Question about Technics SL-BD22 Turntable
Turntable grinds to a halt.
I have a Technics turntable that I've owned from new since 1996. It's had very little use over the years. Now when using the turntable to copy vinyl to the computer, it has started grinding to a halt shortly after starting to play an album, & now will not start at all.
Any thoughts on what the problem may be & is it worth repairing ?
  • 382 Answers
Re: Turntable grinds to a halt.
The Technics SL-BD22 is a belt driven turntable. It is most likely possible that the belt wore off, wore down, or could have spun off. The platter should have 2 holes in it. One of them should alow you to see, and replace the belt. YOu can lift the platter off the turntable via those two holes. MAKE SURE IT IS TURNED OFF AND UNPLUGGED......
You can find a replacement @
And the part should come with instructions. Those guys are very thorough.
Keep me posted.
Posted on Nov 05, 2007
0 characters
3 Points
Technics sl d1 buzz
Turntable needs to be earthed to amp. Cheers john. Styluscity
Apr 19, 2012 | Technics Turntables
Technics sl dz 1200 no vinyl play
is anybody have solution for this? i have the same prob...
Apr 11, 2012 | Panasonic Technics SL-DZ1200 Turntable
I've just set up my Technics SL D212 turntable after moving house. It keeps skidding across records. I've tried the usual adjustments and leveled the turntable. Any clues?
Please make 100% certain the needle is still in place... To test this *GENTLY* rub your fingertip over it and you should hear noise from the speakers when you do. If there is NO noise then there is likely no needle.
Did you put the protective device on the needle/arm for the move? Is it still on there?
Sorry Mate, that the only thing I've got to help....
Feb 20, 2012 | Technics Turntables
After 14 years my Technics SL-BD22 Turntable has a disfunction The electric motor turns slow.
Your turntable is probably belt driven so most likely motor is turning okay but belt is slipping.
They are easy to change, first just lift rubber mat on platter and you should be able to see the belt through a access hole in the platter.
Feb 28, 2011 | Technics SL-BD22 Turntable
I just purchases a Technics 1200 turntable for $70.00. I have found a problem, at the end of the album, the arm does not auto return, but just stays on the album. Could this be a simple problem,...
First off, Congratulations on such a excellent deal! That's a $500.00 turntable. I know I own a pair and I've been a DJ for 18 years.
Second, the Technics 1200 does not have an auto return. You have to pick up the needle and bring it back manually.
Feb 03, 2011 | Technics SL-1200 Turntable
Technics SL-BD22 Turntable Logo
211 people viewed this question
Top Technics Turntables Experts
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Turntable Expert? Answer questions, earn points and help others
