Question about GE Spacemaker JVM1640SJ Microwave Oven
What is the part number for the turntable rotating motor or name.
(GE Spacemaker) I have been trying to purchase a new motor but not sure what to ask for.
  • 5,911 Answers
If the model number is correct, go to appliancepartspros.com and use the "Search by Model Numnber" feature. The turntable motor is located as item number 43 (part number AP3205582) under the Interior Parts (1) section. I hope this helps you.
Posted on Jun 25, 2009
Why wont my GE Spacemaker JVM1650 turntable wont work?
replace the turntable synchronous motor
look to ebay search for
ge jvm1650
then add turntable motor or browse down youll find a new motor
the coils inside may be duff
Aug 12, 2014 | GE Profile Spacemaker Over-the-Range...
GE Profile Spacemaker XL1800 microwave turntable
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
On some, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 28, 2013 | GE WB26X10037 Microwave Stirrer Motor
My GE 1800 microwave turntable has stopped turning
There is a motor underneath the microwave that rotates the turntable. The motor may not be getting power or the motor may have failed.
Feb 11, 2013 | GE Profile Over the RanMicrowave....
The turntable on my GE Spacemaker Microwave JVM1640BB does not turn.... I can turn it by hand, but does not turn during cooking.
HELLO.
The turntable is the unit in the center of a microwave that you set your food on. It rotates during the microwave cycle, making sure all parts of a dish are properly heated. These are typically made of either hard glass or microwave-safe plastic.
Your microwave turntable may not turn due to one of these problems explain below
(1)If your turntable is removable (as many are for cleaning purposes), it may have come loose from this turning mechanism.place the turntable properl on the turning mechanism.
(2)If your turntable was previously working and now does not any longer, check the settings on your microwave's LCD display to make sure you haven't accidentally turned off the turntable.
Most microwaves have different settings that the user can select with the press of a button, like a "Defrost" setting or a "Popcorn" setting. Certain microwaves may stop the turntable from turning during certain pre-programmed selection modes. Stop your microwave and don't use a pre-programmed mode. Instead, just specify the time using the number pads and start your microwave to see if your turntable begins to rotate again.
(3)The rotating mechanism on the inside of your microwave that rotates the turntable is actually connected to a small motor on the inside of your microwave's case. If this motor burns out or stops working, the mechanism will stop turning. This is something that needs to be replace.
FOLLOW THESE STEPS TO REPLACE THE FAULTY MOTOR.
THINGS NEEDED.
* screwdrivers
* replacement motor
* specific microwave information and part number
1 Open the microwave door, and carefully remove the turntable tray. Also, remove the frame that the turntable is positioned on. Both the turntable and the frame are not secured in the oven, so removing them is a quick process.
2 Remove the bottom panel of the microwave. The Microwave Wizard website explains that the number of screws securing the panel varies depending on the manufacturer and specific microwave. Once the bottom panel is loosened, disconnect its wiring harness in order to completely remove the panel.
3 Locate the turntable motor. The Microwave Wizard website explains that the motor compartment should be positioned below the center of the microwave. Unscrew the motor, disconnect the wires, and remove it from the microwave.
4 Determine the specific part number for the turntable motor so that a correct replacement can be purchased or ordered. Position the new motor into the shaft in the bottom of the microwave. Screw the motor securely into place.
5 Test the microwave to make sure that the turntable motor is operating correctly. The Microwave Wizard website explains that the motor can make noises if it was not positioned evenly in the shaft. Reconnect all of the wires that were detached when removing the old motor.
6 Reinstall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Hoping to help on more problems.
THANKS.
Sep 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker microwave turntable
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave turntable motor or belt?
I assume you don't have an illustrated parts list try and Google one up using make and model number etc. It is also a good guide on what needt to be removed and in what sequence.
As far as the novice part, the turntable is a basket case now what can you hurt, this is how we all learned, try to fix it if you cant then call someone who can, not a big deal.
Feb 28, 2009 | GE XL1800 1100 Watts Microwave Oven
Turntable doesn't rotate
If yours is not set to be "off" via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
If yours is a GE, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Please write back with your brand and model number if you need further help.
Aug 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable not rotating
I fixed my own GE turntable by replacing the motor. You can purchase the part (#WB26X10135) directly from GE for $34.75 plus tax and shipping ($8.95) or from RepairClinic.com for $24.90 plus shipping ($6.46) and no sales tax except for delivery in Michigan.
The part is easy to install. Just print out this drawing to see where it goes (look for part 43) underneath the unit. Of course, be sure you unplug the oven first!
Hope this helps!
Aug 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker xl microwave oven turntable
If yours is a GE, there should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
GE Profile Spacemaker Microwave - JVM1660BBC
The turntable has a small motor underneath it that rotates the glass tray. You could have a motor that is going bad, or the plastic spindle (what the glass plate sits on) could be slipping. You can access the motor through the bottom panel. Be careful to make sure the microwave is unplugged for attempting any repairs inside. There is potentially as much as 14,000 volts in the high voltage network around the magnetron. Let me know if this helps.
Jun 27, 2007 | GE JES1039 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
143 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
