Question about Maytag MTB1504A Top Freezer Refrigerator
Why is my compressor running all the time and not getting colder than 44 degrees
    Problem Solver:
  • 7 Answers
More than likely the coils are dirty. The coils need to be clean for the refrigerator to cool properly. On some refrigerators the coils are on the rear and others the coils are underneath. They sell a special brush at most hardware stores and grocery stores. I see them for sale all the time at the "big box" stores. I prefer to use my air compressor with a long blower attachment to reach underneath and blow the dust and "wooly bugers" off. I set the pressure regulator on the air compressor to 40 psi. The only thing is the dust and crud go everywhere but the coils are left really clean. This needs to be done about every 3 months, at least..
Posted on Jun 25, 2009
What is the best temp . for my freezer and fridge on Boshe 44 intelligent and how often should the motor stop for self defrost per day
the compressor and or condenser fan have nothing to do with defrost cycle which is determined by the thermistor which turns on the defrost heater
meaning the defrost heater can glow hot whether or not the condenser fan and or compressor is running.
the defrost heater will activate many times in a 24hr period, the colder you keep everything - the more it is activated.
best temps are:
freezer: 28-31
refrigerator: 39-41
Jan 04, 2015 | Refrigerators
Kenmore 596.58642890 not cooling. Compressor is working. Fan is working. Coils are clean. We completely cleaned everything and turned it back on around 12:30 today. Temperature is only down to 60...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 21, 2011 | Kenmore 53082 / 53084 Side by Side...
I have GE ref, its been a 6 years old. when the temp.reach to 5 deg. it stops the compressor. but the thermostat setpoint is very low. what seems to be problem
Thermostats are common to fail or get out of range, have you had it colder in the past? Is the thermometer that your checking it with accurate.Or are you just wanting it colder now. 5 degrees is not that bad except for ice cream ect. Although its not a problem for you at this time, is the condenser coil clean?
Jul 03, 2011 | Refrigerators
I have a hotpoint side by side model csx20ba xawh. the freezer will not get colder than 20 degrees and the refrigerator will not get colder than 48 degrees. what do you think the problem is.
make sure everything is clean behind and underneath fridge, also make sure fan is blowing across condesor coils and all covers in back are in place
Oct 21, 2010 | Hotpoint Refrigerators
Compressor turns off
Good day,
If he temperature in the garage drops below 55 degrees running time will degrade, and cooling will get erractic, if at all.
It will be covered in your owners manual.
That's the good news.
The problem is the compressor has an oil sump just like your car. But it does not have multiviscosity oil.
Under real cold conditions, it approaches sludge. When it's finally asked to run it has to fight that severe problem, and will, over time (sooner than later)
will destroy itself.
Should be moved into a warmer area if possible.
Thank you for using FixYa
Jan 29, 2010 | Frigidaire FSC23F7D Side by Side...
Vegetable draw is getting too cold and freezing contents,
Good day,
Seems to be a common complaint when colder weather sets in.
This problem seems more acute when the rooms cool down, and the machine gets light usage.
The main reason, is the machine stays off for longer periods of time and the air stratifies in the fresh food compartment.
That is, the cold air tends to settle to the bottom of the compartment when the machine is off and the circulating fan is not running.
recommendations are to set the thermostat to a warmer setting..
Sounds good, however, there are techs who recommend setting it to a colder setting, to keep the fan running more frequently.
I know it sounds ludicrous, but it's primarily the result of trying to keep one compartment at 0 degrees and another at 37 degrees using only one compressor and one cooling fan.
Many years ago, many refrigerators had 2 fan motors, one for each compartment, and 2 thermostats. These machines never had this problem.
Dec 05, 2009 | Kenmore Refrigerators
Not cold enough
hi it is thermostat problem better to check it..... thank u.......
Jun 03, 2009 | Kenmore Freezers
Running High @ -10 C and should run at -20 C on coldest setting
1. Make sure the sealing gasket is making good contact all the way around. It's pretty easy to lose 10 degrees. If it is a magnetic seal on the door gasket, it may not be sealing all the way around.
2. If it is staying that cold, everything is working well enough. Maybe you need a little gas in the compressor. Time for the service guy.
By the way, is your unit speced to be that cold full of supplies? Is the door opened frequently? minus 35 is pretty cold.
Mar 11, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore
when its running how hot are the sides the starting amps are too high and 1.5 running amps ain't bad now the the cut in cut out are too high if you look on the dial that the mid point settings that's where you should have it not on 1 1 is hot set it on the straight line that's where you should do all your testing colder settings go up not down you could be overheating the compressor by making it come on too quick the freezer should be about -10 or so do you see any gaps in the gasket
Mar 31, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Low temp conditions
75k ohms resistor is lower than 0 degrees F in equivalent temperature may be compressor cannot operate because the maximum setting of thermostat. is from 17 to 18deg. C. You can use 11 to 12k ohms the temp. for this is about 23 to 24 deg. C. The resistor resistance is fixed so the compressor continue running without cut out. The only problem for this is the compressor, because the design of the compressor is for high temp. Continue running of compressor can produce icing in suction and evaporator coil and cause damage of compressor due to liquid slugging.
Jan 17, 2008 | Fujitsu 36CS Air Conditioner
Maytag MTB1504A Top Freezer Refrigerator Logo
151 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
