Question about HP Pavilion dv6000z Notebook
When i just move or tilt my screen every thing get vanished. the whole screen turns dark. and have to manually turn off and turn on again.. please help..any problem with battery i guess.. pl help... TP
  • 1 more comment
  • Okit Palling
    Okit Palling Jun 25, 2009
    boss actually there is ne problem with the battery.. please do not that when u tilt the screen it goes dark.. it a logical that the kind of model you have always do have loose screen attach.. i recomend you to visit the HP customer care asap.. if ur laptop is under warranty the will replaced it for u.. its the only way out... cheers..pl rate fixya.
  • Okit Palling
    please note that the screen goes dark or blank..its not a problem of your bettery but the problem is with you connection of c=screen with the laptop ..usually the model u using do have such problem.. the only thing i can suggest is to visit HP service centre..if under warrant they replace your screen.. hope it was helful..please rate.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Take out the battery, wiggle the cord near where it plugs into the laptop and make sure its not a loose dc jack connection. If its not then what you might need to do is to reconnect the lcd cable on the back of the lcd an also where it connects to the motherboard and to the inverter.
    President:
  • 942 Answers
Hi..
Take a closer look at the connection between the video cable and LCD screen. It’s possible you accidentally pulled the video cable from the connector during the screen installation.
The video cable has to be seated properly, all the way down.
Also, on some older LCD screens there are very thin pins inside the connector. Take a look inside the connector, make sure there are no damaged (bent) pins.
You can straighten bent pins with a very small screwdriver but this procedure requires a lot of patience and concentration.
Fortunately, most newer LCD's have a different type of connector, without fragile pins inside.
OK, you have reseated all connectors and cannot see anything wrong but the new screen still is not working.
Good luck! Thanks for using fixya.
Regards
PCmania
Posted on Sep 02, 2009
    Champion:
  • 220 Answers
Vga screen cable is damaged
Posted on Jun 25, 2009
Word"print" vanished on window window to large fix it??
Try pressing the box next to the CROSS on the window, top right hand side. This will allow you to resize the window.
It will also give you two bars one on the right hand side and one on the bottom to move around the whole page, in case the word print has slipped off the screen display.
Dec 10, 2014 | Gateway Computers & Internet
Compaq laptop green pink screen pixalted
One of the things is to hook it to another monitor and see if that still happens. If it does not then it is most likely the screen on the laptop. Not to worry though it could be the cable that connects the laptop motherboard to the screen. When you open and close the lid, it flexes the cable and the little wires in can break. The cable is not cheap though. One way to test this is to change how far the lid opens by flexing it open and closed to see if the screen changes. If it does then it is that cable.
Jan 19, 2014 | Compaq Computers & Internet
Lcd turns dark
Hello
OK, firstly, let me ask you a couple of questions.
Does the screen work for a bit and then turn dark?
Does the display change when you tilt the screen?
Let me know, i will come back to you as soon as possible.
Kind regards
Andrea
Sep 28, 2010 | Acer TravelMate 6410 Notebook
When computer is turned on the initial page vanishes the screen goes blank and the mouse arrow appears then sadly nothing just a dark screen !!!!!!!!!!!!
this problem might be due to the corruption of logon file
install a fresh copy of windows or try to restart it in safemode by pressing F8 repeatedly before boot screen.
Mar 30, 2010 | Acer Aspire One PC Notebook
Screen has turned white no display
my screen is not appearing it started last four moths after some few minutes the time comes and when any of the key pad is pushed sudden it will vanish and the screen turns white.
Jun 08, 2009 | Sony Ericsson K750
Acer Travelmate LCD screen went dark
The same thing happened on my HP. I ended up buying a LCD screen off ebay. That corrected the problem. New screens cost $150+. You can get one off ebay for half the price.
Jan 16, 2009 | Acer TravelMate 270XV Notebook
TV power light comes on, but no picture
I have the same problem. I now turn the TV on manually and tilt it forward at the same time. This has been working for about 6 months now. I don't know why tilting it forward gets the picture back but that could be part of the problem going on internally. I cannot afford to get it fixed. The TV is only 2 years old. We thought we were buying a good product. Guess Not. Try this.....
Jan 14, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Mitsubishi WD-52525 - Picture is not horizontally level
You would need the service manual for that adjustment. It is outlined in the service manual on how to adjust the tilt. It is a mechanical adjustment. You can get the service manual emailed to you instantly after purchase at this link.
http://servicemanuals.vstore.ca/
Apr 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Dark screen
Please check your user manual. There is an save mode. Leaving the save mode will solve the problem. If you need more help please advice.
Jan 12, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
HP Pavilion dv6000z Notebook Logo
126 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
