Question about Maytag Neptune MDE5500AY Electric Dryer
Whirlpool electric dryer will not turn on, timer seems to work
I turn the timer on then i press the strat and the dryer does not turn on it just clicks the door is shut completely
  • 351 Answers
Take off the back cover and spot a little white fuse with 2 wires going to it check for continuity if yes then you have another problem if not change that ... very common for that part and if it happens to be then you have a air flow problem... let me know whirlpoolpartssurpllus.com
Posted on Jun 25, 2009
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet...
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Aug 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
I have an electric whirlpool with start switch not working
OPEN THE DOOR/PUSH THE START SWITCH ON DRYER/THEN PUSH THE DOOR SWITCH/HAVE A PERSON TURN THE DRUM/IF IT STARTS TO TURN (DRUM) OR STILL HUMS AND DRUM WILL NOT TURN YOU HAVE A BAD MOTOR/REPLACE MOTOR.
FREDDY
Feb 14, 2010 | Whirlpool LGB6300 Gas Dryer
Dryer runs but does not get hot
if timer runs thru cycles then it is the element sounds like timer
Oct 30, 2009 | Whirlpool LER8648P Electric Dryer
Dryer tub turns but there is no heat
I have a frigidaire crown series dryer.the tub turns,timer works but there is no heat coming out.
Jun 23, 2009 | Whirlpool Dryers
I HAVE A WHIRLPOOL DRYER. TURN THE TIMER SELECT ON. THEN TURN START KNOB TO ON, THEN PRESS THE SAME KNOB IN TO START CYCLE. YOU CAN HERE THE TIMER AND SOUNDS LIKE THE CONTACT IS WORKING, BUT CYCLE WON'T...
Hello dacarle,
Welcome,
You said, I HAVE A WHIRLPOOL DRYER. TURN THE TIMER SELECT ON. THEN TURN START KNOB TO ON, THEN PRESS THE SAME KNOB IN TO START CYCLE. YOU CAN HERE THE TIMER AND SOUNDS LIKE THE CONTACT IS WORKING, BUT CYCLE WON'T START.
Please send me the model number so i can check out the problem.
Waiting your response
Huuum
Oct 15, 2008 | Whirlpool Dryers
Whirlpool LER5644EQ2 Electric Dryer that won't start
HI yes it could be a fuse its called a thermal fuse located at back of dryer remove back on the left sede on air duct a fuse with 2 smaller blue wirse that should be your problem thanks THE APPLIANCE DOC
Sep 06, 2008 | Whirlpool LER5636P Electric Dryer
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
301 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
