Question about Hitachi 51SWX20B 51" Rear Projection Television
No pitcure hitachi 51swx20b
Hitachi m# 51swx20b
dont know if happend by qoincidence but i used my cell phone for a light to hook up some cables for dvd and at the same time heard a clicking sound and now no pic have power .
The diode led / diode GREEN is flahing d967 - d940 TOWARDS FRONT OF SCREEN ON CURCUIT BOARD its the middle boars of the 3 . and the same for the RED led / diode d912 - d915. this one next to I902 located in the back of the board.
is this a simple replace these 2 parts or just a where to trace down warning o\f some kind?
  • 308 Answers
SOURCE: Hitachi 50ux58b
It's possible that the Convergence IC's are causing a shutdown of the power supply. Also on this model, there have been problems with: C707 - 1000pf @ 2kv Cermaic Disc Cap (normally a small blue one) Hitachi Part # 0244211. I901 - A STRM6811a Reg Ic and E994 - 2.0 Amp Circuit Protector (Pico Fuse) having a high failure rate. If the 2 amp pico fuse was good, and the capacitor looked OK, then I would check the convergence circuit board. There are many other parts that can also cause shutdown problems, however.
Posted on Jan 03, 2007
Slinteriors
  • 8617 Answers
SOURCE: Hitachi 61UDX10B
I would check for burnt resistors as the 150s are interchangeable with the 110s however in alot of hitachis I have seen resistors blow after upgradeing to the higher wattage ICs. I Usually switch out the convergence resistors whenever I go to a higher wattage IC just to be sure. If you need more help let me know.
Posted on May 18, 2008
Slinteriors
  • 8617 Answers
SOURCE: Hitachi 53UDX10B Power Light Flashing after convergence IC replacement
C603 is a polyestor capacitor 0.068UF-FEB 50V part number 0880047R S901 is the power relay ALKS329 the part number for the relay is FJ00142 . I recomend checking the pins on the ICs to make sure they are not bridged. If you need more assistance let me know. Vance Baldwin should have the parts if not you may have to order through hitachi
Posted on Jun 06, 2008
daniel719
  • 240 Answers
SOURCE: Hitachi 53FDX20B Screen and Sound Shut down (Pwr light remains on
you need to replace the Eeprom location 1004
regards,
daniel.
Posted on Jan 13, 2009
  • 668 Answers
SOURCE: 57F500A, powered light on with no sound/picture, ticking noise
Over the years of servicing these sets and others for Convergence issues, I have on several times gotten defective Convergence ICs. In your case where a Resistor is now open, (Probably a 1.5 ohm 1/2 watt), I would suspect you had gotten a hold of a defective IC. I would replace them both again. Make sure to use Heat Sink Compound between the ICs and Heat Sink.(Just a thin coating on the metal area) You can get the heat sink compound from Radio Shack. They should also have the Resistor you need.
Good luck,
Skyassoc
Posted on Jul 25, 2009
I have a Hitachi 51SWX20B. I experienced a power loss and according to the local power company a surge due to a transformer being hit. After power was restored, the TV turns on (red indicator light on...
Unplug,replug the tv back about an hour later.Let the tv to get out of it protection mode,might work again.Not,come back give the new problems,help u some more.
Jun 15, 2010 | Hitachi 51SWX20B 51" Rear Projection...
The convergence going bad again on my Hitachi 51swx20b
Sounds like loose solder on the chips. Either that or they are failing. You can save money next time by doing it yourself with a kit from www.TvRepairKits.com
Jan 10, 2010 | Hitachi 51SWX20B 51" Rear Projection...
Have an Hitachi 51swx20b. The colors are not aligned and magic focus will not work. Vertical and sharpness is grayed out...
Ur convergence it dead.U know how to solders?Buy a convergence kit to replaced parts.Websites Tv repair World.com Tvrepairkits.com.
Dec 16, 2009 | Hitachi 51SWX20B 51" Rear Projection...
51swx20b manual
Click Hitachi Support to download instruction manual of 51SWX20B TV.
Apr 03, 2009 | Hitachi 51SWX20B 51" Rear Projection...
No picture
The model you mentioned does not have an HDMI input. Are you using a convertor from HDMI to DVI? If so there are several types of DVI cables/ inputs make sure you use the right one.
Jan 03, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Blue Ray Hookup
i have a ps3 hooked up to mine and the blue ray works very good connected using hdmi cable, converters work good also just purchased Hisense HDTV Tuner for mine
Dec 30, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi 53UDX10B no red color
The red cable from the cable box was loose.
Jul 20, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi 51SWX20B 51" Rear Projection Television Logo
51 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
