Carrier AC unit inside goes on but outside doesn't. we have two units and we hear the one unit go on out side but not the other
  • 92 Answers
Check breaker,fuse,contactor?Make sure common and yellow go to condencer.
Posted on Jun 25, 2009
I HAVE CARRIER AC MODEL NO. 38HQR18UP30-03, WHEN START THE AC ONLY THE INSIDE BLOWER IS STARTING OUTSIDE UNIT FAN AND COMPRESSOR DOESNT START.....
It could be a number of things. Check breaker panel inside your house for flipped breakers. Check for bad fuses and check your capacitors. But only if you know how to use a multimeter and shut the power off first and understand how to de energize the capacitor. Otherwise call an electrician of hvac professional. Otherwise doing so can be deadly if your are unsure of electricity
May 17, 2016 | Carrier Heating & Cooling
Carrier 2000ss will not turn on. Checked fuses and they are okay.
Inside the outside unit is a pcb with fault diagnosis lights on. It could be anything from a weak start capacitor to a compressor fault or even short of gas. See what lights are on and check the manual
Apr 21, 2012 | Carrier Heating & Cooling
I have Carrier 38TKB036 3 ton A/C condensing unit and one 28CCA036 3 ton A-coil to provide A/C to home thru existing furnice. A/C was on and stopped working. Turned off/on, but will not come on. Any...
Is the furnace fan (indoor fan ) running. If not the problem is with the inside unit. It supplies the control power to operate the entire system and has a control fuse on the circuit board. If it is running but not the outside unit then the problem is outside.
Aug 08, 2011 | Carrier 38CKC042 Air Conditioner
Ac unit clicks outside but nothing engages fan or compressor on unit furnace still runs for heat setting and fan still blows but ac will not engage just hear a clicking was running for three days this...
Have you check the outside breaker? If its ok then you got a problem in your electrical system inside the unit probably the contactor is not engaging this is where the 24 volts from the thermostat calls for the 240 volts to run the condenser fan and compressor. Be careful checking this out because of the high voltage.
Jul 09, 2010 | Carrier 38CKC048 Air Conditioner
Carrier 38tkb not working, but furnace is blowing
It is probably a capacitor problem. Check inside the outside unit. you will see a round cylinder with three groups of terminals on top. If the top of it is dome shaped it probably needs to be replaced. You can check it if you have a microfared tester. However if it is poofed out it probably is bad. If this is not the problem you will probably have to replace the fan motor.
Jul 07, 2010 | Carrier 38CKC036 Air Conditioner
My ac is model carrier it's working both ouside and inside but still not cool from the house itself i just request where i could fine gas to be insert ,
Try changing the filter first and cleaning the compressor outside with a spray of water (with the unit off) The gas (freon) must be put in by a AC professional as it requires special equipment and an expert.
Aug 17, 2009 | Carrier 38CKC036 Air Conditioner
Compressor fan and compressor not running new 2 yr old system puron
No power to outside unit. Check to see if contactor on outside unit is pulled in. Most AC units inside have float switch. When the drain stops up it shuts off outside unit. Located in overflow or underneath unit. No Problem Rusty
Jun 05, 2009 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
