Unit blew breaker and now will not turn on? I checked fuse box and reset the breaker, I checked the fuse on the evaporator and seems fine, but still not working. Amana split unit.
  • 92 Answers
Sounds like you have a grounded compresser! need new 1 !sorry
Posted on Jun 25, 2009
No power. Will not turn on
It may have tripped the internal breaker, and or the house circuit breaker. Go tot the house fuse box and check that first.
Mar 05, 2014 | Whirlpool Gold GU2275XTVy Dishwasher
Was working fine then just stopped runningm didn't slow down or make any noise just stopped like a fuse blew. Is there a reset button on main unit on roof
Hi, there are no reset buttons on the roof, but find the breaker panel in your RV, and you will find a breaker that is most likely tripped. You will need to reset it by turning it off and back on very firm. It should be about a 20 amp breaker. On the roof , there may also be a disconnect box with either a breaker or fuses also. Check the one inside the RV first, it is there somewhere. If it continues to trip the breaker, we will have to check to see if you have a problem with the compressor, condenser fan motor up top, and blower motor inside to see what is taking place. You may have a dirty coil up top that needs a good washing out as this will cause the unit to have high internal head pressures and will take out the compressor and keep tripping the breakers. Keep me posted on what you find and please don't forget to rate me as I know you will be kind. I will check back in with you on this to see how you are doing. It is 11:00p.m. here, so I will check on you in the a. m. This should solve your problem if you remove the top and make sure the condenser motor is running along with the compressor. Then kill the power again to wash this coil out. Please keep me posted.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Aug 29, 2010 | Dometic Rooftop RV Air Conditioner
Bulb blew on cooker hood and I replaced both. Light still won't work and neither will fan - both working fine until bulb blew.
hello. I can assist you. begin by going to the electrical panel for your home. You will be looking for the circuit breaker or fuse that controls this hood. Chances are the actual problem is that the fuse blew, or the circuit breaker kicked off. To reset, replace the fuse with a new one of the same amperage, or turn the breaker on and then off and then back on again.
Nov 18, 2009 | Televison & Video
Is there a reset for the a/c unit itself
check for fuses in disconnect at the out door unit or a reset button where the copper line set goes into the unit at make sure stat wires have not been damaged hope this helps
May 15, 2009 | Weather King 10AJA4201AH Air Conditioner
Unit was working fine. turned off for a few minutes. will not come back on.,
Sounds like the breaker tripped, either in your breaker box or in the shut off switch located next to the outdoor condensor. This could be also either one or two of the fuses blew and need to be replaced
Apr 30, 2009 | Heating & Cooling
No power to the boiler--- breakers are all fine
What type of unit do you have, need details, if it is a split system there will be a pc board inside inside / outside or both units, on the board will be a glass fuse, turn power off at switchboard before removing covers.
Nov 12, 2008 | Heating & Cooling
Loud Pop, blown Breaker
Pull the unit away from the wall and inspect from rear. However, if all is fine, perhaps you simply overloaded the circuit that once. Were you running any other appliances (overhead microwave) at the same time?
Mar 28, 2008 | GE 30 in. JP340 Electric Cooktop
Carrier air conditioner
Sounds like you either blew a transformer, have a bad circuit breaker or blew the main fuse in the outside disconnect. If the indoor unit is still blowing air (no matter what temperature) start looking at the power supply to the outdoor unit. From the circuit breaker, the power will go to a small box located within a few feet from the outside unit. This box will have either a lever on the side or you will be able to open the box and pull out the fuses. From this box the power goes to the condensor. The first thing you should do is to turn off the breaker to the outside unit. Flip it back on and if you have a call for cooling, after about 3 minutes the outdoor unit should start. If it does not, shut off power again to the unit by switching off the breaker, go outside and pull out the fuses in the disconnect box. Using a multi meter, check for continuity thru the fuses. If you have continuity, call your technician. If one or both fuses show no sign of continuity, replace the fuse(s). Make sure that the thermostat is working and sending a signal to the indoor air handler. You may be able to check this by turning the fan switch to "Fan" and see if the blower turns on. You may just have a bad thermostst. Caution should be used anytime you are near electrical components. If you do not have the skill-set required to test electrical equipment, leave it to a proffessional.
Sep 03, 2007 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
