Question about Nikon Coolpix S210 Digital Camera
Cannot operate the camera
"Lens error" message
  • Rabins Sharma
    Rabins Sharma May 11, 2010
    Please give more clearification.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 23, 2010
When I turn on my camera I get the error message 0x0311how do i fix this?
0x0311 error is evidently a lens error.
A lens error can be caused by physical damage to the mechanism that controls the lens, or debris that is interfering with the operation of the lens.
This article may be able to help you with a "do it yourself" solution.
In the event that your problem is due to physical damage and not just dirt or debris, you will need to take it to a local camera repair shop for troubleshooting-- though with most consumer digital cameras, labor and parts cost of a repair can easily exceed the value of the camera.
Mar 11, 2011 | Sanyo Cameras
I have a canon Powershot A480. It keeps coming up with the faultLens Error Restart camera. How do I do this
Service & Support Issue: Camera displays "Lens error, restart camera" on the LCD monitor.
Solution: Possible solutions for a Lens Error message PowerShot A480.
The "E18" or "Lens" error message indicates an error that involves the lens unit or lens cover.
This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution
Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area:
  • Hold the camera so that your fingers do not touch the lens unit when you are shooting.
  • Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred. Please click here to set up service for your camera online.
Jul 25, 2010 | Canon PowerShot A480 Digital Camera
Sytem error 10
Hi - I found this info on the Nikon Australia website:
"System Error" or "Lens Error" message in LCD monitor trnsp.gif Question My COOLPIX camera displays a "System Error" or "Lens Error" message. What should I do? trnsp.gif Answer Having a "System Error" or "Lens Error" message displayed on the camera's LCD monitor would generally indicate that your camera needs servicing. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. To troubleshoot, please try the following:
  1. Use the memory card that originally came with your camera (or a Nikon approved card).
  2. Remove and replace the battery.
On the other hand, a Lens Error generally means that an error has occured during the lens operation. To troubleshoot, please try the following:
  1. Turn off the camera.
  3. Turn on the camera.
If the above tips do not help, your camera must be sent to our Nikon Authorised Service Centres, there are no user serviceable parts in our Nikon COOLPIX cameras. We apologize for any inconvenience caused and we will do everything to repair your Nikon camera as quickly as possible. Click Here for our Nikon Authorised Service Centres details.
Sort of like a Windows Restart to reset the memory.
Hope this helps.
May 09, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon coolpix 4600.
Hi I found this info on the Nikon Australia website:
Seems you may just have to remove and replace the battery - sort of like a Windows Restart to fix a computer problem! - this would reset your camera's memory.
Hope this helps.
Apr 29, 2008 | Nikon Coolpix 4600 Digital Camera
Lens Error
It sound like your lens is either jammed or the motor that causes the lens to open has a problem. First try spraying a can of compressed air around the lens while you turn it on. Also make sure that you are using high output batteries. Digital camera's require high capacity batteries to operate properly but if you are getting a error message then that means that the camera is turning on. Usually if you use regular batteries the camera will just cycle on and off but the lens will come out and go back in. Has this camera been dropped?
Mar 17, 2008 | Vivitar ViviCam 5386 Digital Camera
Lens error
This may be related/helpful: My S3 in normal home use (no sand, wet or shock) just now displayed the ?Lens cover error? message, with cover only half open. Using a tooth pick I ?eased? it gently and it popped open, took a few trial pictures- fine, but would not fully close unless eased. Now will open and close slowly on own but error message blocks camera use. Then spotted cause - a loose thin sliver of silver trim from below flash around (there?s a gummy substance where it should be). When I first saw one end of this it was between the lens cover and the camera body as tho part of the mechanism, so I did not touch it. Now I know it?s jamming the lens cover operation is it OK to open the camera case to get it out? Questions: (a) Has anyone done this please? (b) Will this clear error message? Thanks.
Aug 21, 2007 | Nikon COOLPIX S6 Digital Camera
Taking photos
Hi, I researched the Canon site and the E18 message relates to a lens issue. Your lens sounds like it's "jammed" and so the camera is displaying the error message. According to the Canon online support, the error is temporary and should go away the next time you properly turn on the camera. Howevcer, since you say it happens every time, it may be a bigger issue with the lens. There suggestion is to have it inspected by a certified repair person. This is what I got off the Canon site: Issue: Lens will not move and camera may display an E18 or "Lens" error. Solution: Possible solutions for an E18 or Lens Error message PowerShot A410 The "E18" or "Lens" error message indicates an error that involves the lens unit or lens cover. This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area: * Hold the camera so that your fingers do not touch the lens unit when you are shooting. * Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case. If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred. Good luck. NewMediaMan
Jul 03, 2007 | Canon PowerShot A410 Digital Camera
E18 error message
I have the same problem that was posted by chewie .
E18 error message!
Hope somebody can help.
Jun 22, 2007 | Canon PowerShot S2 IS Digital Camera
Problem with my camera
Your lens is jammed, and needs to be repaired or replaced.
Sep 04, 2006 | Canon PowerShot SD300 / IXUS 40 Digital...
Nikon Coolpix S210 Digital Camera Logo
50 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
