Panasonic NN-T888S Convection/Microwave Oven Logo
A
Anonymous Posted on May 29, 2014
Hi. we have a panasonic nn-cf778s inverter oven. my wife slammed the door shut too hard. it tripped the circuit mcb and now the only sign of life is the top panel background flashing and nothing else will work. any ideas please. bern
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jan 02, 2009
SOURCE: Hi, I have a NN-C784MF
Chances are there are other bad parts blowing the diodes, most likely a MOSFET.
Also, the ESR of the electrolytic capacitors should be checked and all board connections must be checked and resoldered if suspect.
If you're not experienced in troubleshooting switched-mode power supplies (inverters) then you can probably save a lot of timer and money by replacing the whole inverter.
You can find the nearest spare parts supplier by selecting your country then the support links at Panasonic.net.
Anonymous
  • Posted on Jan 20, 2010
SOURCE: Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Anonymous
  • Posted on May 29, 2010
SOURCE: panasonic NN-CD997S microwave
i have microwave problems power trip when switch on the unit. please help me.
Anonymous
  • 30 Answers
  • Posted on Oct 22, 2010
SOURCE: just had a panasonic inverter nn-cf778s delivered
No it definitely isn't. Sounds as though they got the interlocks connected incorrectly, or the control panel is defective.
Either way, you definitely need to send it back to where you bought it.
Anonymous
  • 3361 Answers
  • Posted on Jun 11, 2011
SOURCE: Door closes but will not
There are micro-switches in the control panel that are out of adjustment or sticking.
The switches have to make contact with the door latches when the door closes.
Adjust the position of your switches.
Panasonic NN-H965WFX Microwave is visually dead. Could the power relay behind the control panel cause the problem?
Replace the door switches and it may well work again.
Mind your fingers becaus 2500 volt is no joke!!!
3helpful
4answers
Panasonic inverter nn-cf778s
Demonstration Mode
This is to enable you to experiment setting various
programs. (The letter D will always appear in the display
window. This is to confirm that there is no microwave
power produced and it is safe to use the oven without
any food). To set Demonstration Mode: press micro
power once, then press Stop/Cancel 4 times. To cancel
Demonstration Mode press Micro power once, then
5helpful
2answers
Our panasonic inverter microwave (3 years old) needs repeated hard slams to shut the door so that the light goes off and the microwave will work. How do we fix this problem as I'm afraid we are going to...
We have a Panasonic Inverter microwave. Door became difficult to close and had to slam it hard while holding themicrowave to keep it from moving. When opening the door did not pop open but did unlatch. I ordered a new door lever from Panasonic. When got part I removed case from microwave and lever was okay. I then removed the perimeter strip on the inside of the door. With a screwdriver I stretched the spring at the bottom that keeps the door latches pulled downward. Spring still worked just not as stiff. Put perimeter piece back on the door and replaced housing (which I didn't need to remove in the first place), and then put a small drop of vegetable oil on the cams where the door latches hit when closing door. Viola, door opens and closed as new. Problem solved. Diagnosis: over time the latch tension spring hardens and gets too stiff. P.S.: I had several similar springs as backup in case I screwed up the original one.
Our Panasonic NN-S763BF microwave turns on (light goes on, table turns and fan goes on) automatically when we open the door even though the clock is displayed. It works normally when the door is shut....
You have a faulty interlock switch (which the door operates).
This needs to be renewed by a qualified microwave service technician ASAP.
A potential hazard if not fixed immediately!
2helpful
Just had a panasonic inverter nn-cf778s delivered today.on microwave setting it continues to run after the door is opened,surely this cant be correct.
Top Panasonic Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Jerry Naidoo
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
