Question about Maytag Legacy Series Top Load Washer
Leaks from bottom of tub.
I really want to fix this myself. Can it be done? Is it really worth it? Also what is the main cause for this type of leak?
  • 975 Answers
USUALLY THE MAIN CAUSE IS THE CENTER RUBBER SEAL located at bottom of
WASHER , AND is not difficult to replace if
youre good with tools , AJ
Posted on Jun 25, 2009
I have a twenty year old Maytag washing machine that is leaking water out of the bottom of the machine. I have checked the hoses and it is not coming from there. Any ideas
hello. i can help you. unfortunately, your problem has numerous possible causes.
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Jul 02, 2009 | Washing Machines
I have Frigidaire front loading. During the spin
During fill only
All the time
Apr 03, 2009 | Frigidaire Washing Machines
Whashing machine leaking
Hi my name is joyce
Yes you can fix this yourself but you really need to let a specialist do this so you know that it is done so it wont leak. it may costly at first but it will be worth it.
if you want to do it yourself go online and type in hiya.com and go to their website and type in your model # and get your ser# and then call your local dealer in your area that deals in washers of that sort and order part and go to work.. good luck..
thanks
let me know how it turns out and please remember to rate me
joyce
Feb 04, 2009 | Washing Machines
Siemens Siwamat 2105 washing machine leaking
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
Dec 10, 2008 | GE Spacemaker WSLP1100D Top Load Washer
Water leaking from bottom of front lode washing machine
During fill only
All the time
During fill only
All the time
Dec 01, 2008 | Frigidaire FTF530FS Front Load Washer
My bosh is leaking
During fill only
All the time
During fill only
All the time
Oct 31, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
My front loader is leaking water from the bottom
During fill only
All the time
During fill only
All the time
Oct 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
My Ge washing machine is leaking from the Bottom
During fill only
All the time
During fill only
All the time
Aug 12, 2008 | GE Profile Performance WPSF4170WAA
My machine is leaking during the spin cycle - from under the washer
HI,
During fill only
All the time
Goodluck,
Please don't forget to rate the solution
Apr 28, 2008 | Washing Machines
Washing Machines Logo
302 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
