Question about Epson Stylus Pro 9800 InkJet Printer
Epson 9800 wont print large images
My Epson 9800 is fine printing until I try to print large files. I am printing images 44 x 70 and sometime it prints but most of the time they wont and I have no idea why I'm having this problem. HELP!!!!
  • 483 Answers
make sure that the printer is not managing color by selecting "off (no color adjustment)" in the Printer Color Management option of the printer settings.
Could be a head clog, could be ink starvation, could be head overheating...
How old is it ... ?
Fame !
Posted on Jun 25, 2009
Getting message error 0001000C on Epson Stylus Pro 9800 right after is done printing. The next print after message (after i turn off and on the printer) appears with double image on some areas.
its a carriage home position sensor error u have to clean the sensor and the stip guide which has been attached on carriage... its due to dust on sensor.
Oct 17, 2013 | Epson Stylus Pro 9800 InkJet Printer
Maintenance code 4000 on epson 9800. Can't find
http://files.support.epson.com/pdf/pro78_/pro78_gd.pdf
Use the above link or send an email to LBrown18062@hotmail.com and I will send you the manual. Please put "Epson 9800" as the subject.
Apr 02, 2012 | Epson Office Equipment & Supplies
MY printer stopped working from on day to the next...the problem is when I print out a photo from IPhoto or Preview on my IMac OSX10.4.11 it starts with a large margin which doesn't allow for the complete...
Hello
Large photos are printed differently than regular photos.
Photos that have large resolutions or are best when printed in larger sizes are sometimes printed on multiple pages. Printing the photo on two or more pages requires setting up the printing options so that the printer recognizes how the photo should print and which areas to stop printing on each page.
Open the photo in iphoto
Select "File" and scroll down the list until reaching "Print". Click on "Print" and wait for the printing set up options. Some programs require selecting "Set up" or "Print set up" instead of "Print." Make sure the set up options are brought up according to the program.
Select "Time Imageable Table" or similar options in the program. If there is not an option with a similar title, look over the various titles and any pictures that come with the titles and see if the pictures show multiple pages or only a single page. Click on the options that allow printing one photo on multiple pages.
Select overlap options, which give margins so that connecting the pages forms the picture. Overlap around 1/2 inch or so.
Print the photo. The number of pages should match the set up options selected under the imageable table.
Nov 17, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
Will not print landscape.
Set your file up as a landscape, set your printer as portrait. Setup you width and height to be a half inch larger in each direction (unless you are doing borderless) and try with preview (so you dont waste time, ink & paper) see if this helps
Apr 27, 2009 | Epson Stylus Pro 9800 InkJet Printer
Faint one inch wide line appears at the same time, every time.
We've seen this problem in our shop. The document is "timing out" and the gap is where it restarts. You have to set the print manager to wait to print until the document is finished processing. Any large print will do the same thing. Try "pausing" the printer on your computer, then execute the "print" command in Photoshop, then go back to the printer control panel and "un-pausing" the printer.
Apr 06, 2009 | Epson Stylus Pro 9800 InkJet Printer
Problem Printing Sheet Paper with the Epson 9800
On the machines control panel set to sheet fed (pressing the left button will change from Sheet, roll and roll with cut). In the print settings select your paper profile. On the page setup choose sheet. In the pull down menu you should only have basic paper sizes, no custom size. choose 20x30 and try again.
let me know if this helps
Feb 02, 2009 | Epson Stylus Pro 9800 InkJet Printer
Epson pro 9800 wont print
Don't print out of illustrator it causes a lot of heartburn. put the art into indesign or Quark and print from the layout program. That has always solved the problem for us.
Nov 05, 2008 | Epson Stylus Pro 9800 InkJet Printer
Printing Borderless at 42" width?
Set the roll size to 44 inch, set your left margin to 0 (in your preprint software), experiment. With margins set at 0, using Onyx Productionhouse 7.3, the 9800 will print approx 41.8 inch image on 42 inch roll 43.8 on 44, etc. This is considered borderless printing. No matter what size roll you tell the printer it has in it, it will print to about an eighth to a sixteenth of an inch short of the paper's actual edge (that's the left side of the roll paper coming out of the printer - the right side of the print). If you load, for example, a 36 inch roll, tell the printer its a 44 inch roll, and send a 40 inch wide print, with a left margin of 0 it will print around 35.8 inches, cutting off the image just before it would overprint and get ink on the machine (1/8 - 1/16inch before the edge of your 36 inch stock). It is possible that these tollerances will be different depending on what software you send your images with... hope this helps!
May 08, 2008 | Epson Stylus Pro 9800 InkJet Printer
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
Epson Stylus Pro 9800 InkJet Printer Logo
155 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
