Question about Refrigerators
Maytag msd2652keu side by side compressor gets hot shuts off and unthaws freezer i unplug 4 a few hours plug in and works 4 a couple weeks any idea
  • Refrigerators Master
  • 4,655 Answers
There are several possibilities. Start Capacitor, start relay or the compressor winding or compressor is defective. I would have someone have a look at these soon. Sea Breeze
Posted on Jun 25, 2009
  • 58 Answers
Check to make sure condenser fan is working (this is the fan located near the compressor). It should be running at the same time the compressor is running. If it isn't, make sure there is power to it by testing with a voltmeter. If there is, replace the fan. If the condenser fan is working, clean the coils and check the evap fan.
One Big Freezer.
Thermostat is the likely problem. Not seeing the correct temperature.
Mar 10, 2014 | Samsung Refrigerators
My Maytag model msd2657hes will run perfectly (other than a slight buzz) and then **** off. Have to unplug it for a few hours and then plug it back up and it will work fine for days or maybe even 2 or 3...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 15, 2011 | Maytag MSD2655HES Side by Side...
My GE side by side refrigerator stopped working, then the freezer stopped I unplugged it for 2 hrs plugged it back in and everything seems fine now. I had a repairman look at it and I was told the...
Many (but certainly not all) refrigerators have a Defrost Timer. Google this item and you will find thousands of entries. This timer effectively does what you did by unplugging it for a couple of hours. If Ice forms, it is likely that your compressor is fine or at least working well enough to create ice in the back of the freezer. A very inexpensive way to see if this is your problem is to plug your refrigerator into a 24 hour programmable timer with 22 1/2 hours ON and 1 1/2 hours OFF (set this for 2AM or so when you are not using the refrigerator). If everything is fine after 3 or 4 weeks, then order the timer for your refrigerator. There are MANY google entries which will help you test your timer if you have a multimeter or know someone who does and knows how to use it.
Oct 28, 2009 | Refrigerators
Freezer works frige dont unplug for an hour then it works .
I would suggest check the coils to make sure they are clean . Also check the fan which cools the compressor to make sure it is working . When you unplug , it gives the compressor time to cool down a bit , but after it restarts , it will get hot again and stop cooling .
Jul 06, 2009 | Refrigerators
Freezer is not freezing on Maytag MZD2766GES
When you lay a refrigerator on its side oil from the compressor can seep out into the tubing and cause a restriction in the sealed system. This will cause only a small amount of cooling to occur and needs a licensed technician to fix it.
May 24, 2009 | Maytag MZD2766GES Side by Side...
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Maytag side by side slowly getting warmer
YOU ARE BE GETTING A WEEK COMPRESSOR.
Jun 09, 2008 | Refrigerators
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
