Question about Sony XRC-5300X
Trying to use the rca inputs in the back of my sony xrc5300
Want to use the input to plug in and ipod using an rca to 1/8 inch cable but once plugged in I cant get the player to switch to that source.
  • 578 Answers
Hw old is the unit
Posted on Jun 26, 2009
Need to know what/how to play video player. Set it to AV with no results. Please advise...granddaughter is waiting. :)
if not already done connect rca cable with red white and yellow rca plugs to the rear of the dvd player,then plug the other end of the cable to the tv rca input of which there should be two sets 1 and 2
take note which set you use,now set the tv to match the video input to the number 1 or 2 .
using the remote select source then scroll up or down to av 1 or 2
don't forget to switch on the dvd player.
unles the dvd player is faulty you should be able to find the pic
good luck
Len...
Sep 13, 2014 | Televison & Video
Can i plug an ipod or mp3 to this system
By looking online I see there is a aux input for your system. Get a cable with a stereo mini plug on each end. This is the end you find on MP3 player headphones. Plug the cable in and choose Aux with your source button . You will have to turn up your volume on the mp3 player some, maybe half way....and could be higher depending on the unit. The RCA volume must be used also, set it to at least 25% and give it a try. Adjust MP3 player input down as needed.
Nov 12, 2013 | RCA RTD317W Theater System
Will this receiver accomodate an iPod player? Thanks, Byron Nimocks
It may not take the iPod directly if it doesn't have a dock built in, but you can always connect the iPod to an available input with a suitable cable. You'll need a cable with a plug to fit the iPod headphone jack (a 1/8-inch stereo plug) at one end, and probably RCA plugs at the receiver end. Radio Shack sells one so you can see what you're looking for. If you have an iPod dock, they often have audio output jacks for connecting to your receiver. You may need a cable with RCA plugs on both ends.
Aug 07, 2011 | Integra DTR-5.1 Receiver
How do i connect an ipod to my sony str-de310 receiver
Connecting to a home stereo
  1. For most home stereo systems, connect iPod to your amplifier's sound input using a 3.5 mm mini stereo to RCA adapter cable.
  2. Adjust the volume on iPod to less than half to prevent overdriving your amplifier. Adjust the listening volume using your stereo's controls.
    Note: Depending on your stereo, iPod may need to be set higher than half in order to get a proper volume through external speakers.
http://support.apple.com/kb/ht2167
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 12, 2011 | Sony STR-DE310
How do i hook up an ipod to a denon dra-685?
you can use a 1/8 inch female to stereo RCA adapter and plug the patch cable into one of your inputs like DVD or CD player. The signal to noise ratio on those inputs is pretty good.
Feb 03, 2010 | Denon DRA-685 Receiver
Is there any way i can connect an ipod to my ELan Viadj system?
There should be two RCA input jacks, (L & R), for audio input on the Elan. Use a cable with an 1/8 inch plug on one end that splits to two RCA plugs. Plug the 1/8 plug into the earphones jack and the RCA plugs into the audio input RCA jacks on the Elan. Set the iPod volume low so you won't distort the input signal.
Aug 01, 2009 | Audio Players & Recorders
Ipod vido out
Using the iPod AV Cable
Step 11Use the Apple iPod AV cable. This plugs into the RCA ports on your TV or VCR. This is by far the easiest method. Step 22Connect the AV cable into your iPod. Plug the small end into the iPod where the earbuds would go. Step 33Connect the red RCA plug. This goes into the right audio input of the television or VCR. The colors should match. Step 44Connect the white RCA plug. This plugs into the left audio input of your TV. Connect the yellow RCA plug. This goes into the video input of your TV. Step 55Begin playing a video on the iPod.
May 27, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod hookup
I believe that you are lucky since the "P" in the model number of the deck indicates and extra input source on the rear of your deck. This is used right now by your changer. You need to replace the changer with the Ipod and you are done. Stereo mini to dual rca's and you are done.
Sep 26, 2007 | Pioneer DEH-P5200 CD Player
Ipod Connection through RCA Cable
Actually, what I think gbaity is doing is utilizing his IP(Interactive Pioneer)-Bus port in the back of the DEH-P3000, which is an input port designed to allow the deck to use an external multi-disk CD changer. All you need is the CD changer, then change the input source from your deck to "M-CD". There are folks on eBay and other places that sell a cable that pluggs into that very same port. They are designed to allow the unit to accept input through the IP-Bus from an ipod or just about any low-level input that you can pass through the RCA jacks. I have the same deck, and also just purchased an ipod cable for the IP-Bus, and it also does not work. I have been told that I need to switch the "M-CD" input source to "AUX" as the input, but I do not know how to do that. pressing the input source button only displays "CD", "M-CD", and "FM/AM". Does anyone know how to add "AUX" to the choices or otherwise show us how to make these cables work? Thanks - TomR
Aug 23, 2007 | Pioneer DEH-P3000 CD Player
Auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Mar 15, 2007 | Alpine CDA-7892 CD Player
Sony XRC-5300X Logo
79 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
