Question about Canon Office Equipment & Supplies
Canon MP830 Scanning from ADF..paper stops halfway, hangs...
When scanning from the ADF with my Canon MP830, once the first page disappears into the machine, it stops and hangs, frozen. The LCD reads ''Scanning document.'' When I hit cancel on the MP Navigator box on the screen, MP Navigator hangs as well, and I have to Force Quit MP Navigator. I have tried restarting the computer and the printer to no avail. I also reinstalled the MP Navigator scanner driver (Mac).
    Problem Solver:
  • 3 Answers
I had been moving some furniture and I think I inadvertently knocked a usb cable loose. I also had it going to a hub that was possibly not working. when I made sure everything was hooked up correctly and directly, it was working fine again. I hope this helps someone.
Posted on Jun 25, 2009
I have a problem with my MP830 it is not scanning.
- Confirm the connection
- between the ADF motor and the ADF PWB, and
- between the ADF PWB and the logic board.
- Replace the
- document feed unit, or
- logic board.
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My mp830 prints and scans fine, but it won't scan dual side. it scans the first side, then starts to pull the paper back the other way, but it only goes a little ways (1-3") then the paper stops, like it...
Close the inner cover, and press the OK
button to clear the error. The paper being
printed at error occurrence will be ejected
without printing the remaining data for the
ejected paper, then printing will resume from
the next page.
Oct 11, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830 not scanning
It won't scan unless you have a program like picasso running on your computer to accept the scan. On the Canon you choose where you want the scanned image to go and if you choose the computer you need a program running to store or adjust the scanned image.
Jun 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
Scanner Canon 5010c
This is a known problem with the scanner. Use PixEdit to scan which comes around this problem so the scanning terminates OK after the ADF goes empty.
Dec 22, 2008 | Canon DR-5010C Path-Through Scanner
When scanning document stops halfway through ADF
Have you tried lowering the resolution of the scanned document?
Nov 04, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Scanning using Printer control
Did you install the full printer driver package?
The printer has to start the appropriate scanning SW on your PC.
Aug 13, 2008 | Canon PIXMA MP830 All-In-One InkJet...
ADF Usage
Put the paper in the automatic feeder. In the software options, click on ADF (automatic document feeder) and it will scan multiple pages.
Jun 06, 2008 | HP LaserJet 3030 All-In-One Printer
Scanning Legal Sized Documents
1. From the MP Navigator screen, select "Scan with Scanner Driver" in lower left corner.
2. When in ScanGear MP, select the Advanced Mode tab
3. At Input Settings, select Document (ADF) for document type
4. Set paper size in next window
5. Click Scan button at bottom
May 01, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Saying that paper is stuck
Open the back door under the rear feed-in slot and check for distorted paper there.
I reuse the backside of lots of paper so sometimes get it jambed up back there.
Jan 03, 2008 | Canon PIXMA MP830 All-In-One InkJet...
396 people viewed this question
old marine
old marine
