Question about Goodman CLJ36AR42 Air Conditioner
Air condition not blowing cold air - Goodman CLJ36AR42 Air Conditioner
  • 92 Answers
Large copper line coming from outdoor unit should be cold,If not you need recharge or compresser is turning on.
Posted on Jun 25, 2009
Air conditioning system, when you turn on the air conditioner the drivers side blows cold air and the passengers side blows hot air? What causes this problem?
The most common cause of this is that you have a stuck air temperature control blend door, this can be a motor actuator issue or a jammed door or both (common). To replace both parts you will need to completely remove the dash from the car to access the blend door.
Jul 02, 2016 | 2010 Ford Flex Limited
My air condition only blows out cold air not hot
Turn your air conditioner OFF and turn your heater ON. Air conditioners were designed to blow out one temperature of air... COLD.
Nov 13, 2014 | 2004 Mercury Grand Marquis
2002 gmc safari van defrost blow cold, a/c blow out of defrost
open the hood and check for leak on any plastic vacuum lines.
Oct 19, 2012 | 2002 GMC Safari
Air conditioning blows hot and cold air
You will need to know if the compressor is working when it blows hot air to proceed. It could be an electrical problem, a blend door problem, or the a/c clutch on the compressor.
Jul 02, 2012 | 1999 Honda Civic
I have a 1999 323i BMW. The AC doesnt blow cold (on cool days it blows cool temperature but not common A/C Cold Air, Hot Days it blows Warm/Hot Air). The heater blows warm air but definitely not common...
First things first.....You must have the air conditioning system hooked up to an a/c system machine and then checked for leaks and also read low and high side pressures. If there are leaks then low Freon (R134a) content and low refrigerant oil can cause the a/c system to not engage the a/c compressor which basically means you will not have proper defrost functionality nor regular air conditioning. Most shops, when working with your air conditioning, will install air conditioning dye to assist them in locating leaks and is the first step in diagnosing all a/c systems. Post the findings after thw
Jan 21, 2018 | 1999 BMW 323 Series
The air conditioning system will only blow cold air. Regardless of the mode, I can only get cold air. Can you give me an idea on how to fix the problem? Thanks Don 615-653-3834 drcamp117@comcast.net
The air conditioning is supposed to blow only cold air. Are you trying to get the heater to blow hot air? Make sure the temperature selector is in the hot position.
Dec 19, 2010 | 2002 Buick LeSabre
Air condition won't blow cold
Clogged ORFICE TUBE and or Low Freon Level.
Jun 04, 2010 | 1998 Plymouth Breeze
Air conditioning does not blow cold air all the time
your high pressure switch is faulty. the part is about 50$
May 12, 2009 | 1998 Nissan Altima
Not blowing cold air
check the folowing reason of no air flow
-thermostat
- the selector switch
- wiring
-fan motor capacitor
- fan motor
Apr 26, 2009 | Heating & Cooling
Goodman CLJ36AR42 Air Conditioner Logo
278 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
