Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Only Keyless entry or remotes can be programmed but not both
Once I program any remotes, the keyless entry will not program and if I program the keyless entry, the remotes will not program into the LiftMaster 1265 opener.
    President:
  • 3,197 Answers
If you can program your remotes but when you program your keypad the remotes quit working and vice versa you have either the wrong keypad or it has reverted to an earlier technology. Make sure the keypad is for your specific model door opener.
Posted on Jun 25, 2009
I went through programing as far as lock recycling but wont go any further
Remote Transmitter Programming NOTE: All keyless entry remote transmitters must be programmed at the same time.
NOTE: Programming (or reprogramming) the keyless entry remote transmitters into the central security module can be accomplished using a diagnostic tool or by carrying out the following steps.
  1. Turn the ignition switch from OFF to RUN eight times within 10 seconds, ending in RUN. If the module has successfully entered program mode, it will lock and then unlock all doors.
  1. Within 20 seconds, press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed. Repeat this step for each transmitter.
  1. If the door locks do not respond for any keyless entry remote transmitter, wait several seconds and press the button again. If the door locks still fail to respond, refer to Inspection and Verification.
  1. Turn the ignition switch to the OFF position, or wait up to 20 seconds after Step 2, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the doors will lock and unlock one last time to confirm.
Mar 18, 2016 | 2004 Ford F150
2001 mustang keyless entry not working properly what do I do
You did it like this ?
Programming -Keyless Entry Remote Transmitter NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
NOTE: All previous transmitter identification codes (TIC's) will be erased when programming mode is entered.
NOTE: To program (or reprogram) the keyless entry remote transmitters into the generic electronic module (GEM)(14B204), perform the following steps.
  1. Turn the ignition from OFF to RUN eight times within 10 seconds, ending in RUN. If the GEM has successfully entered program mode, it will lock and unlock all the doors.
  1. NOTE: The first TIC must be entered within 7.5 seconds of entering the program mode and additional TICs must be entered within 7.5 seconds of the first TIC. The programming mode is exited whenever the timing constraints are not met. Press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed.
  1. If the door locks do not respond for any keyless entry remote transmitter, wait for several seconds and press the button again.
  1. Turn the ignition switch to the OFF position, or wait up to five minutes after step 1, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the GEM will lock and unlock all the doors one last time.
Jan 15, 2018 | 2001 Ford Mustang
How do you prgram remote keyless entry
Here are the instructions from the factory service manual:
1. Enter 5-digit permanent entry code into the keyless entry keypad.
2. Within 5 seconds of pressing last button of code, press the 1/2 button. All doors will lock then
unlock confirming you are in programming mode.
3. Press any button on first Keyless Remote within 5 seconds of pressing the 1/2 button. Locks will
cycle to indicate succesful programming.
4. If you are programming more than one Keyless Remote (Including any exsiting remotes) Press
any button on second keyless remote within 5 seconds of previous remote. Locks will cycle again
to indicate succesfull programming. (If the keypad light goes out before all remotes are
programmed the entire process must be repeated).
5. Press the 7/8 and the 9/0 buttons simultaneously on the keypad to exit program mode.
Sep 14, 2011 | 1995 Ford Crown Victoria
I have a 96 ford conversion van with a 600 plus addon keyless system and need to program new keyless remots , need to know how to get system in program mode.
Hi.
To program ( or reprogram ) a keyless entry remote transmitter into the remote keyless entry module, perform the following steps:
1. Turn the key to ON or ACC and short the two terminals of the program connector, a two-pin connector located below the driver's side of the instrument panel at the base of the steering column. All doors should lock and then unlock.
2. Press any button on each keyless entry remote transmitter in turn. All doors should lock and then unlock. If the door locks do not respond, press the button again (up to three times maximum with the same keyless entry remote transmitter). If the door locks still fail to respond, go to Pinpoint Test A.
3. Repeat Step 2 to program additional keyless entry remote transmitters into the remote keyless entry module (up to four keyless entry remote transmitters maximum).
4. Turn key off.
5. Remove the short from the program connector. All doors should lock and then unlock.
6. Verify that the keyless entry remote transmitters have been successfully programmed by pressing the LOCK or UNLOCK button on each one, and observing that the system responds by locking and/or unlocking the doors.
I hope this helps you.
Thanks!
Nov 28, 2010 | 1996 Ford Econoline
Keyless remotes not working
Try reprogramming the remotes. Here are the instructions for the procedure. Hope it helps. Cobra!
Programming NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
NOTE: To program (or reprogram) the keyless entry remote transmitters into the RAP module, perform the following steps:
  1. Make sure that the anti-theft system is not armed or triggered.
  1. Turn the ignition switch (11572) from OFF to RUN eight times within ten seconds, ending in RUN. If the RAP module has successfully entered program mode, it will lock and then unlock all doors.
  1. Turn the ignition switch to the OFF position, or wait up to 20 seconds after step 2, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the RAP module will lock and unlock all doors one last time to confirm.
Jun 06, 2010 | 1998 Ford F150 Regular Cab
How do i reprogram electronic door locks
Programming Electronic Door Lock Control System NOTE: The electronic door lock control processor (14B001) erases all previous keyless entry remote transmitter (15K601) from memory when the keyless entry remote transmitters are programmed or reprogrammed. The electronic door lock control processor can store up to four keyless entry remote transmitters in memory.
  • To program (or reprogram) keyless entry remote transmitter into the electronic door lock control processor, perform the following steps:
  1. Turn ignition switch to the RUN position and momentarily short the two terminals of the program connector taped to the wire assembly and located behind the glove compartment. All doors should lock and then unlock. Remove shorting pin.
  1. Press any button on keyless entry remote transmitter. All doors should lock and then unlock to verify the keyless entry remote transmitter has been programmed. If door locks do not respond, press button again (up to three times maximum with the same keyless entry remote transmitter).
  1. Repeat the above step to program additional keyless entry remote transmitters into the electronic door lock control processor (up to four keyless entry remote transmitters maximum).
  1. Turn ignition switch OFF. All doors should lock and then unlock.
  1. Check operation.
Jun 05, 2010 | 1997 Ford Windstar
Keyless entry remote quit working. Just purchased new battery. Now Spare remote does not work either.
Transmitter Programming Notes Transmitter Programming
  1. Start with the ignition OFF, hold down the power unlock button on the door panel. Turn ignition key ON, OFF, ON, OFF. Release power unlock button on the door panel. The locks will cycle once.
  2. Hold down the keyless entry transmitter LOCK and UNLOCK buttons for 15 seconds . The locks will again cycle once.
  3. Repeat step #2 for each additional keyless entry transmitter.
  4. Turn the ignition on to exit the keyless entry transmitter programming mode. Programming is now complete
Jun 17, 2009 | 2000 GMC Sierra
Can't program Second remote to my Ford Explorer 99
reading your post you mention to "open and close switch"..not sure what refering to...these are the instructions from your vehicles service manual...good luck!
Programming NOTE: All keyless entry remote transmitters (15K601) are programmable and must be set at the same time.
  1. Press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed.
  1. If the door locks do not respond for any keyless entry remote transmitter, wait several seconds and press the button again. If the door locks still fail to respond, refer to Diagnosis and Testing.
Jun 08, 2009 | 1993 Ford Explorer Limited
1999 lincoln con
SECTION 501-14B: Keyless Entry/Computer Operated Locks 1999 Town Car Workshop Manual GENERAL PROCEDURES Programming —Keyless Entry Keypad Code
  1. Enter the permanent factory keyless entry keypad code.
  1. Press the 1/2 button within five seconds to activate the programming mode. Holding the 1/2 button for more than two seconds will erase all stored customer codes. The existing codes do not need to be erased to program new codes.
  1. Enter the new five-digit keyless entry keypad code.
  1. To associate the new code with personality positions 1, 2 or 3, press the 1/2 button within 5 seconds of entering the 5th digit of the new code for position 1 or 3/4 button for position 2 or 5/6 for position 3. The door locks will lock and unlock confirming the new code is programmed.
  1. If another code is to be programmed, begin entering the code within 5 seconds of the last button pressed.
  1. After all new keyless entry codes are programmed:
    • Press keyless entry keypad buttons 7/8 and 9/0 at the same time to exit the program mode.
    • Wait for 5 seconds; the driver door module (DDM) will exit the program mode automatically.
Programming —Transmitter
  1. Cycle the ignition from OFF to RUN four times within three seconds. The locks will then lock and unlock, confirming program mode has been entered.
  1. NOTE: When the first keyless entry remote transmitter is programmed, all other keyless entry remote transmitters are erased.
    Press any button on the transmitter to be programmed.
  1. If additional keyless entry remote transmitters are to be programmed, repeat step 2 within 7.5 seconds.
  1. To exit program mode, turn the ignition to START or wait 7.5 seconds.
Programming —Remote Memory Activation NOTE: This procedure must be completed within 5 seconds.
  1. Press the SET button on the driver door panel.
  1. Press any button on the keyless entry remote transmitter to be associated with a memory setting.
  1. Press the 1 or 2 memory button on the driver door panel.
Programming —Autolock and Horn Chirp
  1. NOTE: This procedure must be completed within 30 seconds.
    Turn the ignition switch to RUN.
  1. Press the UNLOCK button three times.
  1. Turn the ignition switch to OFF.
  1. Turn the ignition switch to RUN. The doors will lock and unlock to confirm entry into program mode.
  1. Press the UNLOCK button once to toggle the Autolock feature on or off, or twice to toggle the Horn Chirp function on or off. The horn will chirp to confirm toggling of the Autolock feature.
  1. Exit program mode by turning the ignition to OFF, START, or wait 7.5 seconds.
Apr 07, 2009 | 1999 Lincoln Town Car
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,139 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
