Question about Hitachi 42HDS69 42 in. Plasma Television
Gateway 42 inch plasma p42m303 6 blinks on power supply
Gateway 42 inch plasma m303 6 blinks on power supply does anyone know this fault code?
    Scholar:
  • 44 Answers
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
TH 42PV8H A MY TV POWER NOT ON RED LED 2 TIME BLINKS
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Mar 16, 2016 | Panasonic TH-42PV8H 42 inch MultiSystem...
I have a 2002 42 inch Plasma made by Gateway I can power up but tv clicks back off without ever showing a picture-the green power light remains on but no sound no pic-I used to be able to unplug and p
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to plasma screen are given with illustrations. You can get an idea about the fault to an extent. It is not easy to include all here by this window.
Dec 04, 2014 | Gateway GTW-P42M303 42 in. Plasma...
TC-P42ST30 power light blinks twice,replaced power supply board,no change.What to replace next?
Are you SURE you get 2 blinks? I show NO 2 blink code in the 011 model Pana plasma sets. Anyway...if you replaced the PS board and still get a code, unload the VS supply from the SC board and re-check--see if the VS supply comes up--even for a couple of seconds...about 205 volts or so. If it does--re-connect and see if it then does not come up. If not--then the SC board is likely bad (THE most common failure on ANY plasma set is the Scan board ).
Nov 24, 2014 | Panasonic VIERA TC-P42ST30 42-Inch 1080p...
I accidentally overheated my Panasonic Plasma TV TH-42PZ700U. It won't turn on, and the power button blinks TEN times.
Check and see if there are any blown caps on the power supply. If there are replace them or change your power supply.
Thank you
Mar 20, 2012 | Panasonic TH-42PZ700U 42 in. Plasma...
Help my 42 inch panansonic plasma tv will not turn on red light just blinks
Hi:
Replace or have the power supply serviced, the most common failure with panasonic plasmas is tthe power supply.
Dec 23, 2010 | Panasonic TH-42PZ700U 42 in. Plasma...
Plasma tv th-42pd50u not come on and keep blinking red light two times and then stop again blinking red light two times and then stop not come on
The light blinking twice means there is a fault within the system and it is a code to tell Panasonic where roughly the fault lies.
Go to Panasonic's web site and look for your set then input the fault code and hopefully they will tell you where the fault lies.
Oct 16, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
No power to my Phillips 42 inch Plasma 42pf7321d/37, just a red blinking light
Most likely it going to be a power supply related problem. The red blinking light is a code for a TV tech to diagnose the problem on the power supply board itself or the board that regulates the power for the screen. Some manufactures call it a Backlight Inverter Board. A TV repair shop should be able to look at it for you and tell you which board is bad.
Replacement boards can be found at a good price at Shopjimmy.com
Sep 05, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
SONY - PFM-500A2WE 16:9 42-inch Plasma fault 22-12
The error code tyo which you refer was truncated off of your posting. Could you please enter that code again? That code will assist us in determining the problem circuit.
Thanks,
Dan
Feb 09, 2009 | Sony PFM-500A2W 42 in. Television
Y SUS Board for a gateway 42" m303
if you check the 15v pin on the board You probably will find the 15v shorted to about 5ohms and one of the two large units on the board is shorted 4921QP1002B. I myself am looking for that part. If you bought a new board can I get Your board for parts?
Mar 06, 2008 | Gateway GTW-P42M303 42 in. Plasma...
Gateway Plasma 42" TV
my 5 yr. old 50 inch plasma hd that i paid almost $7000 for started flashing for afew sec. when first turned on.progresivly got worse,flashed for about 30 min. then ok until turned off.after about a month power light comes on fans start then trips off. gateway phone 888 737 6949 wants $250 for power supply $330 for video?board $600 plus for other boards no guarantees.i fixed mine by spending $1000 for a new vizio 50 inch plasma hd.if anyone wants a free dead gateway email me,
archie
Mar 02, 2008 | Gateway GTW-P42M303 42 in. Plasma...
Hitachi 42HDS69 42 in. Plasma Television Logo
369 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
