When I put the washer on, water flooded on the floor
  • 58 Answers
More info is needed, top loader, front loader, model and serial num..?? send info to jordanaschmidt@aim.com and I can help.
Posted on Jun 25, 2009
Floods floor when on rince cycle Program Bed andBath. Fault intermittant
If you didn't flood the floor when the washer emptied on the wash cycle, it is more likely that you have a partially plugged up drain than a malfunctioning washer!
Has you drains been cleaned lately, being the spring time you might have a root problem partially blooking the drains.
Watch you washer, if the washer flushes the water down the drain line it is working. If the water comes over the top of the drain line, then you have a slow drain.
Jun 01, 2011 | Washing Machines
WILL NOT START SHOWS "F" FAULT Water on floor by water inlet connection .There is a permanent motor running Pump Motor??
This doe seem that the anti flood system has triggered. This device puts the machiene in pump out mode and shuts off the input water supply.
The device is a safety device that triggers once it detects a water leak (pipe / clamp) and consists of a polystireene float and micro switch at the floor of the washer. First check to see if the float has activated the micro switch and then dry the machiene floor and check for leaks.
Jan 25, 2010 | Dishwashers
Ndesit IDL 535 DW, not cycling, water coming from under unt.
The washer is fitted with an anti flood device that detects water leaks and closes water inlet valve and puts washer in pump out mode. The anti flood device is a polystireen float with micro switch at the bottom floor of the washer. Dry the water and find the leak (pipe or pipe clamp) and this should then solve the error.
Jan 22, 2010 | Indesit 24 in. IDL500 Built-In Dishwasher
Machine not starting ...Programme Progress Display light flashing
This normaly indicates an error code. Could be the anti flood device activated due to water leaks etc. The anti flood device (polystireene float and micro switch at base of machiene) puts the washer on pump out mode and shuts off the inlet water. Dry the water at the floor of the washer and check and rectify any leaks.
Jan 21, 2010 | Dishwashers
Water wont come through the dishwasher.i checked the water supply switch it is still in the on position what should i check next.
The anti flood system could have triggered (due to water on the base of the washer via leaky pipe) This device shuts off the water supply and puts the pump out motor on and nothing els happens until you clear the water on the washer floor and rectify the leak.
The anti flood device is a polystireene small plate with a micro switch on the bottom floor of the washer.
Jan 19, 2010 | Dishwashers
Our dishwasher does not seem to be getting any
The anti flood device (polystireene plate and micro switch) when activated due to water leak on floor of washer, shuts off the water inlet valve and puts the drain pump on. Determine if any water has leaked to the floor of the washer and is activating this switch. Dry the water and rectify any leak. The water inlet valve (solinoid) could also be faulty although this is not common.
Jan 18, 2010 | Dishwashers
Water level will not stop and floods floor
check the level switch by blowing on it if clicks is good if not replace the switch , make sure that the hose that connects to the switch is free of debri
Jun 18, 2009 | Kenmore 22422 Top Load Washer
Portable Whirpool washer, floods the floor when in use
dose it stop flooding when you stop the timer or turn off the water.if timer your presure switch hose has come off.have to empty washer to reinstall because water in tube gives false reading.if when you turn off water its your water level switch.God bless,tom
Jan 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
