My Canon PIXMA MX700 will not print. It indicates Error code 6A80.
    Novelist:
  • 133 Answers
Here are the basic steps:
Did you try removing the cartridges and reinserting them back?
Did you see if there is any paper jam?
Is anything obstructing the cartridge movement?
If the printer is new then did you remove all the tapes?
How old are the cartridges and when was the last time you used the printer?
Turn off the printer, remove the power plug and press and hold the power button for 5 to 6 seconds and then replug and restart the printer again.. does it help?
Please let me know if that works.
Regards,
Srinivas
Posted on Jun 25, 2009
Error code 6A80, won't print after changing ink cartridge. printhead is all the way to left. Tried moving it manually and turning off and unplugging printer.
@font-face { font-family: "Times New Roman"; }@font-face { font-family: "Verdana"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0in 0in 0.0001pt; font-size: 14pt; font-family: Verdana; }table.MsoNormalTable { font-size: 10pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; }
Issue: ERROR LCD: Error Code 6A80
Solution #1: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the button again.
3. Wait until the device has completed its cycling process before submitting another job request.
Solution #2: Removing paper jams MX700
See very detailed description at this link:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx700#ServiceAndSupport
Jun 30, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I have a Canon MP550 and after pressing ON button in few seconfs appeares message: ERROR CODE 6A80
[6A80] & Light Blinking 12 times = APP Position Error. An error occurred in the APP motor. Maybe foreign material or paper debris around the PURGE UNIT (at the printer most right hand side) or Auto Sheet Feed area.
May 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I received an error code 6A80
Solution:
  • Switch the printer OFF
  • Press buttons 1 + 2 + 3 and 4 (simultaneously using four fingers)
  • Keep pressing this four buttons for 10 seconds
  • Release the On/Off button (number 4) (Keeping pressing the others)
  • After a few seconds (when the printer go ON), release buttons 1, 2, 3
Jan 31, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Error message 6a80 mx700 printer canon what is this?
Hello
Ok, the error code you are getting refers to a paper jam, which the paper is usually torn from the big piece and stuck, you need to have a good lok to find it.
Most probably the paper was ripped inside, and one piece is stuck somewhere on a sensor. Usualy is the purge unit that clean up the print head, and it's located inside on the right side (printhead parking place).
Take a torch, lift up the scanner unit, with the unit ON, wait for the print head to come in the middle, move it to left to make more room, and check the right side, inside the unit.
Kind regards
Andrea
Dec 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Thank you!
Nov 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
How do I re-set error 6A80? on my Canon PIXMA MX700 lcd display?
6A80 is APP position error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output)
is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.Check the sheet feeder.If this not help your printer need service.
Nov 01, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Service Error 6A80
That error says there is something jammed in either the purge assembly or the sheet feeder on the back not able to turn. The purge assembly is on the right where the printhead parks for cleaning.
Oct 29, 2009 | Canon PIXMA MP600 all-In-One InkJet...
MX700 ERROR 6A80
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Error 6A80 – means “AP position error”- indicates that "an error occurred in the APP motor during purging operation". Either the sheet feed unit, purge unit, or logic board could be at fault.
I'd recommend bringing the unit into your local canon authorized service facility for complete diagnostic and repair.
Hope this helps
Aug 08, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Error 6A80
Error 6A80 indicates that "an error occurred in the APP motor
May 22, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Cannon Mx700 error code 6a80.
It is because of Purge unit can be damaged or stuck. Probably you have to pulled apart the printer and check the purge unit.
Nov 27, 2008 | Canon PIXMA MX700 All-In-One InkJet...
42 people viewed this question
k24674
jasbo
jasbo
