Question about Toshiba Computers & Internet
I need a wiring Diagram for a Toshiba power Cord
I need a wiring Diagram for a Toshiba power supply part number PA3516E-1AC3 19 V and 3.95A.
Polaris 9300 sport pool cleaner. the wires pulled free from the plug into the power supply. not sure which wire goes where. There are 3 red black and brown. 4 holes for them to go back into.
Without a wiring diagram it will need either model knowledge or some educated guesswork aided by a multimeter and carefully studying the internal wiring of the power supply.
Without a great deal of additional description I can't help further other than to suggest you contact the retailer who sold the appliance.
May 31, 2016 | Blue Wave Polaris 9300 Sport Robo Cleaner...
My Toshiba Theaterview turns on with sound, but no picture.
A model number is needed to assist you but a general answer is:
Likely damage is in power or standby power supply the set uses.
A visual look in that area might tell you what is bad---follow power cord inside to the power board where it goes directly.
Mar 19, 2012 | Toshiba Televison & Video
When I plug the power cord it won't boot. I need to charge the batterry first so I could use it. What is the possible trouble.
It sounds like you need a new power cord. The power cord may be giving just enough juice to charge the battery, but not enough to charge WHILE running. You can pick up a universal power supply from Radio Shack to diagnose if this is the issue. If it is, you can either keep the universal supply or return it and pick up a power supply from e-bay or toshiba.com. Just put in your model number with the toshiba link and look for "accessories", then find the power supplies.
Aug 23, 2011 | Toshiba Satellite Pro L300 Notebook
Hi there, The power cable for my laptop has suddenly stopped working, and when I plug it in it makes a strange electronic pulsing noise. Is this fixable, or will I need to buy a new cable? My laptop...
I would recommend getting a new one. Power adapter's die more often than you'd think and a problem with power supply could permanently damage your laptop. They are reasonably priced online and even sold on places like Amazon.
http://www.google.com/search?q=PA3516E-1AC3&tbs=shop%3A1&aq=f
Please leave feedback for this answer, thanks.
Mar 11, 2011 | Computers & Internet
I have a Toshiba Theater View and the power cord came out from the back of the televison. I can't find the location to put it back on. Could I get a diagram please?
hello if you take the back off look on the power supply board you should see a plastic whites clip with 2 pins coming off it or possible 3 just push it back in .
it will be at the top of the power supply board i hope it helps
regards
shaun
Jul 26, 2010 | Toshiba TP55H60 55" Rear Projection...
Needing a power supply cord
u can simple order it by toshiba
Dec 17, 2008 | Toshiba Satellite A105 Notebook
Cord Connection
If your dryer cord is flat and gray, then simply attach the two outside wires from the cord to the left and right screws on the terminal block. Connect the center wire of the cord to the center screw of the terminal block. The only important wire is the center wire of the cord goes to the center screw of the terminal. The two outside wires don't matter.
Jun 13, 2008 | Roper RES7646KQ Electric Dryer
Looking for a power supply
Sorry about the above post, but I wasn't signed in yet and this crazy GLITCH here put me down as a GUEST instead. The above post was mine, as I'm resending it again below.
Thx,
Frank
FRANK'S FIX IT SHOP
AC/DC power adapter + Power cord. 24VDC power adapter + power cord for Toshiba 20HLV15 20" Flat Panel LCD TV
Specification:
Input :100-240VAC (50-60Hz)
Output : 24VDC 4Amp (72W)
Part# ADP-2404-3PX
Approx cost: $50-60
Call Toshiba USA and give them that p/n for an exact cost quote plus shipping.
Best regards,
Frank
Apr 01, 2008 | Toshiba 20HLV15 TV
Mx35 no power
Hi, can you use a multimeter? If so then check on the power suply what the voltage output should be for that unit. Then with the power turned on GREAT CAUTION MUST BE TAKEN AT THIS STAGE AS TESTING THE WRONG END COULD CAUSE ELECTROCUTION use the meter to test the laptop end plug only and see what power output you have. If you can not do this then take the power supply to a technician and have it tested. If ok = dead battery, if not replace power unit. Regards mistyman
Sep 01, 2007 | Toshiba PA2502U - Libretto 100, 110,...
Computers & Internet Logo
249 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
