Question about Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I HAVE A 8 HORSE TROY BILT TILLER I NEED A CARBURATOR FOR IT. WHERE CAN I FIND ONE. HOW MUCH DO IT COST. IT HAS A KOHLER ENGINE ON IT
    Scholar:
  • 115 Answers
I would check ebay, or goto troybilt.com and find a parts list there. good luck
Posted on Jul 04, 2009
This is a Troy Bilt Big Red Horse Tiller. Wont crank. new battery. ignition switch good. starter relay clicks when ignition switch turned. jumpering the relay makes the starter spin.
The starter solenoid/relay clicking can mean a bad starter solenoid/relay or bad grounding. Not knowing what engine you have as they have used Kohler, Tecumseh and Briggs and Stratton over the years. hope this helps
Mar 06, 2015 | Troy-Bilt Garden
How to troubleshoot a kohler m8 engine
first check for spark then check for fuel try starting fluid does it fire on starting fluid then is carb related
May 22, 2012 | Troy bilt Horse Tiller Hiller Furrower...
Adjustment for belt for 8 horse power horse. Really need to find a manual. Where can I locate one?
http://www.hammerwall.com/Manuals/Troy-Bilt/Description/21A682J766/Troy-Bilt%208%20HP%20Rear%20Tine%20Tiller%208%20HP%20680%20Series%20Briggs%20and%20Stratton%20Engine%20Manual/275092/
May 29, 2011 | Troy Bilt 21A682J766 Horse 8 HP Rear Tine...
How can I find a parts manual/breakdown for an older Troy Bilt tiller? I beleive it was manufactured in 1987 possible model #870487 definite S/N 87 46 39. This tiller has the 8 HP Kohler engine. I am...
http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1
Go to this website and type in horse for your model number and you should be able to find a parts break down for your tiller. If the serial number is 874639 it was made in 3/88 and will be a four speed PTO model.
I find a lot of parts on Ebay for these tillers, your can order parts through MTD but they will be a little pricey. MTD aquired Troy Bilt out of bankruptcy in 2001 and still carries parts for the tillers.
Frank
Jun 27, 2010 | Troy-Bilt Garden
Old Troy Built with model #HH60-105106F. What is
That's the engine number. It's a 6Hp Tecumseh. Go on ebay and buy the Troy Bilt parts manuals on CD for Horse Roto Tillers (if that's what it's on). I paid $8. Definitely worth it.
Mar 08, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Need flywheel K161T tiller 7 hp kohler
Go to www.precisionope.com. Find Kohler under OEM parts.
Good Day.
Oct 07, 2009 | Troy-Bilt Garden
I have a horse model about 35 years old with a kohler motor 7 horse. What new motor fits. serial no. 360331
In my opinion, (which doesn't count for much, I know) the 7hp Kohler Troy Bilt Horse tiller was the best tiller ever made. Those tillers lasted forever if they were taken care of. I've got one of the 8hp Kohler versions, but it's just not the same.
It's become a lot harder to find an engine to replace these engines. You'll most certainly want to go to a Briggs and Stratton dealer and have them look it up. You need a 3/4" crank, 2 7/8" long with a keyway, tapped for a bolt to hold on the pulley and reverse disc. IF you find an engine to fit, you'll likely need to have a custom throttle cable made up to replace the current one. A good small engine dealer should be able to help you.
Now for the bad news. The 7hp Kohler was a cast iron engine. Any replacement engine you find will likely be an aluminum block with a cast iron sleeve and therefore, much lighter. What this means is the balance of the tiller, from front to back, is going to be thrown off. The result is - it will be MUCH harder to pick up the rear of the tiller when you want to turn at the end of the garden. You will most likely need to either put on one of the bumpers (if you can find one to fit) or figure out a way to hang some weight on the engine. I've seen people do some creative things to get the balance back. Whatever you do, it just won't be the same as that great 7hp Kohler. I'd suggest trying to rebuild it - if possible!
Jun 11, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
Apr 02, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt Pony 6.5 Hp Rear Tine Tiller Logo
224 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
