Question about Peg Perego Aria Twin Stroller
Need to replace underneath basket
My basket underneath is worn out.. need to replace it.. where can i get a new one?
  • 127 Answers
Call perego at 1800-671-1701 they will have it,or check ebay
Posted on Jun 26, 2009
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Have a yz85 that jumps out of second gear. Whats the fix?
you might need a new clutch basket, it could be worn take out clutch plates and check for groves in the basket they may be sandable but you might have to replace. good luck
May 02, 2012 | 2003 Yamaha YZ 125
Replacement basket for a Graco DuoGlider
Hello Carcuni,
Go to this link http://www.gracobaby.com/ReplacementParts/Pages/ReplacementParts.aspx
You should be able to replacement parts for your duoglider.
Apr 28, 2010 | Baby Gear
The spin cycle is not working. I already replaced the clutch assembly. Still, it did not wrok.
when you replaced the clutch did you look at the bottom of your basket drive tube to see if it was worn down,also the white plastic brake release arm could have the 2 little lineup pins broken off, or your drive block could be worn out,it is under your agitator,,,,,i found out on my machine that the bottom of the basket drive tube has a brass t post and the thrust washer had worn it off completely,the clip that holds the brake release arm fell off and broke those 2 little fingers off the arm,,,,,,i had to buy a used basket drive tube installed it with a new clutch and now the spin cycle works fine !! give it a good look at
Feb 15, 2010 | Kenmore Washing Machines
Direct Drive Kenmore Washing Machine will not spin a full load of clothes during rinse or spin but will spin a small load. Agitates fine. Replaced drive coupler, clutch and basket drive...no luck. What...
its possible the ears on the top of the drive tube have worn alowing the basket drive block to slip and not turn the clothes basket with authority, or the basket drive block has just worn from overloading and needs replacing.. is easy to verify by looking..
best of luck,
ttfn
Oct 25, 2009 | Whirlpool LSR7333 Top Load Washer
Basket strainer
You will need to have the entire basket strainer drain assembly replaced.
Jul 12, 2009 | Plumb Pak Laundry Tub Strainer Basket...
I need a new franke sink basket strainer for my franke sink model PRX11021 - stainless steel. What is the model number that will fit this sink and can I order it online or go to a local store?
You should purchase a complete basket strainer assembly. Home Depot or Lowes have some very nice ones. They are a standard size.
Tell them it's for your kitchen sink.
Jan 28, 2009 | Plumbing
Tub and Basket
Fairway, sounds like you have a worn drive block. You are going to have to remove the agitator and inspect the drive block. If it is the drive block you will get some good hammering when the spin cycle stops. I will attach some photos of a worn out drive block. If you want to attempt to handle this yourself, we can walk you through it. Catriver..post back.
Oct 23, 2006 | Whirlpool Ultimate Care II LSQ9564J Top...
Peg Perego Aria Twin Stroller Logo
263 people viewed this question
Top Peg Perego Baby Gear Experts
Jennifer Rock
Jennifer Rock
Are you a Peg Perego Baby Gear Expert? Answer questions, earn points and help others
