Question about Epson Stylus cx7450 All-In-One InkJet Printer
I need to print in colour only!
I have no black ink and I need something printed urgently for tomorrow. How do I print in colour only?
  • 297 Answers
In Epson CX series you cant make a print even if one cartridge is empty :( . I suffered from this issue many times!
Posted on Jun 25, 2009
I have replaced the black ink cartridge in my Kodak ESP5210, I only need to print in black, now the colour has run out which I don't need (the original cartridge). I have tried taking out the colour...
go to printer & fax right click on the printer then select maintenance look for the cartridges in (default both cartridges will be detected) you must select only black then close it then try to print
Aug 03, 2011 | Office Equipment & Supplies
Printer is printing the black color as light grey. Toner is already exchanged.
When you print something from a website and the print box comes up, click on preferences tab, and when it comes up click on color . Then click on print in grayscale and change the setting from High Quality to Black ink only, click apply at the bottom, then OK. It should print in black ink.
Jan 11, 2011 | Laser Phaser 6125 Colour XEROX Phaser...
Ink cartidges are all installed and registering ok. New balck ink installed but will only print in colour and not black print what can I do as I need docs printed urgently?
Does it take (pull up the paper) in the paper? If so, Try to print only images and check if it works or not. It'll be much easier if you let us know the program from which you are printing. Also try to print only in text using Ms Word, wordpad or notepad. If possible update your driver. Good luck.
May 26, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Want to print only in black
search through your manual for grayscale options... this is usually code word for black and white...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 21, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I have just fitted new cartridges although it was only the colour one which needed renewing I thought! However it wuld only print out in red/pink shades so I changed the black cartridge to be on the safe...
I have personally encountered similar problem in my work. There is no problem with your printer, No need to go to your suppliers yet.
Sometimes when either of the inks overflow at the nuzzle, it gets absorbed to an extent into another ink compartment. So that colour affected now prints another colour; the colour that has crept into its compartment, Sometimes it is serious at other times is not. If not serious, usually, after a few solid colour prints the colour affected returns to normal.
I do not know how much of a technical person you are, but I will give you the solution to returning that yellow printing red back to printing truly yellow. Bring out your colour cartridge. Peel off the seal covering top. You will see the holes through which in is fed into it. Get a clean handkerchief, fold it and place over the top of the cartridge. Hold it over a bowl or something. Now place your mouth over the top with the handkerchief in between and blow hard. Ink will discharged at the nuzzle. Clean off the ink. (At the nuzzle do not rub only dab). Now press a piece of folded tissue to the nuzzle firmly. It should be blotted with ink:- red, blue, yellow. If any colour is missing you may need to repeat the procedure. Once you get the three colours back, the issue is resolved.
Dec 06, 2009 | HP PSC 2355 All-In-One InkJet Printer
Canon MP360 not printing
You probably need a new purge assembly, it draws some ink to both clean and prime the printhead. When it stops working you won't get any ink to the paper.
Jul 19, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Have changed Ink Black and Colour... Stil getting error Message.
Make sure the tape covering the hole on the bottom of the black cartridge is removed. and then go into the printers folder and right click on your printer icon and go into the properties of that printer and there should be something in there to tell it that you changed cartridges and you can also print a test page as well.
Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I need to print a document urgently
Go into Printer properties and select the option to print colors as black/gray
Feb 02, 2009 | Epson Stylus Photo R340 InkJet Printer
Epson Stylus cx7450 All-In-One InkJet Printer Logo
120 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
