Question about Traeger Industries Grilling
My bbq/smoker model # bbq 070 serial #36096 is tripping the breaker everytime I turn it on, what is the problem. kevin@kmresorts.com
  • 240 Answers
There is some circui anywhere in the smoker u surely need en electricin service man to check it. check it soon dont use it or try to use it it mat be dangerous.. pls rate the answer
Posted on Jun 25, 2009
Louisiana BBQ grill trips circut breaker
You need to take other devices off that circuit. Also outdoor circuits usually are on a GFI circuit.which are very sensitive to flucuations.
Jul 14, 2014 | Traeger Industries BBQ070 All-in-One Grill...
Control board for BBQ 070
Contact Traeger customer service at http://www.traegergrills.com for parts and installation instructions.
Mar 30, 2014 | Traeger Industries Grilling
Treager bbq keeps tripping breakers
I would strongly recommend you pull the control panel and inspect the fuse. Before tripping a breaker, your GFS outlet should trip, and/or blow the fuse.
If the unit is tripping circuits, then there is likely a short. Given the material draw from the hot rod, I would start with that. Putting a multi-meter on it to test voltage, should give you a basis to confirm with Treager if it's within spec. Sometimes it's simpler to replace the rod, but this can add up quickly if not the root issue.
Dec 26, 2013 | Traeger Industries Grilling
Can you find manual for charbroil bbq? model # 466454706, serial # 0606230411? its about 4-5 yrs old.
You can get an Owners Manual by contacting Charbroil's Customer Service at 866-239-6777.
Apr 11, 2011 | Char-Broil CharBroil Master Flame Gas...
Grill will not turn on
I assume you are referring to the auger motor. If so, have you checked the electric receptacle the g=auger motor is plugged into? Plug another electric appliance, like a lamp into the receptacle to see if the lamp works. If not, look for a tripped circuit breaker in your home's breaker panel. If one is tripped, make sure nothing is plugged into the offending receptacle and reset the breaker. Plug the auger motor back in to see if the breaker trips again. If does, there's an electrical issue with the auger motor or the cord.
If none of the above is the problem, i have included a link to Traeger Industries website. There you can find and download the Owners Manual for your Grill-Smoker, which also has a Trouble Shooting Section.
http://www.traegergrills.com/
Feb 21, 2011 | Traeger Industries BBQ070 All-in-One Grill...
I have a Thermos gas BBQ Model # 461410708. It seems everytime I try to light it there's not enough gas going through the burners to stay lit. I'm after turning off the tank and removing the regulator and...
You probably need a new regulator. It sounds like it is sticking, so take your old one with you to a store that sells BBQ's and get a new one.
Apr 11, 2010 | Grilling
Electric smoker is now tripping GFCI breaker
GFCI breaker tend to wearout and become more sensitive after time and use. Motor loads are especially hard on them. Also resistance loads such as heating elements. Your smoker may be pulling a bit more electric than it used too.
Check the power draw of the smoker when operating, if it is high then fuigure out why. It it is normal then replace the braker. Use a regular breaker if the GFCI is not required, or run a cord from an outlet that is not on a GFCI breaker.
Heatman101
Jan 24, 2010 | Masterbuilt 20070106 Electric Smoker
Gas Grill
The "safety" inside the gas tank has tripped. Close the valve on the tank, remove the hose from the tank, reconnect the hose and SLOWLY open the valve on the tank. This should reset the safety.
SG
Apr 06, 2009 | Grilling
Tripping the electrical Breaker
I have used the charbroil bullet electric H2O smokers for years (wore 2 out - currently on my 3rd). I won't use anything else (having used many, many others - HOWEVER - as with every product made there are things to watch or overcome. Learn to use it properly and look forward to many years of great BBQ.
Ambient (outside) air temp below 70 (depending on wind also) will affect these smokers drastically - highly recomend getting or making a "smoker blanket" (got mine at cabelas years back - if you can't find one welding blankets from an industrial supply store can be made into one) to insulate the sides - this drastically reduces heat loss and reduces the electrical load.
Another MAJOR mistake many people make is extension cords - avoid the use of them at all if possible - if not possible then purchase the heaviest gauge you can find.
Always pre-heat your smoker - Always use boiling water (or other liquid) in the H2O pan added after smoker is pre-heated - Always minimize opening the smoker once cooking has begun.
The heater element can be cleaned when cold with a very mild detergent and room temp water.
If you have the large 2 rack but are only smoking enough to use a small amount of rack space on only one rack remember that you are heating a whole lot of air - i have a couple (different size) wood boxes wrapped in foil to take up excess air space - this means less air volume to be heated and better heat control - DO NOT use cardboard boxes or other low temp combustable items in the box construction!
Make sure the house outlet you are plugging into is a 3-prong GROUNDED outlet on a 20 amp breaker.
Finally, make sure your smoker is level and remember there can be up to a 20 degree cooking temp swing in temp between the bottom rack and top rack (top rack 5-20 degrees hotter than bottom).
The heater element will cycle on and off during normal use.
Good smoking and enjoy.
Apr 28, 2008 | Char-Broil Electric H2O Smoker
Grilling Logo
155 people viewed this question
Top Traeger Industries Grilling Experts
Gary Kenady
Gary Kenady
Craig Butler
Craig Butler
Paul Carew
Are you a Traeger Industries Grilling Expert? Answer questions, earn points and help others
