Question about Gateway GT4016 Desktop PC
Gateway GT4016 not booting up. Fan works, but no
Gateway GT4016 not booting up. Fan works, but no beeps even when I have disconnected the hard drive. I tried removing and reinstalling the memory, reset the bios by changing the dip switch setting but nothing changed. Is there a LED light on the motherboard so we know the motherboard is working?
  • 59 Answers
I have a gateway computer with a gateway nvidia geforce 6150 uatx 4006138r motherboard and will not boot up. windows vista 32 bit OS. I get no beep codes unless I let it sit for a day. i took ram out and ...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up:
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty:
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly:
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
also check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge Cmos battery on some motherboards are soldered in
hope this helps you
Sep 26, 2011 | Gateway Computers & Internet
Gateway gt4016 desktop, s/n gcm64 110 54982 unit will not boot up, pressing power button, fans starts, yellow light comes on, then shuts down. cleared cmos, pressed power button unit will boot up but...
the cpu could be over heating make sure its secure if you like get some thermal paste from your local pc world put a little on the top of the cpu under the cpu fan and replace fan securely might work be carefull....bonnell
Sep 17, 2011 | Gateway GT4016 Desktop PC
I have a Gateway GT4016 Desktop PC im trying to restore it back to factory settings without the cd. can you help
almost all gateway have all of your restore to factory default on a drive that is hidden on the hard drive. All company's use a different key to do this but I always start with f5 start the comp and hold f5 down and the system restore program should pop up. If it is not f5 it will just beep at ya. Then just do the same thing over and over starting with f1 all the way to f12 until you find the right one. but I always try f5 and f8 first hope that helps
Dec 04, 2010 | Gateway GT4016 Desktop PC
Gateway GT4016 boots but nothing shows on the monitor
Without more specific information it is hard to tell. Did you just buy a new video card? Is it the the right type? Where did you get the second card? Have you tried it in another PC or talked to the store you got it from? Maybe the source can test it. Your PC can take an optional PCI express x16. Make sure you are using the right display adapter expansion slot. Note: PCI-e is not the same as PCI-X. They are not compatible. You want PCI-e.
May 01, 2010 | Gateway GT4016 Desktop PC
GT4016 recovery stuck on 1 screen
Sounds like a memory problem. You have to remove the ram and spray some air using pressurized air in the slots then reinstall the memory. That might do the trick.
Dec 23, 2009 | Gateway GT4016 Desktop PC
I have a gateway gt4016, it is not loading. it's asking for a recovery cd... so I put in the operating disc (windows xp) it's not reading it and I can't enter safe mode.
first go into the bios f2
set the boot record to boot from cd first
also on new computers it will say hit f 11 12
for boot order selection, but this has to be done fast before it tries to pick up on hard drive
if the cd player works ok
you should see "press any key to boot from cd" first, is the start of erasing your hard drive
Jul 19, 2009 | Gateway GT4016 Desktop PC
Fan works but no beeps, no video signal. Tried some suggestions.
sometimes pulling the power cord out of the pc and then replugging it will let it reboot. for some reason these machines die, and they will not reboot until you take all the power off the motherboard for about 10 seconds.
Jun 25, 2009 | Gateway GT4016 Desktop PC
Gateway gt4016 won't boot. Fan runs but nothing
open cpu cabinet and pull Ram and refix it.
Aslo reattcha llconnection to mother bord.
Pull cmos cell for 15 minutes so all bios setings are set to defaults.
Jun 12, 2009 | Gateway GT4016 Desktop PC
4016 gATEWAY computer wont boot
Plug off your Hard Disk and give a try. If the system boots then, its a prob with HDD. Else, it may be because of the monitor, or the RAM module.
Thank you!
Sabharish
Jun 03, 2009 | Gateway GT4016 Desktop PC
Gateway gt4016 problem
Check your monitor on another computer. If it is ok connect it to your bad computer. Open the CPU case and unplug all the data cables and power cables to HDD, floppy and cd/dvd. Remove keyboard and mouse. also remove pci cards if any. You didn't mention about video card. I guess it is onboard. Now put it on an see. If nothing happens blame the motherboard.
Dec 17, 2008 | Gateway GT4016 Desktop PC
Gateway GT4016 Desktop PC Logo
569 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
