Question about Freezers
Settings for freezer - Freezers
    Sergeant:
  • 340 Answers
Set to 7
Posted on Jun 25, 2009
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
What is the temperature for the numeric settings? Thank you!
do not rely on the "settings" for the freezer,they are a guide ONLY.use a proper thermometer to get it to minus 18C.
Oct 04, 2010 | Frigidaire 12 cu. ft. / 340 liter Upright...
What should the settings be on this freezer?
any and all control settings should be in the middle of the control's maximum range scale.
Oct 03, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
I am just trying to find out what are the recommended settings for a 8.8 cu. ft. energy star rated Frigidaire chest freezer.
I would suggest getting a fridge/freezer thermometer and use that to set the temperature. They are marked with the recommended temperatures. Also many times the setting on the nob in the freezer are not very consistent so it is better to actually set the temperature by turning the knob up or down to reach the desired temp on the thermometer
Sep 18, 2010 | Frigidaire Freezer 8.8 cu. ft. Chest...
We have just got a second hand ice diamond freezer and not sure what the 2 drip and 1 drip symbols mean can you help me thankyou,
hello sir/mam
the symbol 1 drip indicates the normal settings,and the 2 drip symbol indicates higher settings.
Oct 04, 2009 | Freezers
Sears Kenmore Deep Freezer settings
It sounds like you have a circulation problem.
Spread out the packages so the freezing air can circulate.
  • Check that the condenser fan is on
  • Check that the coils are not covered with lint and dust especially if they are under the freezer.
  • you may need a tech to put freon in the system.
Apr 06, 2009 | Kenmore Freezers
Freezer/kenmore
the settings usually are:
off - on - superfreeze. you just want "on"
Nov 16, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
i tilt my chest kenmore deep freezer to remove water when cleaning it by the time it was connected it didnt work
Nov 10, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezers Logo
156 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
