Question about Acer Aspire M3100 Refurbished Desktop PC - AMD Athlon X2 5600+ 2.8GHz, 3GB DDR2, 500 SATA, DVDRW, Fl
The sound isn't going through the speaker's - Acer Aspire M3100 Refurbished Desktop PC - AMD Athlon X2 5600+ 2.8GHz, 3GB DDR2, 500 SATA, DVDRW, Fl
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 162 Answers
I give you the one solution you first check that the lead is fully pluged and the sound driver is installed in your computer and if not then install sound driver for sound it's really works try this if any error occured conatct me at arpit.jain68@yahoo.com ok
Posted on Jun 25, 2009
Sound card
Hi check if your sound isn't muted in the system. Go to properties of your sound card and see if the volume level is not down there and check also levels for waves and don't forgot check speakers it self. A there powered ? Are you using correct jack hole for signal out ? If you need more help let me know
Oct 11, 2012 | eMachines T3616 Desktop PC
I don't have sound on my computer yet i have installed sound drivers and they are working well?
check in your control panel and go to systems.
Then go to hardware and under that go to Device Manager
In there see if there are any exclamation marks in your sound hardware,
conflicts and such.
If there are none then go to Sound Controls in Audio Devices and make sure the audio isn't muted in the windows program
Use this to do an audio test of your speakers.
If that isn't working but it should be check your wires to see if there is a break or if it is plugged into the the green colored jack for external speakers.
Jul 31, 2012 | Creative Labs Sound Blaster Live! 5.1...
Can't get sound out of my speakers although sound registers as playing
Check that your computer isn't muted and the volume on the speakers is up. Check that the plug for the speakers is connected correctly. Check to see if the sound card that the speakers are plugged into is set as the default in the control panel. Is there any sound coming out of the front port (earphones). Try another set of speakers.
Jun 06, 2012 | Computers & Internet
I have my speakers pluged in probily but the sound isn't working
chek the power suply connection 9light on)
chek the vol on the speakers
chek the vol on the computer
try to connect them on another computer that have other speakers that are working
bernard
http://www.rylwy.com/
Feb 10, 2012 | Dell A215 Computer Speakers
I turned on my t.v. and there was no sound
First thing, make sure the mute feature isn't on. If it is not, go to menu and look for a feature that lets you choose whether you can use external speakers or internal speakers. Some newer sets have this option. If your set has this option, make sure your internal speakers are turned on. If this isn't the case, you could have fault in the 12vdc/15vdc section of your power supply board or on the mainboard of the set.
Sep 24, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
MY SPEAKERS ISN'T WORKING DELL INSPIRON N5010
hi, check yr sound driver in system properties, look at your sound driver, if have yellow exclamation mark that mean your need to reinstall yr sound driver,
if not try use external speakers and see what result
TQ
Aug 05, 2011 | Dell Audio Players & Recorders
External speaker do not work
Follow these steps: Go to the Control Panel > Hardware and Sound > Sound > Manage Audio Devices under the Playback tab, select "Speakers" or any playback device listed. double click the device or click Properties. Go to Levels tab. Under the "Speakers" and "PC Speaker" area, adjust the volume level to its maximum. Then apply changes.
If the above instructions wont work, try this out:
Check if your speaker is detected when you plug it in.
If it isn't detected then either your sound drive has a problem/missing or maybe somethings wrong with your computer's headphone/speaker jack.
If detected, set it as your default device.
Hope it helped! :)
Jul 27, 2011 | Computers & Internet
Can't turn off internal speakers when i have external speakers connected via headphone socket
First, check if you put the connector for external speakers all the way to the end. Sometimes when the connector isn't fully inside both internal and external speakers will work. After you do that, once you connect the external speakers, go to the sound settings in windows and look for the volume mixer. You can regulate the sound for each type of speaker there.
May 04, 2011 | Computers & Internet
No sound coming from both speaker
There are several things that could be wrong:
Your speakers are broken
Your speakers are not turned on
The sound cable is plugged into the wrong jack
The speakers are muted in Windows
The sound drivers are not installed or are corrupt.
Your sound card is bad.
Lots to think about. First ask if your speakers were working. If so, when?
Try a system restore back to when they were working. That should fix it. IF not, proceed:
Go into the control panel and click on sounds.
Select system sounds, choose a Windows event that has a sound assigned and try to preview it. If the preview arrow is grayed out, then the sound drivers are at fault. If you have a black arrow and you click on it and it seems like it's playing, then check for mechanical problems.
If Windows thinks it's playing and it isn't, the system restore thing should fix it. Or try another set of speakers to see if your speakers have failed.
Apr 17, 2011 | Computers & Internet
Problem with right rear speaker outlet
These are fairly pricy speakers and I would hesitate before recommending you buy them UNLESS they are dirt cheap, like $40 or less. Odds are good that the issue is related to mechanical wear like defective wiring, a jack, where the cable connects to the speakers or even a worn volume switch. The problem is that if it winds up being a defective amplifier or volume switch then your deal becomes less of one. Replacing a volume switch isn?t too hard but finding a suitable part and installing is will take some time. If that isn?t the problem then you?re left with the built-in amplifier which is not typically repairable by the average home user. Hope that helps.
Jan 30, 2007 | Logitech Z-5500 Computer Speakers
Acer Aspire M3100 Refurbished Desktop PC - AMD Athlon X2 5600+ 2.8GHz, 3GB DDR2, 500 SATA, DVDRW, Fl  Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
