Question about Compaq Armada E500 Motherboard
I need to clear the power on password - Compaq Armada E500 Motherboard
Hello rand,
U just clear the cmos..
Posted on Jun 26, 2009
I have an acer laptop 2920 i lost the password which has locked
There is only one way to clear cmos (BIOS) passwords and I'll show you the procedure.....
Steps for Clearing BIOS Password Check
If users set BIOS Password ( Supervisor Password and/or User Password ) for a security reason, BIOS will
ask the password during systems POST or when systems enter to BIOS Setup menu. However, once it is
necessary to bypass the password check, users need to short the HW Gap to clear the password by the
following steps:
q Power Off a system, and remove HDD, AC and Battery from the machine.
q Open the back cover of the machine, and find out the HW Gap on M/B as picture.
q Use an electric conductivity tool to short the two points of the HW Gap.
q Plug in AC, keep the short condition on the HW Gap, and press Power Button to power on the
system till BIOS POST finish. Then remove the tool from the HW Gap.
q Restart system. Press F2 key to enter BIOS Setup menu.
q If there is no Password request, BIOS Password is cleared. Otherwise, please follow the steps and
try again.
NOTE: The steps are only for clearing BIOS Password ( Supervisor Password and User Password ).
Below is the picture showing the location of the jumper next to the memory module slots. This is the jumper connections that have to be "shorted".
Jan 28, 2010 | Acer Aspire 4720 Notebook
Could you please guide me how to remove bois possword for travel mate5730g
If users set BIOS Password (Supervisor Password and/or User Password) for a security reason, BIOS will ask
following steps:
• Power Off a system, and remove HDD, AC and Battery from the machine.
• Open the back cover of the machine, and find out the HW Gap on M/B as picture.
• Use an electric conductivity tool to short the two points of the HW Gap.
• Plug in AC, keep the short condition on the HW Gap, and press Power Button to power on the
• Restart system. Press F2 key to enter BIOS Setup menu.
• If there is no Password request, BIOS Password is cleared. Otherwise, please follow the steps and
try again.
NOTE: The steps are only for clearing BIOS Password (Supervisor Password and User Password).
Check below for the picture of the HW Password reser gap. The gap that needs to be "shorted" is G77.
Jan 27, 2010 | Acer TravelMate 5730-6204 Notebook
My acer aspire one crashed and i need help
Below are the steps for the resetting of the password. Below the steps is the link for the service manual. On page 113 is the picture of the jumper pads that need to be "shorted" to reset the cmos.
following steps:
try again.
http://tim.id.au/laptops/acer/aspire%20one.pdf
Dec 26, 2009 | Acer Aspire One PC Notebook
ACER ASPIRE 4730Z. How do I clear the CMOS (password)?
Below is the steps for clearing the password. Below that is the link for the manual, the picture of the jumper tabs is on pg. 153, good luck
following steps:
try again.
http://tim.id.au/laptops/acer/aspire%204730z%204730zg%204330.pdf
Oct 11, 2009 | Computers & Internet
Don't reset password BIOS HP DC7100
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
Open the CPU casing locate the CMOS battery in motherboard and remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper.
This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it. Good luck!
Oct 04, 2009 | Computers & Internet
My laptop compaq armada1700 ask me power-on password what can i do?
Follow the instructions of the service manual for the Armada 1700 (you need to have some skills):
2.2 Clearing Passwords
The power-on password prevents use of the computer until the password is entered. The setup password prevents unauthorized changes to Computer Setup. To clear the passwords, you must remove all power from the system board. If you do not know the passwords, use the following procedure to clear the password:
1. Remove all battery packs from the battery bay and MultiBay, if applicable.
2. Disconnect the AC power.
3. Remove the real-time clock battery.
4. Wait five minutes.
5. Reconnect the AC power.
6. Restart the computer. During Power-On Self Test (POST, a "162 System Options not set" message appears.
7. Shut down the computer, then disconnect AC power again.
8. Replace the real-time clock battery.
9. Install the battery pack(s).
10.Proceed with the troubleshooting procedures.
Point 10 means you need to do the setup via disquette to set the date and time again, to avoid the "162 system option not set" message of the POST.
Lucas from Argentina
Mar 22, 2009 | Compaq Armada 1700 Notebook
Clear power on password
Removing the Time of Year battery will clear the BIOS password. It is located on the underside of the n610c behind the panel covered by the Microsoft COA label. A small phillips screwdriver is required to remove the two screws on the panel. Carefully lift the BR1225 battery with a small flat blade screw driver.
After 10 minutes re-insert the battery. The BIOS Password should now be cleared, as well as other BIOS settings, the time and date.
Sep 09, 2008 | Compaq Evo N610C Notebook
Power on password
If this is a Windows password, then you will need to enter safe mode at start up by pressing F8. Once you're in safe mode, log on as administrator, from here you can clear any user passwords. Now if this is a bios password, then you will need to contact Compaq support.
Jul 15, 2008 | HP Compaq nx6310 Notebook
Acer aspire 9300 backdoor or bios password
Clear Password
PIN Pad: Bypassing Password Check, Keep shorting G3 (2 triangle pad) as above PIN pad and
then powering on the system will force the BIOS to clear Supervisor and User passwords. That
means both the power-on and setup passwords are all cleared.
Apr 15, 2008 | Acer Aspire 9300 Notebook
Compaq Armada E500 Motherboard Logo
96 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
