Heaters
My 32E Bock Oil Water Heater will not fire up. What is the gap between the little lighter fingers? Or whatever you call them? We got it to fire once but then it went out again shortly. We have checked...
Hello You have a clogged oil filter or oil line.The (electrode) gap should be left ALONE.The line needs to be blowin out & replace the filter element then the flameout will stop.
Sep 03, 2010 | RTO Bock Water Heaters 32E 32 gal 104,000...
No hot water. Gas co. serviceman says problem with draft inducer.
try to remove pipe you could have a clog water,ice,nest. also you may have a bad pressure swith hose find the hose and **** to see if it will fire
also if you take your pipe of you make turn on to see if you get fire you can not run for more then 30 sec with this off co. will fill the house.
Feb 13, 2010 | Fasco GSW Hot Water Heater Exhaust Draft...
How do i clean out my system for my oil hot water heater? some how we ran out of oil, i guess we used way too much oil, it usually lasts until november but went out mid sept, i had oil delivered and now it...
It sounds to me like you probably have a clogged oil nozzle. Of course I'm am assuming that you bleed all the air out of the oil lines that run both to the hot water tank and the heating appliance. If you have solid flow at the water heater pump, and the unit still does not ignite, it is most likely the nozzle. Hope this helps
Sep 14, 2009 | RTO Bock Water Heaters 51E 50 gal 152,000...
Water heater not firing up
Make sure thermostat is turned to 120 to 150 degrees Fahrenheit. Turn the thermostat down and back up to see if it ignites. If it lights put the cover back on and set it to temp you want it to be. if not, you have a bad thermostat.
Hope this helps.
Aug 14, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Heater wont ignite. Has fuel coming out front of
if the spark plug is sparking it is hot enough to lite the fuel.is ther dirt in fuel tank???is there water in the fuel???? what is the air pressure set at????is the nozzle clean and spraying correctly?????any of these will cause the heater not to fire.not the spark plug.
Feb 20, 2009 | Dayton E51 Oil Filled Utility Heater
Wat the hell is wrong with my dayton heater?170,000 btu oil fired...wont stay runnin?on shut down puffs like a mutha....
Most use a spark plug to ignite fuel it could need cleaning. You also could have water in fuel or dirt
check and clean ignitor/spark plug clean fuel line and nozzle, drain and clean tank Check for water in fuel by tilting unit to have a low corner siphon fuel from that corner after 1 hr inspect for water.
Jan 23, 2009 | Dayton E51 Oil Filled Utility Heater
Dayton E50 Heater Logo
137 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Tim Whalen
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
