Question about Epson LQ 300+ Matrix Printer
Printing stops halfway through on Epson LQ300+
I configured my Epson LQ300+ printer on my PC (Vista Ultimate) using a ''USB to PARALLEL PRINTER ADAPTER 1284 CABLE 36 PIN IEEE''. Printer got installed using the vista drivers auto. Problem is, it stops printing halfway through on the paper all the time. Then I can't even eject the paper, that button won't work. I ll have to switch off/on the printer again to eject the paper. I used the default settings.
Please help.
Thanx & rgds
shareek
  • shareekahmed Jun 25, 2009
    No it wasn't similar. Paper orientation is "Potrait" and I m printing on a potrait orientation paper. It just stops suddenly after about completing 65% of the printing.
    rgds
    shareek
  • Richard Schabler May 11, 2010
    I've had a problem with printers that was similar. It turned out that the application I was printing from was printing a Landscape orientation paper, and Windows was printing Portrait orientation paper. The result was an 8.5 x 8.5 inch print. Does this sound similar to what you're getting?
    President:
  • Epson Master
  • 1,447 Answers
You use dpi 180X180 then print full page and speed fast
Posted on Jun 25, 2009
How to print from Window Vista to Canon BJC80 printer using USB to Parallel cable
Helen, is the printer correctly installed in laptop? Check if shows under Printers and devices. If not, install and show it as default. Make sure your usb connections are ok.
Mar 19, 2014 | Canon BJC 80 InkJet Printer
Epson lx-300 parallel to usb printing problem
Make sure driver for Parallel to USB adapter is installed properly, this doesn't guarantee that it will work. Suggestion is, check for interface availability for Epson printer if you can change parallel interface at the back of it to USB interface. Call Epson for details and availability.
Sep 21, 2012 | Epson LX Office Equipment & Supplies
Epson TM-T90 wont work with USB plug
I have the same problem...Epson does not work with a parallel to usb cable or adapter. If you still want to use this printer you will have to use the parallel port or change the interface on the printer to USB.
Nov 21, 2009 | Epson TM T90 Printer
Windows 7 is not recognizing me Epson RX595
The following steps may help:
  1. Remove all the drivers and software installed for this printer.
  2. Restart your computer.
  3. Click here to go to the driver download page. Download the driver for Win 7 and install.
  4. Connect the printer to your PC, the installation will continue.
  5. After installation, you should be able to use your printer.
Nov 03, 2009 | Epson RX595 Photo All-In-One Printer
USB to Parallel connection (Panasonic KX-P1121)
I would recommend buying a Printer parallel port connection (PCI to LTP1), install it into the system, and use the printer parallel cable.
Sep 02, 2009 | Nikon COOLPRINT Thermal Printer
Problem printing from Dell Inspiron 1720 with Vista Home Premium to Epson Stylus Colour 1160 using Nikkai USB to Parallel Convertor. Cable supposed to be plug and play. Any pointers?
You pretty much said it when you mentioned "Other than buying the cable in the first place" I have never successfully used a USB to parallel converter cable on any system. My suggestion, asisde from getting a true USB printer, is a parallel port card
http://www.newegg.com/Product/Product.aspx?Item=N82E16839328010&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-PC+Cards/PCMCIA+Add-on+Cards-_-Syba-_-39328010
May 16, 2009 | Dell Computers & Internet
Window vista
You first need to get a Parallel Printer to USB cable. Once you have that, in Vista, click add a printer, do the windows update, and Epson Stylus Color 1520 should appear. Now you need to make sure that the port being used is the Virtual USB Printing Port, for example USB001....and there you have it...
Jun 25, 2008 | Epson Stylus 1520 InkJet Color Printer
HP LaserJet II p Plus will not print
I am assuming that you are using Vista. Based on your post/description:
1. the HP Compaq 6710b has no parallel port;
2. the HP LaserJet IIP Plus is only capable of either serial or parallel connection;
3. hence you're attempting a USB to Parallel interface;
4. the printer is installed in your notebook and is set to USB port;
5. from the printer a test print can be performed but not from the Printer Properties in your notebook;
6. all printing jobs initiated from the notebook results in an "Error".
With the above in mind, may I point/suggest that:
a. Windows Vista driver will only enable your HP LaserJet IIP Plus' basic functions to work. It is not 100% compatible;
b. alternately, you can try using the XP installation CD/drivers of the printer;
c. the compatibility issue may be compounded by the USB to parallel interface;
d. the USB to parallel interface may be hampered by a known Vista USB issue;
e. you can try patching/updating the Vista USB driver. Since this has been a recognized issue with Vista, Microsoft has posted a fix for this here or here.
f. verify that the printer does not display a 22 or 40 Error.
If the printing concern has not been rectified after completion of the above procedures, you may need to:
i. download and install HP Universal PostScript Print Driver; or
ii. consider using a wireless print server connected to the parallel port of the printer; or
iii.consider replacing your printer. Sorry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 12, 2008 | HP LaserJet IIp plus Printer
My HP LaserJet 6L Won't Print on new HP/Vista PC
Use any printer parallel 25pin convertor to USB cable and connect it to pc or notebook
Connect both ends from pc to 6L printer
Go to website to choose the correct O/S driver for installation
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=14974&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=18972&prodSeriesId=25476
Use virtual USB port005 for printer 6L
Bi-directional option can be ticked
Click apply and ok
Unplug and replug the USB cable
Try printing a test page,
I have tried it, the vista download drivers works on vista, no problems in printing at all, advise from http://www.bebo.com/andythoo
Jan 20, 2008 | HP LaserJet 6L Printer
Epson TM-T88#P thermal printer driver for windoze vista
You can use windows 2000 drivers on Vista for this printer, according to this article:
http://www.prophetline.com/node/141
Jan 14, 2008 | Epson TM-T88III Thermal Printer
Epson LQ 300+ Matrix Printer Logo
1,311 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
