Question about Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM, 60 PSI, 12 Volt
I have a Fimco 2.1 gpm pump that worked fine last week. I ran it until it didn't spray anymore. This week the motor runs but it seems to have lost its prime,it won't pump.Any ideas? The filter is clean. No trash got to the pump. It has a gauge and this week it reads nothing with the motor running.
    Problem Solver:
  • 3 Answers
There is an o-ring inside that has popped out of place and it's letting the pump recirculate within itself. I had the same problem. I took the pump apart found the out of place o-ring and put it back. primes with no problem now.
Posted on Jun 30, 2009
    Problem Solver:
  • 6 Answers
Clean the checkvalve in the pump with dish soap, and a toothbrush. scrub thoroughly and rinse off. replace and see if that works!
Posted on Aug 21, 2009
I don't think that these pumps run dry very well ... most likely you ruptured a diaphragm by running it dry. How long did it run dry? ... take it apart and see if the diaphragm or valves are damaged. You will need to replace them before the pump will work.
Posted on Jun 28, 2009
Pump sprayer has no suction
We have the exact same sprayer 2.1 GPM for our FIMCO and the engine runs but it will not suction. This happened once before last year and because it was under warranty they replaced it. Now it is happening again but FIMCO will not stand by this part because they don't "Warranty their warrenties.". What a bunch of ****! Stand by your products for pete's sake!!! If anyone has any solutions or ideas it would help us out a lot!
Apr 14, 2012 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
I have a 15 gallon Fimco trailer sprayer. Last
Bleach gives off corrosive vapors, so the internal parts of the pump may have corroded over time. Least expensive fix is to disassemble the pump, find and replace any corroded parts, but you'll be tinkering for a day and it may not be repairable anyway. More expensive but faster is to replace the pump - check the GPM rating and find it here for about $60 - $100. Good luck!
Jul 05, 2010 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Not much pressure on fimco 15 gallon sprayer - purchased new 2.1 gpm motor - it sprays but not a lot comes out - seems not much pressure - Thanks.
Is it possible that the pick-up tube inside the sprayer is clogged up, or the hose it damaged? Maybe dirt in the spray handle/wand?
Oct 26, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Insufficient Pressure From Pump
Take the strainer at the end of the hose on the tank off. Throughly clean it. I used an old tooth brush, then ran hot water through it several times. Also drained the tank and flushed it out 3-4 times with fresh water, then ran fresh water through the pump for several minutes
Hope this helps
Aug 03, 2009 | Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45...
Pump has no pressure
scrub up the check valve within the pump really well, that should help restore the prime! use dish soap and a toothbrush!
Jun 30, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Fimco 15 gal sprayer has lost prime
There is an o-ring inside that is probably bad. I tore my pump apart and found it and repaired it. My sprayer was about two years old as well.
Jun 29, 2009 | Fimco On Demand 12 Volt 1.0 Gpm Pump
I have a fimco pump on a 25 gallon sprayer. It is a 2.1 gallon per min. pump. I took it out yesterday to use and it would not pump up, no pressure. Worked fine last year. I checked and the motor is...
open up the pump, take out the check valve. wash in dish soap/hot water solution, scrub with old toothbrush, rinse off, reinstall & see if that makes a difference...
Apr 29, 2009 | Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45...
Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM, 60 PSI, 12 Volt Logo
903 people viewed this question
Top Fimco Garden Experts
lnbn1975
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Are you a Fimco Garden Expert? Answer questions, earn points and help others
