Question about Ruud UAMB Air Conditioner
What size wire do I need to power my Ruud UAMB AC unit
  • 92 Answers
#8 wire
Posted on Jun 25, 2009
Ac blower motor attic
that is a model number for the outside condensing unit. to find the motor size for the inside unit, you will need the model off of the inside unit, gas furnace or electric air handler.
Aug 15, 2013 | Ruud UAKA048 Air Conditioner
I have a RUUD gas pack unit.....when you turn on the heat, the blower does not blow any air out of the vents while on "auto". If you put it on "on" it blows cold air out of the vents. What is wrong?
Sounds like the thermostat is hooked up wrong. If the ac doesnt work right its in the thermostat programming or the wiring. Hope this helps good luck
Jan 13, 2013 | Ruud UAMB Air Conditioner
Air Handler--Noisy Harmonic Sound
DO NOT buy a RUUD system. I purchased a complete system in 2010 & have had multiple issues since - - new coil, high humidity levels, condensation on my walls when the furnance is on, and now when the outside temp is 90+ degrees the AC unit shut off and only blows hot air. THey've replaced the "board" and I was told that RUUD is aware of multiple problems with the 2010 units but will NOT recall them.
Nov 01, 2012 | Ruud UAMB Air Conditioner
I don't know how to wire up my air conditioner. I have two hot wires, but no place to attach the ground wires. It is a self contained outside unit.
Your Ruud is a 220 volt AC unit and requires two hot wires and one ground. The ground wire goes to the case inside of the electrical box close to the contactor that the two hot wires connect to. I have included a picture of what the grounding lug looks like so you will have no trouble finding it.
Grounding lug
Jun 16, 2011 | Ruud UAMB Air Conditioner
Need a part number for fan motor on UAMB-036JAZ
Hi, what you need to do is gain access to the motor its self. If it is the condenser fan motor or the blower motor . This is a 3 ton unit from the numbers you have given me. There are two ways you can do this. On the data plate on this Ruud unit, normally they are paper with a plastic coating on Ruuds and Rheems, and it will tell you the H.P., size like 1/3, amperage, and the R.P.M.'s. Then get all of the model number and serial number from the unit. The best way is to get the information from the motor its self. It has the voltage, amperage, name of motor, example a G.E., the part number, Horse power (H.P.) r.p.m. such as 1725, 1100, and so on. Rotation, CW or CCW. The new motor will be reversable, just change 2- leads on it. This would be your best bet, to do it this way.
please don't forget to rate me and I know you will be kind. I cant give you the numbers as they will use different motors in the same unit, and different brand names.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
May 29, 2010 | Ruud UAMB Air Conditioner
We have a RUUD AC unit, model number UAMB-042JAZ. ...
Those are the low voltage wires from the thermostat and transformer. Yes he can just match up the colors and splice with wire nuts or something else to hold the tight. If the transformer got shorted out during any of this it may need to be replaced. Hook them up and if the unit runs, then no problem with the transformer.
May 21, 2010 | Heating & Cooling
How do i find coil size for a armstrong central air unit
Are you asking what indoor coil size you need to match your outdoor unit? If so the model number of the outdoor unit will have a number divisible by 12. example an 036 is a 3Ton a-c an o42 is a 3 1/2 Ton. Probably the numbers right after UAMB.
Aug 27, 2009 | Ruud UAMB Air Conditioner
Electrical Schematic for Ruud URGG-10E37JKR
just a maybe , write to RUUD AT P.O. BOX 17010 , 5600 OLD GREENWOOD ROAD ,FORT SMITH ARKANSAS, 72917-7010, OR CALL 479-646-4311 AND SEE IF THEY CAN TELL YOU WHERE TO CALL FOR SAM.
Sep 20, 2008 | Ruud UAMB Air Conditioner
Ruud UAMB Air Conditioner Logo
71 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
