Question about Kenmore 63942 Dryer
Kenmore electric dryer 110.60712990 Series 70 heats but does not dry the clothes. A friend with a meter came over and said that there is 9.8 ohms resistance on the heating element. Is this within normal operating range?
  • 5,911 Answers
Your heating element is good. It should read between 9 to 13 ohms. If the heating circuits are working, then you don't have a problem with the heating circuits. The numbe ron cause of drye heat related problems, or longer dry times, is poorly installed, or clogged ventilation. A simple test to try is to remove the exhaust vent hose from the back of the dryer and attempt to dry a load of clothes as you normally would. The air escaping the exhaust should be forceful and warm (about 140 degrees).
If the air flow is normal, and your clothes dry normally, the problem is with your exhaust ducting from the point where it leaves your dryer to where it exits your home. I would recommend you inspect the entire length of your exhaust ventliation to make sure it is free of kinks or clogs if this is the case.
If the air flow is weak, then the problem is INTERNAL to the dryer. The most common source of the problem is a clog in the blower fan housing preventing air to flow properly. Remove the blower fan housing cover and clean as necessary. Make sure the blower fan can turn unobstructed.
Let me know if you still have problems. I hope this helps you.
Posted on Jun 25, 2009
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
My dryer is on but it wont dry my clothes
Start by checking that the exhaust pipe is not blocked. Without airflow drying will be very slow. If you have good airflow, then the next item to check is the heating element, which can be checked with an ohm meter.
Jan 02, 2012 | Kenmore Metro Dryers
Kenmore Dryer 70 series electric-quit heating and timer wont shut
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 24, 2017 | Kenmore Dryers
My Kenmore series 70 electric dryer isn't heating. Replace element, thermostats, ?
a heating element would be a likely cause however before you replace the element you should check to make sure that it is bad by using an ohm meter to check the element for continuity. if you take the element out of the machine you can usually visualy inspect it and see the broken wire.
May 29, 2010 | Kenmore 67632 Electric Dryer
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
Kenmore series 70 electric dryer will not heat up, but will rotate.
remove the back cover and check the heater box fuse and the heating element,do you have a meter?
May 10, 2009 | Dryers
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Not drying
is it electric?is the drum turning/are both your vent holes(wall&dryer)clear?mike
Mar 21, 2009 | Kenmore Dryers
My kenmore 70 series dryer will not dry clothes, but it does heat up inside and lets hot air out the dryer vent on the outside of the house.
make sure the dryer vent and the house vent are not clogged with lint this will slow down the drying process-mike
Mar 14, 2009 | Kenmore 62802 Electric Dryer
Kenmore 70 Series
You probably have an open thermal fuse, the dryer will run in some cases and not heat, Just moving air across you clothes will dry them however it takes forever.
If you are electrical or mechanical replace the thermal fuse yourself if not call someone you trust, you can purchase thermal fuses on line from Sears.com just do a parts search for you specific dryer.
Jun 04, 2008 | Dryers
Kenmore 63942 Dryer Logo
785 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
