Question about HP LC3760N 37 in. LCD HDTV
Tv (LC3760N) shut off blinking power light will not turn on
Will not turn on from remote nor manual from tv. unplugged for extended period of time still nothing. any suggestions.
    Scholar:
  • 44 Answers
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
Why is my Samsung ln-t1953h takes 5-10 minutes to power on. During boot the red light is blinking and clicking.
How old is the tv set also do you have it plugged up to a power cord? Can you tell me how many times does the light blink thank you.
Aug 19, 2014 | Samsung LN-T1953H 19 in. LCD HDTV
My tv wont turn on by power button or remote. white light keep blinking.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
Sony trinitron wont turn on
These sets usually if do not turn on will have the power light blink a sequence--7 blinks, pause 7 blinks etc.
A model number would help here.
Apr 09, 2012 | Televison & Video
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
My 42" Phillips Tv will no longer turn on. The power light continues to blink in red and when unplugged and plugged back in it almost acts as though it will turn on again but goes back into turn off mode...
you have a bad power supply, and the tv goes to protect mode, undo the back and look for any bulged or open cap, and replace it.
Fosg2000, please rate me
Mar 17, 2010 | HP LC3760N 37 in. LCD HDTV
LC3760N power light blinks
Replace the whole board,LCD usally the IC is dead,not like DLP the capacitors,burn most of the time.
Sep 22, 2009 | HP LC3760N 37 in. LCD HDTV
TV won't turn on
read from other forum. wouldn't hurt to try, unplug the power for 2 days and plug back in again to see if it will turn on.
Mar 10, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
TV auto shut off-power indicator light blinking-won't turn back on
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
Jan 11, 2006 | Toshiba 43H70 43" Rear Projection...
HP LC3760N 37 in. LCD HDTV Logo
4,073 people viewed this question
Top HP Televison & Video Experts
Computer Links
vbalag
Level 1 Expert
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
