Question about Kenmore Elite 45986 Front Load Washer
Not getting clothes clean
My Elite front loader doesn't appear to keep water in it. The clothes are not getting clean and we get absolutely no suds. we use the same HE detergent. The water seams to just go through and not stay in the machine.Any suggestions?Thanks
  • 58 Answers
Check your drain hose for siphoning. this is a common problem, make sure only about 8 inches is sticking into the drain, and the drain line is higher then the mid point of the washer, ex: drain hose must not leave the washer and head directly to the floor, must make a loop upwards, then enter a drain appx. 3+ft high. Drain hose from washer not to enter drain plumbing more then 8".
Posted on Jun 25, 2009
My Kenmore Elite front loader keeps on showing the same problems
Cut down on your soap i only use very little soap and it works great.No more SUD code
Jul 02, 2014 | Kenmore Elite 45986 Front Load Washer
Maytag Front load Washer. "SUDS"
Clean the drain pump basket. http://www.youtube.com/results?search_query=kenmore+elite+front+load+washer+drain+pump+cleaning&oq=Kenmore+Elite+Front+Load+Washer+drain+pump+clean&gs_l=youtube.1.0.33i21l2.425000.427123.0.432800.6.6.0.0.0.0.410.1517.2-5j0j1.6.0...0.0...1ac.1.lQhVllMwg9M
Jan 27, 2013 | Maytag MAH2400 High Efficiency Front Load...
Ytek.netwe just moved into a house with a duet washing machine- a few years old. when we do a normal clean cycle, it doesnt appear there is that much water getting used. How much water should we see thru...
All front loaders use very little water as a opposed to a top loader that uses up to 45 gallons per load a front loader uses about 10,plus a front loader cleans clothes very well with that minimal water usage.
The major question is do the clothes seem to come out clean when you have used that washer?
Aug 20, 2011 | Whirlpool Washing Machines
Should suds be visible in top load washers during the wash cycle?
Not if your using the correct amount of HE detergent You have to start with the understanding that the tumble action of high-efficiency washers (i.e., front loaders) produce more suds than the agitator action in top loaders. Now most of people think, "Oooo, sudsy, that's good!" No, not good. Suds do nothing to clean your clothes and are actually an undesirable by-product of the detergent's chemical interaction with the water. The main job of detergents is to remove soils and stains. They do this by breaking down the surface tension of water, in effect, making water "wetter." The water is what actually does the cleaning by slipping in between the ca-ca and the fabric, separating them and suspending the ca-ca in solution.
Detergents are designed to freshen, remove odors, and brighten fabrics as they clean. Another key detergent function is to hold ca-ca, and any dyes from colored fabrics, suspended in the wash water so they aren't re-deposited back onto the cleaned clothes. Traditional detergents are designed to do this in high water volumes used by conventional, top-loading water hog washers.
If you think about it, using HE detergent in your front loader is really common sense. Because of the low-water wash and rinse cycles in HE washers, HE detergents must work differently from traditional laundry detergents in order to be effective.
Excess suds can cause the washer's pump to overheat causing premature failure of the pump. These excess suds also cause residue to build up inside the drum and hoses. After a while, your washer will start giving off a moldy funk and infecting your clothes with its faint, musky stink. Hope this Helps Good Luck
Oct 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a kenmore elite he3 front loader; it gives me the "sud" code during a wash cycle. What could be the potential problem?
either way too much soap or the wrong type,run a couple of washes,without clothes to purge excess soap and see if this clears up the sud code
Jul 07, 2010 | Kenmore Elite 45986 Front Load Washer
Can you use regular detergent with front loader washers??
All manufactures suggest using a high efficiecy detergent. They are specially formulated to keep the suds level low and work well with the low water levels of a front loader. Boxes are marked with an HE on them letting you know they are for high effiency machines. Regular detergents were designed for washers that use many gallons of water.
Feb 03, 2010 | Kenmore Elite 45986 Front Load Washer
Suds indication
Hi!
For a top loader, a general rule of thumb is to lay clothes loosely inside the washer until they reach the top of the agitator. For a front loader, fill it until it's full, with minimal compression of the clothes.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Usage of HE detergents
The best he soap I have seen yet is all, he is high effieciency low suds soap. The rule of thumb for liquid he soap is 2 Tbl for every 1 Tbl of softener. Powder can be used but is not good on pumps and build up in tubs. If you have a water softener you can use 25% less soap. Still with powder you need about a 1/4 cup per load to equal a 2 Tbl liquid variety. Suds damage pump impellers, seals and hoses from expansion and that is it on the reason "why to use he".
Sep 04, 2008 | LG WM-2277HW Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
49 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
