Question about Carrier Heating & Cooling
Replacement of air conditioner's compacitor
My power went out due to a storm and the air condensor's fan stopped working. I figured I need to replace the compacitor which is approximately a $10.00 part. How do I replace this on my own?
    Problem Solver:
  • 7 Answers
I am assuming this is a split system with the condensor outside and the air handler inside. What is the model of your unit? Is the capacitor a dual run capacitor? Is the compressor running? If the compressor is running and your condensor fan is not you need to immediately shut power off to the compressor or you will probably ruin your compressor. If the power went off due to a storm and you don't have power to the condensor fan did you check to see if the circuit breaker to the condensor was tripped. I would check that first. Even if the circuit breaker doesn't look like it tripped go ahead and flip it off and back on again. Even you suspect it is the capacitor you need to determine if it is a dual run (controls the compressor and the fan) or does it just run the fan? If it is a dual run capacitor you will have to get the numbers off the capacitor and try and find a match at the local hvac supplier. If you have a Grainger's in your city they probably will have a match. When working on your unit don't forget you are working with high voltage that can KILL you, If you don't know what you are doing call in a professional. If you decide to tackle it yourself make sure you turn off the power to both the inside unit and the condenser. I always pull the disconnects inside and outside, flip the circuit breakers and turn off the thermostat just to be safe. Then I double check by using my digital multi-meter to ensure the power is totally off. The capacitor stores power so you will have to discharge it by using an INSULATED screw driver and touching the blade across the terminals. Discharge the capacitor AFTER THE POWER IS SHUTOFF. Before you pull the wires off the capacitor terminals I suggest you make a drawing of where the wires are connected. You should have markings with a "C", "F" and "Herm". Even better, I like to take several digital pictures from different angles of the connections. After you remove the capacitor, I would suggest you take it with you to your hvac parts supplier so they can match it. Once you get the right replacement capacitor it is just a matter of connecting the wires back to the original configuration. Then restore the power by flipping the breakers, plugging the disconnects back in and turning the thermostat back on. Most units will not start up right away. They have a 5 minute delay built in to protect the compressor. Good luck and post back and let us know how it goes.
Posted on Jun 25, 2009
KF9000e. Why does compressor cycle at short intervals?
Yes. due to low rpm of fan motor in the condensor copil. or dirty condensor coil. I If so, replace fan capacitor.
If all good, check the seating of condensor set. It needs minimum 2mtrs open space for air throw. If not due to overheat compressor gets short cycling on and off.
Sep 07, 2015 | Amcor Heating & Cooling
Replaced a ge condensor fan 3 wire with new dayton the wires are different...old fan has a wire connectort mouted to it orange,black yellow, the new one 2brown 1 with white stripe, purple, black, i have...
the new ge fan requires its own capacitor, the brown and the brown/white go direct to new fan capacitor. black to relay (leg one of power) purple to relay (leg two of power. the compressor will have a wire to the relay and the other to the herm terminal. you now will have nothing to the original capacitor fan terminal.
The new motor will have the diagram showing this. you need the capacitor that goes with the new motor. the grainger guy should have sold that to you with the motor.
Apr 11, 2013 | Heating & Cooling
My condensor fan and compressor on my Carrier AC (Model# 38ckc036350) stopped working, so I replaced my capacitor and they both work fine now. The problem is my house won't cool down. There is c
Often after a repair has been made, the air conditioner will take hours to readjust back to normal. When the system has been off for to long, not only does the heat in the house rise, but so does the humidity, which has to be pulled out of the air first before it really starts dropping in temp. You could have a low charge on refrigerant, dirty filters, etc. More than once I have ran into things that were just coincidence after a repair that showed up. Since you just replaced the capacitor, I would make sure the fan motor is turning in the right direction and there is nice air flow coming out of the condenser, some times if one wire is wrong, it can cause it to spin backwards, which will work, but just barely. The air needs to be pulled through the coils, not pushed. Hope this helps!
Jul 06, 2012 | Carrier 38CKC036 Air Conditioner
HAIER HWR12XCA. Main fan stopped working. Condensor kicks on then kicks off after a few minutes. Any suggestions.
I would replace the fan capacitor. This is a split system and from the symptom you
describe, it would be the first thing I would look at since the compressor will go into
thermal overload and shut down if the fan is not running.
Fan caps are available online, Or you can get a substitute from a local appliance
parts store. Just be sure the value of the replacement is the same. Make sure power
is off at all sources feeding this unit before servicing. :)
Jul 31, 2011 | Haier HWR12XCA Air Conditioner
I have an amana 90 home air conditioner w/ a amana prestige compressor. compessor runs but cooling fan not turning ,fan is not locked up and unit has power .of course w/fan not turning home is not...
Could be a couple of reasons for this:
1. Condensor fan motor bad.
2. Condensor fan motor loss of power.
3. Condensor fan motor capictor bad.
Unit has control for fan for low ambient operation and unit is low on freon telling fan its cold out side and dont run.
Hope this helps. wally
Jul 22, 2011 | Amana Heating & Cooling
I have a Ruud condenser on which I just replaced the capacitor and contactor. When I power up, the fan motor spins very slowly and a buzzing occurs about every 15 seconds. The buzzing sounds like it's...
Hello Zing77,
I understand that you are having a problem with your Rudd condensor. The fan is turning slowly and the compressor is making a buzzing noise which has a Diversitech hard start conected to the capcitor.
You have already replaced the run capcitory on the unit and have attached the compressor wire to therm and c and the fan to therm and fan. The hard start kit shoudl be attached to the therm and c with your compressor wires attached to the same place. The hard start kit is to give the compressor the extra push (electrical charge) to start.
You need to check your connections and make sure that you purchased the proper run capcitor. If you have purchased the proper compacitor and the connections are right then you have a bad fan and the compressor as gone out on the unit.
Thank you for choosing FixYa.com
Justin
Mar 27, 2011 | Heating & Cooling
Location of overvoltage protection
Go outside to the condensor, its unlikely that the fuses are there unless it is an older unit. Turn off the power and open the power disconnect box. That is one place the fuses or breaker could be.
In the house you should have an electrical panel usually grey in color. Open the service panel as it should be hinged. Most of the time the fuse or breaker is labeled AC Unit andThe rating should be
anywhere between 25amps-60amps.
Jul 20, 2010 | Goodman CKL24AR24 Air Conditioner
Cooling fan in condenser sometimes does not run.
Shut off the power before inspecting or repairing! I would check the wiring harness inside the condensor unit for loose connections and or broken wire first. Then you might try removing the capacitor to the fan (some operate both the fan and compressor) and have it tested. If all is OK then your fan motor is probably overheating and may need replaced. A bad capacitor can cause the motor to overheat. If you had a lightning storm just before the problem the capacitor is most likely the problem.
Aug 05, 2009 | Heating & Cooling
A/C not working, outside fan not turning without assistance
is fan spinning fast enough it has to have alot of velocity to cool condensor coils if you haft to push fan to get going its probably shot and get new motor the ac is a sealed system and hardly ever will leak freon!!!Best of Luck to You!!! :)
Jul 02, 2009 | Bryant 462AJC021BA Air Conditioner
Condensor fan wont come on
check you breaker for a/c seperate from air handler and check the contactor could have coil blown for low voltage not calling in the compressor
May 16, 2009 | Heating & Cooling
Heating & Cooling Logo
363 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
