Question about Refrigerators
We have side by side kitchenaid refrigerator. The problem is the freezer side is working, but the vents in the other side (refrigerator) does not blow air. I think the diffuser is not working. Is that correct? Any suggestions. Thanks
  • 58 Answers
Most likely defrost problem, check for evidence of frost on back of freezer panel, remove evap cover if nec. Make sure evap fan is working, if not, test for power to evap fan, if none, replace. if defrost problem, ohm out heater and defrost thermo, if either open, replace, if not, check defrost timer. If in defrost no power to heater or thermo, replace timer.
Posted on Jun 25, 2009
My freezer works fine it's my refiidgator doesn't
Check that foods in freezer are not blocking the vent which allows cold air to refrigerator. Newer refrigerators have only one cooling unit in the freezer. Cold air must be free to enter the refrigerator section.
Jan 09, 2014 | KitchenAid Superba KSRS27CN Side by Side...
My freeser is working other side is not cooling the top vent getting air but not underneath
You need to thaw the ice which has clogged the passageway from the freezer to the refrigerator. To do this, you can turn off the whole unit for several hours and let everything thaw, or you can remove the panels and locate the vent(s). Melt the ice with a hair dryer, then reassemble the panels and restart the refrigerator. There is a small chance that the fan in the freezer has frozen up as well. When the refrigerator compressor runs, you should also hear a small fan in the freezer run. If not, you will need to do some investigating to find out why.
Apr 25, 2012 | KitchenAid Refrigerators
Kitchenaid superba refrigerator side at lowest temp setting is not cold enough. Freezer temp is fine.
Check the setting of your vents between sides and open them, sometimes you have to pull out the produce drawer to find the lower one
Jun 23, 2011 | KitchenAid Superba Architect KSCS25INSS...
Freezer works; refrigerator does not. Can't hear any noise. Plugged in & vents clean. Generator?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | KitchenAid 19.7 Cu. Ft. Side-By-Side...
Freezer side is working, but frige side isn't cooling?
Probably a defrost problem. I would suspect that the freezer is not as cold as it should be, even though it still freezes ice cream.
It could be air circulation, so make sure you have not packed the freezer or refrigerator too tightly and blocked the cross over vents.
To check if the problem is the defrost system, look in the louvered vents, or around the fan, to see if there is thicker accumulations of frost/ice on the cooling coil.
Dec 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid side by side freezes food in the refrigerator side
The damper between fridge and freezer is most likely stuck open.
Oct 02, 2017 | KitchenAid (KSRD22FKST) Side by Side...
My refrigerator won't stay cool but my freezer works fine
You have something wrong with the vent going from the freezer to the fridge. You probably have a defrost problem and ice is blocking the vent that goes from the freezer and comes out in the roof of the rerigerator compartment. Replace your defrost timer and bimetal.
Sep 11, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Ice build up on a corner of the coil.
could be low on freon or insuffencient compressor...
Jun 24, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Refrigerator section warm. Freezer section OK.
Most likely it's a defrost system problem. One of the heaters could be bad and that will cause the coils to freeze up reducing the amount of cold air the fan can push into the fridge. Sounds wierd but, trust me, that could be your problem. Mine did that two years ago.
Apr 14, 2009 | KitchenAid KSCS25FKSS Side by Side...
Kitchenaid KSRA25IL Freezer working Fine - Refrigerator not
many times when a unit has a defrost problem the coils freeze up and do not allow the fresh food side to cool properly...check for a build up of ice on the inside back wall of the freezer compartment. if there is a build up of ice, you have a defrost problem. Also, check to make sure the evaporator fan in the freezer is blowing the air into the fresh food side.
Dec 26, 2008 | KitchenAid KSRS25IL Side by Side...
Refrigerators Logo
93 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
