Question about HP Compaq Presario SR2010NX PC Desktop
I want to replace the internal power source on my Compaq Presario. Aside from getting the right replacement part with the correct style plug, are there any traps for this rookie installer?
    Problem Solver:
  • 15 Answers
Aside from getting the right part you don't have anything to worry about.
not sure which is the right part?
go here: http://h20141.www2.hp.com/hpparts/default.asp?cc=US&lang=EN
and type in your model number
then power supply
Posted on Jun 25, 2009
    Sergeant:
  • 199 Answers
Not really the most confusing part is the new power supply may have a 24 pin power strip and your board may need a 20 pin but the 4 pin part will plug in also but in a different spot. it the new PS has a 24 pin connector it will have a way to snap off the four pin part. other than that should be a no brainer really. just pay attention and if you need make notes of what kind of cable goes where. oh and the plugs are keyed so you cant put them in wrong unless you push way to hard than you need to normally put one in
Compaq Presario SR2020NX will not turn on at all. Any ideas, people?
ah a tower
you check the power source output
this can be replaced as a whole unit
at power up should be a beep
if the mother board is good it will start up its default
before loading from the hard drive
make sure the dust is removed from all the internals
clean all the contacts
the fans and cards and main board
Oct 06, 2016 | Compaq Computers & Internet
How do I install new Hard Drive in my Compaq Presario cq5320PC Desktop
Hmm Well I cant seem to find your computer model anywhere on the Internet.... but assuming its a basic compaq Computer All you would need to do is buy the correct type of Hard Drive (Ide, sata) open the computer up with the power unplugged and static protection..... now some computers have multiple Hard Drive bays and some only have one so you will need to install your new HD into a bay assuming your replacing your current HD you would remove the old HD and install this one in its spot dont forget to Check the jumper setting on the Hard drive to either match the drive your replacing or as a Master in a single HD setup also plug in a power source and the data cable into your new drive or it wont work.... it should be that easy almost all new computers will automatically configure it in the cmos for you.... if its a replacement for your main HD then it will need You to install an Operating System on it before you can use it.
Oct 13, 2013 | Compaq Presario CQ5320F PC Desktop
How do i remove my compaq presario 2200's hard drive?
The Compaq Presario line is one of the longest-running series of computers, originating in 1993 and remaining in production even after the purchase of Compaq by HP. Because of this, many Compaq Presario desktops have required that some of their parts be upgraded or replaced because of the wear that they have received over years of standard use. One of the more commonly replaced Presario desktop components is the hard drives, especially given how much hard drivemag-glass_10x10.gif storage capacity has increased since the Compaq Presario line was introduced. Replacing a hard drive in a Compaq Presario desktop isn't difficult, and can usually be done in a matter of minutes even for users who aren't familiar with computer upgrades.
structions
  1. Step 1Remove the screws holding the left side panel of the computer on, then slide the panel back to remove it. Set both the panel and the screws aside so that you can put the panel back in place once the hard drive has been replaced.
  2. Step 2Unplug the ATA (wide, flat and usually gray) or SATA (thicker, thin and red) data cable and the power cable from the back of the hard drive that is currently in the Compaq Presario. Move the cables so that they will be out of the way, but make sure that they will still be easily accessible to you so that you can plug them into the new hard drive.
Aug 08, 2010 | HP Compaq Presario 2200 Notebook
Presario 5000 PC Desktop. I disassembled the entire danged thing and now can't figure out where to find an accurate manual or how to plug everything in the right place. HELP? :(
Be calm. All internal components fit only where they belong, if you read the name and number of *********** board you could google for the specific manual.
Basically you need to plug hard an optical drives, they need to be conected to the motherboard and also to the power source, most modern desktop computers have sound and video cards in the motherboard, if this is not the case plug them also. If you also removed RAM and processor be careful when reseating them, make sure they are firmly connected before turn on the computer. I hope this may help you.
May 13, 2010 | Compaq Presario 5000 PC Desktop
Does not boot makes a clicking sound
You have a key stuck on the keyboard. Unplug your keyboard turn the computer on if it it gets past the post, then you need to find which key is stuck. If the keyboard is usb then you can plug it in when you free the key. If it is PS2 style you can shut off power right after it starts with out clicking. Once off key freed you can turn it back on. If key is not findable replace keyboard. After verifing no keyboard no clicking.
Jan 15, 2010 | HP Compaq Presario SR1620NX...
Pc will not power up. Green light on power switch blinking like a slow stobe light. I tried un plugging it, did not work. I tried swicthing it to 240v, then back to 120v did not work. I tried an alternate...
The power supply is shot. Best suggestion is to replace it. You need to make sure it is replaced with the same model power supply. Check online for a replacement unit.
Mar 10, 2009 | HP Compaq Presario SR1110NX PC Desktop
Power
You may need to have the DC Jack replaced. It appears to be shorted. Should only run about $50-75. Ask the cost estimate before leaving it. You may be able to shop around. Use the smaller MOM&POP shops rather than the STORES or GEEKS.
Jul 18, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq presario dessktop 5000 series 5330US model#470019-713,Intel Pentium 4
Here is a link which supplys all needed internal parts for you specific computer...
http://www.impactcomputers.com/compaq-presario-5500-desktop-parts-internal-parts-and-assemblies.html
Feb 25, 2008 | Compaq Presario 5000 PC Desktop
No Power of a Compaq Presario Computer
Make sure that the power button is conected to the right prongs on the mother board. On the writing next to the prongs it should say power.
Feb 23, 2008 | Computers & Internet
HP Compaq Presario SR2010NX PC Desktop Logo
77 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
